balthasar
I'm currently facing the problem that my teensy 4.1 is not recognized by neither the Arduino IDE (v2.1.1) nor the teensyloader (v1.59). It has to be something with the teensy itself since the same setup (cable, IDE version, etc...) works totally fine for my teensy 4.0. I have used the teensy before so there is no default blinking state to check wether the teensy has power. I had to desolder all the pins since they were the wrong type for my current project and I used a special desoldering iron. With this I'm afraid the teensy might have gotten a little too hot and overheated. I tried checking with a multimeter when plugged in and the Vin pin shows 5V and the 3.3v pin shows 0 volts. This is probably a bad sign but is there a way to confirm if my teensy is dead with the multimeter for example or if there is something i could still do to fix this issue?
I'm happy to answer further questions in the responses
