Tennsy 3.2 doesn't read CAN messages.
Black_Stork
I am trying to send messages from one teensy to another. I know that teensy which sends messages works correctly since my Arduino with seeedstudio CAN BUS shield reads it perfectly fine.
Both microcontrollesr use TI SN65HVD230 tranceiver.
They are both connected the same way, between CAN lines there is 60 Ohm resistance, so I assume that there is something wrong with my receiver code and not in wiring.
Arduino library is included because i use PlatformIO on Windows 10. I use Collink80's version of FlexCAN library.
RECEIVER(doesn't work):
#include <FlexCAN.h>
#include <kinetis_flexcan.h>
#include <Arduino.h>
const int baudRate = 500000;   // baud Rate
const int ledPin = 13;        // embedded led
const int delayTime = 100;   // 1/10 second
FlexCAN myCAN(baudRate);
static CAN_message_t msgReceived;  // wiadomosc gdy wcisniety
  pinMode(ledPin,OUTPUT);
  digitalWrite(ledPin, HIGH);
  myCAN.begin(baudRate);
  delay(1500);
  digitalWrite(ledPin, LOW);
  Serial.println("CAN Receiver Initialized");
    myCAN.read(msgReceived);
    while(myCAN.read(msgReceived))
    // toggle LEDs
        digitalWrite(ledPin, !digitalRead(ledPin));
        Serial.print("Receiving: ");
        for(int i=0; i<msgReceived.len; i++)
            Serial.print(msgReceived.buf[i]); Serial.print(" ");
        Serial.println("");
SENDER(works fine; sends 2 different messeges depending on button position):
const int baudRate = 500000;   // baudRate
const int delayTime = 500;   //
const int button = 8;
static CAN_message_t msgButton_P;  // when pressed
static CAN_message_t msgButton_N;  // when NOT pressed
  pinMode(button, INPUT_PULLUP);
  delay(1500);
  Serial.println("CAN Tranceiver Initialized");
  //P
  msgButton_P.ext = 0;       // 11 bit
  msgButton_P.id = 0xD0;     // adress msgButton_P
  msgButton_P.len = 8;        // length
  msgButton_P.buf[0] = 0x86;  // kolejne bity
  msgButton_P.buf[1] = 0x00;
  msgButton_P.buf[2] = 0x00;
  msgButton_P.buf[3] = 0x00;
  msgButton_P.buf[4] = 0x00;
  msgButton_P.buf[5] = 0x00;
  msgButton_P.buf[6] = 0x00;
  msgButton_P.buf[7] = 0x00;
  //N
  msgButton_N.ext = 0;       // 11 nit
  msgButton_N.id = 0xD0;     // adresa msgButton_N
  msgButton_N.len = 8;        // length
  msgButton_N.buf[0] = 0x06;  !
  msgButton_N.buf[1] = 0x00;
  msgButton_N.buf[2] = 0x00;
  msgButton_N.buf[3] = 0x00;
  msgButton_N.buf[5] = 0x00;
  msgButton_N.buf[6] = 0x00;
  msgButton_N.buf[7] = 0x00;
    delay(delayTime / 2);
    Serial.print("Sending every ");
    Serial.println(delayTime);
    if (digitalRead(button) == LOW)        // if pressed
        Serial.print(msgButton_P.id);     // print
        Serial.print(' ');
        Serial.println(msgButton_P.len);
        for (int i = 0 ; i < msgButton_P.len ; i++)
            Serial.print(msgButton_P.buf[i]);
            Serial.print(' ');
        Serial.print("\n");
        myCAN.write(msgButton_P);         //send msgButton_P
        Serial.print(msgButton_N.id);
        Serial.print(' ');
        Serial.println(msgButton_N.len);
        for (int i = 0 ; i <msgButton_N.len ; i++)
            Serial.print(msgButton_N.buf[i]);
            Serial.print(' ');
        Serial.print("\n");
        myCAN.write(msgButton_N);         // msgButton_N
Thank you very much tni, it worked!
As far as i understand the custom name is only for this line: "FlexCAN myCAN(baudRate);" and all comands regarding sending and receiving messages is executed by Can0 object or Can1 in case of using Teensy3.5?
No, don't ever declare your own instance of FlexCAN (or be prepared for things randomly not working). The constructor doesn't even take the baud rate as parameter.
You specify the baud rate when you call begin(), e.g. "Can0.begin(500000);" uses 500'000 baud.
Given how different and incompatible the 'collin80' version of FlexCAN is to the original, it should have been renamed.
