07:57:55.708 (loader): file changed
07:57:55.742 (loader): File "C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\Teensy-RV-Leveling-Helper-Pair.ino.hex", 116736 bytes
07:57:55.742 (loader): File "Teensy-RV-Leveling-Helper-Pair.ino.hex". 116736 bytes
07:57:55.800 (post_compile 25): Begin, pid=6092, version=1.59-beta6, high-res time
07:57:55.803 (loader): remote connection 1544 opened
07:57:55.804 (loader): remote cmd from 1544: "comment: Teensyduino 1.59-beta6 - WINDOWS (teensy_post_compile)"
07:57:55.804 (post_compile 25): ARDUINO_USER_AGENT = "arduino-cli/0.34.0 arduino-ide/2.2.1 grpc-node-js/1.8.18"
07:57:55.804 (post_compile 25): Sending command: comment: Teensyduino 1.59-beta6 - WINDOWS (teensy_post_compile)
07:57:55.806 (loader): remote cmd from 1544: "status"
07:57:55.809 (loader): remote cmd from 1544: "dir:C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\"
07:57:55.809 (post_compile 25): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:55.809 (post_compile 25): Sending command: dir:C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\
07:57:55.811 (post_compile 25): Sending command: file:Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:55.811 (loader): remote cmd from 1544: "file:Teensy-RV-Leveling-Helper-Pair.ino.hex"
07:57:55.831 (loader): File "C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\Teensy-RV-Leveling-Helper-Pair.ino.hex", 116736 bytes
07:57:55.831 (loader): File "Teensy-RV-Leveling-Helper-Pair.ino.hex". 116736 bytes
07:57:55.837 (loader): remote cmd from 1544: "status"
07:57:55.846 (post_compile 25): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:55.846 (post_compile 25): Disconnect
07:57:55.877 (loader): remote connection 1544 closed
07:57:56.759 (post_compile 26): Begin, pid=7944, version=1.59-beta6, high-res time
07:57:56.762 (loader): remote connection 728 opened
07:57:56.764 (post_compile 26): ARDUINO_USER_AGENT = "arduino-cli/0.34.0 arduino-ide/2.2.1 grpc-node-js/1.8.18"
07:57:56.764 (post_compile 26): Sending command: comment: Teensyduino 1.59-beta6 - WINDOWS (teensy_post_compile)
07:57:56.764 (post_compile 26): port = "usb:0/140000/0/3"
07:57:56.764 (loader): remote cmd from 728: "comment: Teensyduino 1.59-beta6 - WINDOWS (teensy_post_compile)"
07:57:56.768 (loader): remote cmd from 728: "status"
07:57:56.773 (post_compile 26): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:56.773 (post_compile 26): Sending command: dir:C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\
07:57:56.773 (loader): remote cmd from 728: "dir:C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\"
07:57:56.776 (loader): remote cmd from 728: "file:Teensy-RV-Leveling-Helper-Pair.ino.hex"
07:57:56.777 (post_compile 26): Sending command: file:Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:56.797 (loader): File "C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\Teensy-RV-Leveling-Helper-Pair.ino.hex", 116736 bytes
07:57:56.797 (loader): File "Teensy-RV-Leveling-Helper-Pair.ino.hex". 116736 bytes
07:57:56.807 (loader): remote cmd from 728: "status"
07:57:56.816 (post_compile 26): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:56.816 (post_compile 26): Disconnect
07:57:56.833 (post_compile 27): Running teensy_reboot: "C:\Users\mjcul\AppData\Local\Arduino15\packages\teensy\tools\teensy-tools\0.59.6\teensy_reboot.exe" teensy_reboot.exe "-board=TEENSY40" "-port=usb:0/140000/0/3" "-portlabel={serial.port.label}" "-portprotocol={serial.port.protocol}"
07:57:56.834 (loader): remote connection 728 closed
07:57:56.840 (loader): remote connection 728 opened
07:57:56.877 (reboot 28): Begin, pid=5716, version=1.59-beta6, high-res time
07:57:56.877 (reboot 28): location = usb:0/140000/0/3
