Teensyduino ide installation issue
Hi
I just installed teensyduino, only for it to start with error messages and rest of gui invisible. GUI elements only became visible when the mouse went over them.
Initial startup of teensduino:
Error Messages (screenshot taken after mouse on all gui elements to make them visible)
Prior to installing the teensyduino, the arduio ide started without these errors and all gui visible.
System Details:
Teensyduino version: 1.45
Arduino IDE version: 1.8.8
OS: Windows 10 home
Arduino Location: D:\additional apps\arduino-1.8.8
Arduino has portable folder setup see: https://www.arduino.cc/en/Guide/PortableIDE
Teensyduino was installed with WIFI off and antivirus turned off
Teensy LC has not yet been inserted due to ide errors​
Just tried arduino's standard installer (non-portable) followed by the teensyduino installer. Although the gui now worked, the same error messages turned up.
Error messages screenshot:
Full error messages:
Exception in thread "AWT-EventQueue-0" java.lang.NullPointerException
	at processing.app.EditorLineStatus.setSerialPort(EditorLineStatus.java:136)
	at processing.app.EditorLineStatus.paintComponent(EditorLineStatus.java:101)
	at javax.swing.JComponent.paint(JComponent.java:1056)
	at javax.swing.JComponent.paintChildren(JComponent.java:889)
	at javax.swing.JComponent.paint(JComponent.java:1065)
	at javax.swing.JSplitPane.paintChildren(JSplitPane.java:1047)
	at javax.swing.JLayeredPane.paint(JLayeredPane.java:586)
	at javax.swing.JComponent.paintToOffscreen(JComponent.java:5217)
	at javax.swing.RepaintManager$PaintManager.paintDoubleBuffered(RepaintManager.java:1579)
	at javax.swing.RepaintManager$PaintManager.paint(RepaintManager.java:1502)
	at javax.swing.RepaintManager.paint(RepaintManager.java:1272)
	at javax.swing.JComponent.paint(JComponent.java:1042)
	at java.awt.GraphicsCallback$PaintCallback.run(GraphicsCallback.java:39)
	at sun.awt.SunGraphicsCallback.runOneComponent(SunGraphicsCallback.java:79)
	at sun.awt.SunGraphicsCallback.runComponents(SunGraphicsCallback.java:116)
	at java.awt.Container.paint(Container.java:1978)
	at java.awt.Window.paint(Window.java:3906)
	at javax.swing.RepaintManager$4.run(RepaintManager.java:842)
	at javax.swing.RepaintManager$4.run(RepaintManager.java:814)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:74)
	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:814)
	at javax.swing.RepaintManager.paintDirtyRegions(RepaintManager.java:789)
	at javax.swing.RepaintManager.prePaintDirtyRegions(RepaintManager.java:738)
	at javax.swing.RepaintManager.access$1200(RepaintManager.java:64)
	at javax.swing.RepaintManager$ProcessingRunnable.run(RepaintManager.java:1732)
	at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:311)
	at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
	at java.awt.EventQueue.access$500(EventQueue.java:97)
	at java.awt.EventQueue$3.run(EventQueue.java:709)
	at java.awt.EventQueue$3.run(EventQueue.java:703)
	at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
	at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:205)
	at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
	at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
	at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
	at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Ok, I believe I see what's causing the NullPointerException.
Here's an attempt to fix it. To install this, extract the ZIP file to get pde.jar. Then copy it to the "lib" folder inside Arduino, replacing the pde.jar that's already present.
Please let me know if this solve the error?
  • pde.zip
Wanted to say that I also had this issue on a Windows 10 machine, Arduino version 1.8.8 installed as the Windows exe rather than as a Windows 10 App.
This fix also worked for me.
It worked for me too. It was a long and frustrating path to here because I started with the Win10 app before I found the app version of Arduino was not supported. Then I had to find this thread.
I for one think that a big RED note in the Teensyduino download page would be in order that first cautioned about the app version of Arduino and then pde.jar fix.
Fred
I just got the same issue and patching lib/pde.jar fixed it.
Any chance the Teensyduino installer could be updated to use the right lib/pde.jar? Thanks!
Ditto here. Installed Arduino IDE on a fresh Win 10 install, and then Teensyduino, and ran into the same issue. The new pde.jar fixed it.
