This Should Never Happen
wwatson
@Paul - Was compiling the following sketch on the Dev Board 5 with Arduino 1.8.19 and TD1.60B1. Also using @KurtE variants and FlexIO libraries. OS is Ubuntu 22.04. The compile failed with an error message "This should never happen" and to report it to PJRC.:
teensy_size: Memory Usage on Teensy MicroMod:
teensy_size:   FLASH: code:64836, data:497080, headers:8448   free for files:15944708
/home/wwatson/.arduino15/packages/teensy/tools/teensy-tools/1.59.0/stdout_redirect /tmp/arduino_build_843155/testing.ino.lst /home/wwatson/.arduino15/packages/teensy/tools/teensy-compile/11.3.1/arm/bin/arm-none-eabi-objdump -d -S -C /tmp/arduino_build_843155/testing.ino.elf
teensy_size:    RAM1: variables:10720, code:60664, padding:4872   free for local variables:448032
teensy_size:    RAM2: variables:12416  free for malloc/new:511872
Using library TeensyRA8876-8080-main at version 1.0.0 in folder: /home/wwatson/Arduino/libraries/TeensyRA8876-8080-main
Using library TeensyRA8876-GFX-Common-main at version 1.0.0 in folder: /home/wwatson/Arduino/libraries/TeensyRA8876-GFX-Common-main
Using library Wire at version 1.0 in folder: /home/wwatson/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries/Wire
Using library FlexIO_t4 at version 1.0.0 in folder: /home/wwatson/.arduino15/packages/teensy/hardware/avr/1.59.0/libraries/FlexIO_t4
/home/wwatson/Arduino/hardware/teensy-dev/../tools/teensy_post_compile -file=testing.ino -path=/tmp/arduino_build_843155 -tools=/home/wwatson/Arduino/hardware/teensy-dev/../tools -board=TEENSY_DEVBRD5 -reboot -port=/sys/devices/pci0000:00/0000:00:02.1/0000:01:00.0/usb1/1-5 -portlabel=/dev/ttyACM0 Serial -portprotocol=Teensy
Teensy Loader is unable to read your compiled sketch (r)  This error should never happen.  Please report this to paul@pjrc.com.  In Teensy Loader, click Help > Verbose Info, then click Log > Save As and attach the log file to your message.  The log info is essential for any hope of figuring out what went wrong here!
The sketch:
// testing.ino
#include "RA8876_Config_8080.h"
#include <RA8876_t41_p.h>
#include "Teensy41_Cardlike.h"
// RA8876_8080_DC, RA8876_8080_CS and RA8876_8080_RESET are defined in
// src/RA8876_Config_8080.h.
RA8876_t41_p tft = RA8876_t41_p(RA8876_8080_DC,RA8876_8080_CS,RA8876_8080_RESET);
  while (!Serial && millis() < 1000) {} //wait for Serial Monitor
  // Set 8/16bit bus mode. Default is 8bit bus mode.
  tft.setBusWidth(RA8876_8080_BUS_WIDTH); // RA8876_8080_BUS_WIDTH is defined in
  tft.begin(BUS_SPEED); // RA8876_8080_BUS_WIDTH is defined in
                        // src/RA8876_Config_8080.h. Default is 20MHz.
  tft.fillScreen(BLACK);
  Serial.println("Test transfer speed difference between 8Bit bus and 16Bit bus\n");
  Serial.print("Bus width is ");
  Serial.println(RA8876_8080_BUS_WIDTH);
  Serial.print("Bus speed is ");
  Serial.println(BUS_SPEED);
  elapsedMillis em = 0;
//  tft.writeRect(10, 10 , 575, 424, teensy41_Cardlike);
//  tft.pushPixels16bitDMA(teensy41_Cardlike, 10, 10 , 575, 424);
  tft.pushPixels16bitAsync(teensy41_Cardlike, 10, 10 , 575, 424);
  Serial.print("Rendering 487600 bytes took ");
  Serial.print(em,DEC);
  Serial.println("ms");
The verbose error log dump is to large to post as text so it is attached as a zip file. This only happened once. Could not duplicate failure again...
  • Error_Log_txt.zip
