Unable to Install USB Serial driver - Unable to initialize serial port
blackrockcity
Im running windows 7 using a teensy 2++ with arduino IDE and https://github.com/neophob/PixelController v 1.4 software. I have the sketch loaded on the teensy and its going through init and awating communication but i noticed during the teensy install process it could not install the usb serial driver and it will not allow me to giving me error Windows Error E000022F = ""
When trying to start pixelcontroller it states in the logs the serial port fail to initialize...
please help.
I also tried installing manually with this link..forum.pjrc.com/attachment.php?attachmentid=567&d=1371046506‎ still will not let me install driver... please advise???
For Windows 8, you need to reboot and use F8 at startup to disable the driver signing enforcement.
More details here:
http://www.pjrc.com/teensy/windows8.txt
Yep figured this out shortly before you replied.. The only thing im not able to get to work now is chain beyond 300 pixels. Beyond 300 pixels its just a static color.. Im ordering another teensy to run another chain individually (running 512 leds total). Micheal the developer suggested tpm2.net but im not sure how to use that firmware with the teensy. So i think ill just order another teensy tomorrow. If you think i can run the whole 512 led on 1 chain with the teensy with the pixelcontroller software please advise.
