This is our touchscreen painting example for the Adafruit ILI9341
captouch shield
----> http://www.adafruit.com/products/1947
Check out the links above for our tutorials and wiring diagrams
products from Adafruit!
MIT license, all text above must be included in any redistribution
#include <SPI.h> // this is needed for display
#include <ILI9488_t3.h>
#include <Wire.h> // this is needed for FT6206
#include <Adafruit_FT6206.h>
// The FT6206 uses hardware I2C (SCL/SDA)
Adafruit_FT6206 ctp = Adafruit_FT6206();
// The display also uses hardware SPI, plus #9 & #10
#define TFT_RST 8
#define TFT_DC 9
#define TFT_CS 10
#define TFT_BL 7
ILI9488_t3 tft = ILI9488_t3(&SPI, TFT_CS, TFT_DC, TFT_RST);
// Size of the color selection boxes and the paintbrush size
#define BOXSIZE 40
#define PENRADIUS 3
int oldcolor, currentcolor;
void setup(void) {
while (!Serial && millis() < 5000); // used for leonardo debugging
Serial.println(F("Cap Touch Paint!"));
tft.begin();
if (! ctp.begin(40)) { // pass in 'sensitivity' coefficient
Serial.println("Couldn't start FT6206 touchscreen controller");
while (1);
Serial.println("Capacitive touchscreen started");
tft.fillScreen(ILI9488_BLACK);
// make the color selection boxes
tft.fillRect(0, 0, BOXSIZE, BOXSIZE, ILI9488_RED);
tft.fillRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9488_YELLOW);
tft.fillRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9488_GREEN);
tft.fillRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9488_CYAN);
tft.fillRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9488_BLUE);
tft.fillRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9488_MAGENTA);
// select the current color 'red'
tft.drawRect(0, 0, BOXSIZE, BOXSIZE, ILI9488_WHITE);
currentcolor = ILI9488_RED;
// Wait for a touch
if (! ctp.touched()) {
return;
// Retrieve a point
TS_Point p = ctp.getPoint();
// Print out raw data from screen touch controller
Serial.print("X = "); Serial.print(p.x);
Serial.print("\tY = "); Serial.print(p.y);
Serial.print(" -> ");
// Maybe flip it around to match the screen.
// p.x = map(p.x, 0, 240, 240, 0);
// p.y = map(p.y, 0, 320, 320, 0);
// Print out the remapped (rotated) coordinates
Serial.print("("); Serial.print(p.x);
Serial.print(", "); Serial.print(p.y);
Serial.println(")");
if (p.y < BOXSIZE) {
oldcolor = currentcolor;
if (p.x < BOXSIZE) {
} else if (p.x < BOXSIZE*2) {
currentcolor = ILI9488_YELLOW;
tft.drawRect(BOXSIZE, 0, BOXSIZE, BOXSIZE, ILI9488_WHITE);
} else if (p.x < BOXSIZE*3) {
currentcolor = ILI9488_GREEN;
tft.drawRect(BOXSIZE*2, 0, BOXSIZE, BOXSIZE, ILI9488_WHITE);
} else if (p.x < BOXSIZE*4) {
currentcolor = ILI9488_CYAN;
tft.drawRect(BOXSIZE*3, 0, BOXSIZE, BOXSIZE, ILI9488_WHITE);
} else if (p.x < BOXSIZE*5) {
currentcolor = ILI9488_BLUE;
tft.drawRect(BOXSIZE*4, 0, BOXSIZE, BOXSIZE, ILI9488_WHITE);
} else if (p.x <= BOXSIZE*6) {
currentcolor = ILI9488_MAGENTA;
tft.drawRect(BOXSIZE*5, 0, BOXSIZE, BOXSIZE, ILI9488_WHITE);
if (oldcolor != currentcolor) {
if (oldcolor == ILI9488_RED)
if (oldcolor == ILI9488_YELLOW)
if (oldcolor == ILI9488_GREEN)
if (oldcolor == ILI9488_CYAN)
if (oldcolor == ILI9488_BLUE)
if (oldcolor == ILI9488_MAGENTA)
if (((p.y-PENRADIUS) > BOXSIZE) && ((p.y+PENRADIUS) < tft.height())) {
tft.fillCircle(p.x, p.y, PENRADIUS, currentcolor);
