T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c: In function 'lfs_dir_traverse.constprop':
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:822:70: warning: array subscript 'const struct lfs_attr[0]' is partly outside array bounds of 'struct lfs_diskoff[1]' [-Warray-bounds]
822 | int err = cb(data, LFS_MKTAG(LFS_TYPE_USERATTR + a[i].type,
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:293:19: note: in definition of macro 'LFS_MKTAG'
293 | (((lfs_tag_t)(type) << 20) | ((lfs_tag_t)(id) << 10) | (lfs_tag_t)(size))
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:753:28: note: while referencing 'disk'
753 | struct lfs_diskoff disk;
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:823:53: warning: array subscript 'const struct lfs_attr[0]' is partly outside array bounds of 'struct lfs_diskoff[1]' [-Warray-bounds]
823 | lfs_tag_id(tag) + diff, a[i].size), a[i].buffer);
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:293:72: note: in definition of macro 'LFS_MKTAG'
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:823:65: warning: array subscript 'const struct lfs_attr[0]' is partly outside array bounds of 'struct lfs_diskoff[1]' [-Warray-bounds]
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c: In function 'lfs_dir_compact':
T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS\src\littlefs\lfs.c:754:42: warning: array subscript 'lfs_mdir_t {aka const struct lfs_mdir}[0]' is partly outside array bounds of 'struct lfs_diskoff[1]' [-Warray-bounds]
754 | if (off+lfs_tag_dsize(ptag) < dir->off) {
Compiling library "SPI"
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-g++" -c -O3 -g -Wall -ffunction-sections -fdata-sections -nostdlib -MMD -std=gnu++17 -fno-exceptions -fpermissive -fno-rtti -fno-threadsafe-statics -felide-constructors -Wno-error=narrowing -Wno-psabi -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -D__IMXRT1062__ -DTEENSYDUINO=160 -DARDUINO=10819 -DARDUINO_TEENSY41 -DF_CPU=600000000 -DUSB_SERIAL -DLAYOUT_US_ENGLISH "-IT:\\TEMP\\arduino_build_570794/pch" "-IT:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr\\cores\\teensy4" "-IT:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr\\libraries\\LittleFS\\src" "-IT:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr\\libraries\\SPI" "T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr\\libraries\\SPI\\SPI.cpp" -o "T:\\TEMP\\arduino_build_570794\\libraries\\SPI\\SPI.cpp.o"
Compiling core...
Using precompiled core: T:\TEMP\arduino_cache_54489\core\core_fbaf3cc09a6812b07e339698e1d55848.a
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-gcc" -O3 -Wl,--gc-sections,--relax "-TT:\\T_Drive\\arduino-1.8.19\\hardware\\teensy\\avr\\cores\\teensy4/imxrt1062_t41.ld" -mthumb -mcpu=cortex-m7 -mfloat-abi=hard -mfpu=fpv5-d16 -o "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.elf" "T:\\TEMP\\arduino_build_570794\\sketch\\KH_16MBpsramTst.ino.cpp.o" "T:\\TEMP\\arduino_build_570794\\libraries\\LittleFS\\LittleFS.cpp.o" "T:\\TEMP\\arduino_build_570794\\libraries\\LittleFS\\LittleFS_NAND.cpp.o" "T:\\TEMP\\arduino_build_570794\\libraries\\LittleFS\\littlefs\\lfs.c.o" "T:\\TEMP\\arduino_build_570794\\libraries\\LittleFS\\littlefs\\lfs_util.c.o" "T:\\TEMP\\arduino_build_570794\\libraries\\SPI\\SPI.cpp.o" "T:\\TEMP\\arduino_build_570794/..\\arduino_cache_54489\\core\\core_fbaf3cc09a6812b07e339698e1d55848.a" "-LT:\\TEMP\\arduino_build_570794" -larm_cortexM7lfsp_math -lm -lstdc++
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -j .eeprom --set-section-flags=.eeprom=alloc,load --no-change-warnings --change-section-lma .eeprom=0 "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.elf" "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.eep"
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objcopy" -O ihex -R .eeprom "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.elf" "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.hex"
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/teensy_secure" encrypthex TEENSY41 "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.hex"
encrypting 104448 bytes to T:\TEMP\arduino_build_570794/KH_16MBpsramTst.ino.ehex
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/teensy_post_compile" -file=KH_16MBpsramTst.ino "-path=T:\\TEMP\\arduino_build_570794" "-tools=T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/" -board=TEENSY41
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/stdout_redirect" "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.sym" "T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -t -C "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.elf"
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/teensy_size" "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.elf"
Memory Usage on Teensy 4.1:
FLASH: code:94432, data:9936, headers:8268 free for files:8013828
RAM1: variables:9440, code:88696, padding:9608 free for local variables:416544
RAM2: variables:12416 free for malloc/new:511872
"T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/stdout_redirect" "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.lst" "T:\\T_Drive\\arduino-1.8.19\\hardware\\teensy/../tools/arm/bin/arm-none-eabi-objdump" -d -S -C "T:\\TEMP\\arduino_build_570794/KH_16MBpsramTst.ino.elf"
Using library LittleFS at version 1.0.0 in folder: T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\LittleFS
Using library SPI at version 1.0 in folder: T:\T_Drive\arduino-1.8.19\hardware\teensy\avr\libraries\SPI
