Toggle TO momentary button press code:
teknogeek1300
Googled around a lot and only found the opposite, turning temporary button presses into toggles.
This code simulates a button press for a desired amount of time when the toggle switch is flipped on, then presses again when the toggle is flipped off.
The purpose of this is for games that do not support a press/hold button feature.
char switch1 = 0; //name of fist switch
char switch2 = 0; //name of second switch
  pinMode(13, OUTPUT); //onboard LED to confirm toggles are working
  pinMode(8, INPUT_PULLUP); //pin first toggle is connected to
  pinMode(7, INPUT_PULLUP); //pin second toggle is connected to
  if (digitalRead(8) == LOW && (switch1 == 0)){
     digitalWrite(13, HIGH);
     delay(90); // how long the button press will occur
     digitalWrite(13, LOW);
     switch1 = 1; // changes the switches char so the switch will not automatically loop
  if (digitalRead(8) == HIGH && (switch1 == 1)){
     switch1 = 0;
  if (digitalRead(7) == LOW && (switch2 == 0)){
     switch2 = 1; // changes the switches char so the switch will not automatically loop
  if (digitalRead(7) == HIGH && (switch2 == 1)){
     switch2 = 0;
