Hi, I am using the following example to experiment with transposing incoming MIDI notes with a Teensy LC, using a hardware MIDI circuit:
The above sketch works as expected where the incoming MIDI note C3 (48) plays an additional C2 (36) . So the note is effectively "doubled" C2/C3.
What I am trying to accomplish is have the sketch play only the lower octave and struggling to come up with a way to "filter" out the base incoming note and have only the lower octave play...
Would I need to do something to the effect of "zero-ing" out the velocity of the base note (C3 for example) or is there another suggested approach?
Still learning the basics here so any help or hints to a solution is greatly appreciated.
//Arduino for Musicians
//Listing 5.8: MIDI Library input callback
#include <MIDI.h>
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI);
const byte transposition = -12; //transpose all input down 12 semitones
//Define the callback functions. Parameters and return value must match the
//values listed in the MIDI library:
void myHandleNoteOn(byte channel, byte note, byte velocity)
MIDI.sendNoteOn(note + transposition, velocity, channel);
void myHandleNoteOff(byte channel, byte note, byte velocity)
MIDI.sendNoteOff(note + transposition, velocity, channel);
//Connect the callback functions to the MIDI library
MIDI.setHandleNoteOn(myHandleNoteOn);
MIDI.setHandleNoteOff(myHandleNoteOff);
MIDI.begin(MIDI_CHANNEL_OMNI); // Listen on all channels
//Call MIDI.read(). MIDI class will automatically call callback
//functions as needed.
MIDI.read();