07:57:56.877 (reboot 28): portlabel = {serial.port.label}
07:57:56.877 (reboot 28): portprotocol = {serial.port.protocol}
07:57:56.877 (reboot 28): portprotocol missing, infer "Teensy" from location
07:57:56.877 (reboot 28): Only location usb:0/140000/0/3 will be tried
07:57:56.877 (reboot 28): LoadLibrary cfgmgr32 ok
07:57:56.877 (reboot 28): LoadLibrary ntdll ok
07:57:56.879 (reboot 28): found_usb_device, id=\\?\usb#vid_16c0&pid_0483#12886730#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
07:57:56.879 (reboot 28): found_usb_device, loc=usb:0/140000/0/3 Port_#0003.Hub_#0001
07:57:56.879 (reboot 28): found_usb_device, hwid=USB\VID_16C0&PID_0483&REV_0279
07:57:56.879 (reboot 28): found_usb_device, devinst=00000002
07:57:56.879 (reboot 28): add: loc=usb:0/140000/0/3, class=USB, vid=16C0, pid=0483, ver=0279, serial=12886730, dev=\\?\usb#vid_16c0&pid_0483#12886730#{a5dcbf10-6530-11d2-901f-00c04fb951ed}
07:57:56.879 (reboot 28): comport_from_devinst_list attempt
07:57:56.879 (reboot 28): found Ports in classguid_list at index=1
07:57:56.879 (reboot 28): port COM8 found from devnode
07:57:56.879 (reboot 28): found_usb_device complete
07:57:56.883 (reboot 28): usb scan found 1 devices
07:57:56.886 (loader): remote connection 1536 opened
07:57:56.891 (reboot 28): found Teensy Loader, version 1.59
07:57:56.891 (reboot 28): Sending command: show:arduino_attempt_reboot
07:57:56.891 (loader): remote cmd from 1536: "show:arduino_attempt_reboot"
07:57:56.896 (loader): got request to show arduino rebooting message
07:57:56.902 (loader): remote cmd from 1536: "comment: Teensyduino 1.59-beta6 - WINDOWS (teensy_reboot)"
07:57:56.902 (reboot 28): Sending command: comment: Teensyduino 1.59-beta6 - WINDOWS (teensy_reboot)
07:57:56.908 (loader): remote cmd from 1536: "status"
07:57:56.915 (reboot 28): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:56.915 (reboot 28): do_reset (serial) COM8
07:57:56.920 (loader): remote cmd from 1536: "status"
07:57:56.927 (reboot 28): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:56.927 (reboot 28): status read, retry 0
07:57:57.034 (loader): remote cmd from 1536: "status"
07:57:57.047 (reboot 28): Status: 1, 1, 0, 3, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:57.047 (reboot 28): status read, retry 1
07:57:57.158 (loader): remote cmd from 1536: "status"
07:57:57.169 (loader): handle 5a0
07:57:57.176 (loader): Device came online, code_size = 100
07:57:57.182 (loader): Board is: NXP IMXRT1062 ROM
07:57:57.189 (loader): begin operation
07:57:57.213 (loader): File "C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\Teensy-RV-Leveling-Helper-Pair.ino.hex", 116736 bytes
07:57:57.218 (loader): File "Teensy-RV-Leveling-Helper-Pair.ino.hex". 116736 bytes
07:57:57.223 (loader): set background IMG_ONLINE
07:57:57.235 (reboot 28): Status: 1, 1, 1, 4, 0, 8, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:57.243 (loader): nxp_write: success
07:57:57.248 (loader): HAB locked secure mode
07:57:57.261 (loader): ERROR, need .ehex file for locked Teensy
07:57:57.268 (loader): start ignoring usb:0/140000/0/3
07:57:57.273 (loader): end operation, total time = 0.077 seconds
07:57:57.282 (loader): redraw timer set, image 81 to show for 8000 ms
07:57:57.298 (loader): remote cmd from 1536: "status"
07:57:57.317 (reboot 28): Status: 1, 1, 0, 4, 0, 0, C:\Users\mjcul\AppData\Local\Temp\arduino\sketches\8895C39DBBCE0E7B0A0F8F3765B0B1F4\, Teensy-RV-Leveling-Helper-Pair.ino.hex
07:57:57.317 (reboot 28): status read, retry 2
07:57:57.317 (reboot 28): Disconnect
07:57:57.317 (reboot 28): Success
07:57:57.348 (loader): remote connection 1536 closed
07:57:57.371 (loader): remote connection 728 closed
07:58:05.292 (loader): redraw, image 9
