Unable to access file system on sd card.
Handuer
I am using the teensy audio adapter and when i run the SD card test it reads the card type as SD fine, but then stops because it can't access the file system. Anyone have an idea what could be causing this?
I have tried two different SD cards, one of which i am sure of being genuine. I have also reformatted both with the windows SD card formatter.
we need more information:
which teensy (2 or 3) ?
which SD software ?
which SD card (size)?
if SD card size >32 GB, standard formatting is exFAT which is not supported by common teensy SD software
It's Teensy 3.2
I am not quite sure what you mean by software, it's the one in windows 10 that is available if you right click a SD card in file explorer.
The sizes are 16gb and 2gb .
It's the one that comes with Teensyduino under Audio>Hardware Testing>SdCardTest
// SD Card Test
// Check if the SD card on the Audio Shield is working,
// and perform some simple speed measurements to gauge
// its ability to play 1, 2, 3 and 4 WAV files at a time.
// Requires the audio shield:
//   http://www.pjrc.com/store/teensy3_audio.html
// Data files to put on your SD card can be downloaded here:
//   http://www.pjrc.com/teensy/td_libs_AudioDataFiles.html
// This example code is in the public domain.
  Sd2Card card;
  SdVolume volume;
  File f1, f2, f3, f4;
  char buffer[512];
  boolean status;
  unsigned long usec, usecMax;
  elapsedMicros usecTotal, usecSingle;
  int i, type;
  float size;
  // wait for the Arduino Serial Monitor to open
  while (!Serial) ;
  delay(50);
  // Configure SPI for the audio shield pins
  SPI.setMOSI(7);  // Audio shield has MOSI on pin 7
  SPI.setSCK(14);  // Audio shield has SCK on pin 14
  Serial.println("SD Card Test");
  Serial.println("------------");
  // First, detect the card
  status = card.init(10); // Audio shield has SD card SD on pin 10
  if (status) {
    Serial.println("SD card is connected :-)");
    Serial.println("SD card is not connected or unusable :-(");
    return;
  type = card.type();
  if (type == SD_CARD_TYPE_SD1 || type == SD_CARD_TYPE_SD2) {
    Serial.println("Card type is SD");
  } else if (type == SD_CARD_TYPE_SDHC) {
    Serial.println("Card type is SDHC");
    Serial.println("Card is an unknown type (maybe SDXC?)");
  // Then look at the file system and print its capacity
  status = volume.init(card);
  if (!status) {
    Serial.println("Unable to access the filesystem on this card. :-(");
    return;
  size = volume.blocksPerCluster() * volume.clusterCount();
  size = size * (512.0 / 1e6); // convert blocks to millions of bytes
  Serial.print("File system space is ");
  Serial.print(size);
  Serial.println(" Mbytes.");
  // Now open the SD card normally
  status = SD.begin(10); // Audio shield has SD card CS on pin 10
  if (status) {
    Serial.println("SD library is able to access the filesystem");
    Serial.println("SD library can not access the filesystem!");
    Serial.println("Please report this problem, with the make & model of your SD card.");
    Serial.println("  http://forum.pjrc.com/forums/4-Suggestions-amp-Bug-Reports");
  // Open the 4 sample files.  Hopefully they're on the card
  f1 = SD.open("SDTEST1.WAV");
  f2 = SD.open("SDTEST2.WAV");
  f3 = SD.open("SDTEST3.WAV");
  f4 = SD.open("SDTEST4.WAV");
  // Speed test reading a single file
  if (f1) {
    Serial.println("Reading SDTEST1.WAV:");
    if (f1.size() >= 514048) {
      usecMax = 0;
      usecTotal = 0;
      for (i=0; i < 1000; i++) {
        usecSingle = 0;
        f1.read(buffer, 512);
        usec = usecSingle;
        if (usec > usecMax) usecMax = usec;
      reportSpeed(1, 1000, usecTotal, usecMax);
      Serial.println("SDTEST1.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST1.WAV on this card");
    return;
  // Speed test reading two files
  if (f2) {
    Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV:");
    if (f2.size() >= 514048) {
      f1.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        f2.read(buffer, 512);
        usec = usecSingle;
      reportSpeed(2, 1000, usecTotal, usecMax);
      Serial.println("Reading SDTEST1.WAV & SDTEST2.WAV staggered:");
      f1.seek(0);
      f2.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        usec = usecSingle;
      Serial.println("SDTEST2.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST2.WAV on this card");
    return;
  // Speed test reading three files
  if (f3) {
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV:");
    if (f3.size() >= 514048) {
      f1.seek(0);
      f2.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        f3.read(buffer, 512);
        usec = usecSingle;
      reportSpeed(3, 1000, usecTotal, usecMax);
      Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV staggered:");
      f1.seek(0);
      f2.seek(0);
      f3.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        usec = usecSingle;
      Serial.println("SDTEST3.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST3.WAV on this card");
    return;
  // Speed test reading four files
  if (f4) {
    Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV:");
    if (f4.size() >= 514048) {
      f1.seek(0);
      f2.seek(0);
      f3.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        f4.read(buffer, 512);
        usec = usecSingle;
      reportSpeed(4, 1000, usecTotal, usecMax);
      Serial.println("Reading SDTEST1.WAV, SDTEST2.WAV, SDTEST3.WAV, SDTEST4.WAV staggered:");
      f1.seek(0);
      f2.seek(0);
      f3.seek(0);
      f4.seek(0);
      usecMax = 0;
      usecTotal = 0;
        usecSingle = 0;
        usec = usecSingle;
      Serial.println("SDTEST4.WAV is too small for speed testing");
    Serial.println("Unable to find SDTEST4.WAV on this card");
    return;
unsigned long maximum(unsigned long a, unsigned long b,
  unsigned long c, unsigned long d)
  if (b > a) a = b;
  if (c > a) a = c;
  if (d > a) a = d;
  return a;
void reportSpeed(unsigned int numFiles, unsigned long blockCount, unsigned long usecTotal, unsigned long usecMax)
  float bytesPerSecond = (float)(blockCount * 512 * numFiles) / usecTotal;
  Serial.print("  Overall speed = ");
  Serial.print(bytesPerSecond);
  Serial.println(" Mbyte/sec");
  Serial.print("  Worst block time = ");
  Serial.print((float)usecMax / 1000.0);
  Serial.println(" ms");
  Serial.print("    ");
  Serial.print( (float)usecMax / 29.01333);
  Serial.println("% of audio frame time");
void loop(void) {
  // do nothing after the test
That is unusual..
Is the audio board soldered to the teensy ?
I'm asking, becuase sometimes user prefer other ways...which do not work :)
