cores\teensy4\MTP_Storage.cpp: In member function 'void MTPStorage::OpenIndex()':
cores\teensy4\MTP_Storage.cpp:339:25: error: 'MTP_class' has not been declared
339 | MTP_class:rintStream()->printf("Failed to open Index file on storage number %d try memory File\n", index_file_storage_);
cores\teensy4\MTP_Storage.cpp:349:22: error: 'MTP_class' has not been declared
349 | if (!index_) MTP_class:rintStream()->println("cannot open Index file");
cores\teensy4\MTP_Storage.cpp: In member function 'void MTPStorage:rintClearRecordReadWriteCounts()':
cores\teensy4\MTP_Storage.cpp:384:9: error: 'MTP_class' has not been declared
384 | MTP_class:rintStream()->println("*** Storage Record Read/Write counts ***\n");
cores\teensy4\MTP_Storage.cpp:385:9: error: 'MTP_class' has not been declared
385 | MTP_class:rintStream()->printf(" Writes: %u to FS:%u\n", debug_write_record_count_, debug_fs_write_record_count_);
cores\teensy4\MTP_Storage.cpp:386:9: error: 'MTP_class' has not been declared
386 | MTP_class:rintStream()->printf(" Reads: %u from FS:%u\n", debug_read_record_count_, debug_fs_read_record_count_);
cores\teensy4\MTP_Storage.cpp:391:9: error: 'MTP_class' has not been declared
391 | MTP_class:rintStream()->printf("Record Info Blocks (index\tblock_index\tlast hit\tdirty):\n");
Current cores from git isn't usable due to throwing a load of MTP related errors
MTP internal filesystems info:
Storage List, 12 Filesystems
store:0 storage:10001 present:Yes fs:20004078 name:"" fsname:"PROGRAM"
store:1 storage:20001 present:Yes fs:20004144 name:"RAM1" fsname:"EXTMEM"
store:2 storage:30001 present:Yes fs:20004210 name:"RAM2" fsname:"EXTMEM"
store:3 storage:40001 present:Yes fs:20009960 name:"SD Card" fsname:"Untitled"
store:4 storage:50001 present:Yes fs:2000E5C8 name:"USB1" fsname:"USB DISK"
store:5 storage:60001 present:No fs:2000EA7C name:"USB2" fsname:""
store:6 storage:70001 present:No fs:2000EF30 name:"USB3" fsname:""
store:7 storage:80001 present:No fs:2000F3E4 name:"USB4" fsname:""
store:8 storage:90001 present:No fs:2000F898 name:"USB5" fsname:""
store:9 storage:A0001 present:No fs:2000FD4C name:"USB6" fsname:""
store:10 storage:B0001 present:No fs:20010200 name:"USB7" fsname:""
store:11 storage:C0001 present:No fs:200106B4 name:"USB8" fsname:""
I noticed it a couple of days ago... Figured I would wait until it was packaged upJust noticed that you added MTP to the Teensy4 core but not to the Teensy 3 core. Are you planning to add it to the Teensy 3 core as well?
Will be curious if (experimental) has been removed![]()
#include "SdFat.h"
Glad you mentioned that - I noticed that the other day but forgot to post about it. Now to implement you change just so I can have both on my systemProbably not a complete solution, but at least I can build on both systems again...
