reading this right? :: Possible the LTO code order/timing is different, and one way works on timing and the other does not? Either way it is on a hairy edge for the Flash chip?Is it possible the flash chips aren't happy with the changes to CSINTERVAL/TCSH/TCSS for port 2 (causing intermittent failures when accessed in a particular manner) ?
#if defined(DMA_DCHPRI_DPA)). If you could persuade @jmarsh to create a PR, and pull it in, that would be ideal.
useFileSystemIndexFileStore(MTPStorage::INDEX_STORE_MEM_FILE)
send_StoreRemovedEvent(handle) followed by storage()->removeFilesystem(handle) but now both of those functions are private/removed.Any estimate when 1.60 will be released?
int x,y,z;
while (!Serial)
x=2;
y=0;
while(x>y){
y=x; //keep the last value
x*=2;
Serial.printf("\nwhile(x>y) correctly exits after multiplies when %d < %d\n", x, y);
y=2*y-5; //make it less than double
x=y+1;
z=5;
Serial.println("\nbut only works after add on T4.1 if optimize is set to fast.");
Serial.printf("x=%d, y=%d z=%d\n",x,y,z);
while(x>0 && z>0){
y=x;
x+=1;
z-=1;
Serial.printf("x=%d, y=%d z=%d",x,y,z);
if(z==1){
Serial.println("<-should have exited here");
}else{
while(x>y) correctly exits after multiplies when -2147483648 < 1073741824
x=2147483644, y=2147483643 z=5
x=2147483645, y=2147483644 z=4
x=2147483646, y=2147483645 z=3
x=2147483647, y=2147483646 z=2
x=-2147483648, y=2147483647 z=1<-should have exited here
x=-2147483647, y=-2147483648 z=0
I've put in PR#790 which I believe makes the conditional compilation adapt in a manner consistent with the other interface types (MIDI, Serial, keyboard etc.). Briefly tested, seems to work OK.If you are using existing interfaces (making your own device with
a different set of interfaces) the code in all other files should
automatically adapt to the new endpoints you specify here.
I just want to make sure this gets on the radar for the 1.60 release.LittleFS unused-but-set warnings fixed with this PR:
LittleFS_NAND: Fix some unused-but-set warnings by ssilverman · Pull Request #64 · PaulStoffregen/LittleFS
Contribute to PaulStoffregen/LittleFS development by creating an account on GitHub.github.com
Note that while the PR solves the warnings, I'm not certain what the intent for the LATER macro is, so it might not be strictly correct. I'll leave that up to @PaulStoffregen.
