I have been reading about Ultrasonic Leak detection that apparently generates noise at around 40Khz.
My aim is to (Blower door) pressure test a Passive House I wish to build. Apparently the 50Kpa (about 50mm water
offset in Bowden tube) is enough to cause Ultrasonic noise at leaks. To achieve PassivHaus certification, the leaks
need to cause less than 0.6 Ach (Air changes per hour), & the smaller the house the harder to get it leak free.
My project is 105 sq M, so fairly small. What I want is a detector I can walk around with looking for leaks.
My first check will be smoke to find the big leaks, but one needs something more sensitive for the tiny leaks.
Has anyone tried the TeensyBat for such an application? As a retired Electronics tech, the build will be straightforward.
btw, in Australia, the
