uNavINS.cpp
Original Author:
Adhika Lie
2012-10-08
University of Minnesota
Aerospace Engineering and Mechanics
Copyright 2011 Regents of the University of Minnesota. All rights reserved.
Updated to be a class, use Eigen, and compile as an Arduino library.
Added methods to get gyro and accel bias. Added initialization to
estimated angles rather than assuming IMU is level. Added method to get psi,
rather than just heading, and ground track.
Brian R Taylor
brian.taylor@bolderflight.com
2017-12-20
Bolder Flight Systems
Copyright 2017 Bolder Flight Systems
Permission is hereby granted, free of charge, to any person obtaining a copy of this software
and associated documentation files (the "Software"), to deal in the Software without restriction,
including without limitation the rights to use, copy, modify, merge, publish, distribute,
sublicense, and/or sell copies of the Software, and to permit persons to whom the Software is
furnished to do so, subject to the following conditions:
The above copyright notice and this permission notice shall be included in all copies or
substantial portions of the Software.
THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, INCLUDING
BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY, FITNESS FOR A PARTICULAR PURPOSE AND
NONINFRINGEMENT. IN NO EVENT SHALL THE AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM,
DAMAGES OR OTHER LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE SOFTWARE.
#include "uNavINS.h"
void uNavINS::update(unsigned long TOW,double vn,double ve,double vd,double lat,double lon,double alt,float p,float q,float r,float ax,float ay,float az,float hx,float hy, float hz) {
if (!initialized) {
// initial attitude and heading
theta = asinf(ax/G);
phi = asinf(-ay/(G*cosf(theta)));
// magnetic heading correction due to roll and pitch angle
Bxc = hx*cosf(theta) + (hy*sinf(phi) + hz*cosf(phi))*sinf(theta);
Byc = hy*cosf(phi) - hz*sinf(phi);
// finding initial heading
if (-Byc > 0) {
psi = M_PI/2.0f - atanf(Bxc/-Byc);
psi= 3.0f*M_PI/2.0f - atanf(Bxc/-Byc);
psi = constrainAngle180(psi);
psi_initial = psi;
// euler to quaternion
quat(0) = cosf(psi/2.0f)*cosf(theta/2.0f)*cosf(phi/2.0f) + sinf(psi/2.0f)*sinf(theta/2.0f)*sinf(phi/2.0f);
quat(1) = cosf(psi/2.0f)*cosf(theta/2.0f)*sinf(phi/2.0f) - sinf(psi/2.0f)*sinf(theta/2.0f)*cosf(phi/2.0f);
quat(2) = cosf(psi/2.0f)*sinf(theta/2.0f)*cosf(phi/2.0f) + sinf(psi/2.0f)*cosf(theta/2.0f)*sinf(phi/2.0f);
quat(3) = sinf(psi/2.0f)*cosf(theta/2.0f)*cosf(phi/2.0f) - cosf(psi/2.0f)*sinf(theta/2.0f)*sinf(phi/2.0f);
// Assemble the matrices
// ... gravity
grav(2,0) = G;
// ... H
H.block(0,0,5,5) = Eigen::Matrix<float,5,5>::Identity();
// // ... Rw
// Rw.block(0,0,3,3) = powf(SIG_W_A,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// Rw.block(3,3,3,3) = powf(SIG_W_G,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// Rw.block(6,6,3,3) = 2.0f*powf(SIG_A_D,2.0f)/TAU_A*Eigen::Matrix<float,3,3>::Identity();
// Rw.block(9,9,3,3) = 2.0f*powf(SIG_G_D,2.0f)/TAU_G*Eigen::Matrix<float,3,3>::Identity();
// // ... P
// P.block(0,0,3,3) = powf(P_P_INIT,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// P.block(3,3,3,3) = powf(P_V_INIT,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// P.block(6,6,2,2) = powf(P_A_INIT,2.0f)*Eigen::Matrix<float,2,2>::Identity();
// P(8,8) = powf(P_HDG_INIT,2.0f);
// P.block(9,9,3,3) = powf(P_AB_INIT,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// P.block(12,12,3,3) = powf(P_GB_INIT,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// // ... R
// R.block(0,0,2,2) = powf(SIG_GPS_P_NE,2.0f)*Eigen::Matrix<float,2,2>::Identity();
// R(2,2) = powf(SIG_GPS_P_D,2.0f);
// R.block(3,3,3,3) = powf(SIG_GPS_V,2.0f)*Eigen::Matrix<float,3,3>::Identity();
// ... Rw
Rw(0,0) = SIG_W_A*SIG_W_A; Rw(1,1) = SIG_W_A*SIG_W_A; Rw(2,2) = SIG_W_A*SIG_W_A;
Rw(3,3) = SIG_W_G*SIG_W_G; Rw(4,4) = SIG_W_G*SIG_W_G; Rw(5,5) = SIG_W_G*SIG_W_G;
Rw(6,6) = 2.0f*SIG_A_D*SIG_A_D/TAU_A; Rw(7,7) = 2.0f*SIG_A_D*SIG_A_D/TAU_A; Rw(8,8) = 2.0f*SIG_A_D*SIG_A_D/TAU_A;
Rw(9,9) = 2.0f*SIG_G_D*SIG_G_D/TAU_G; Rw(10,10) = 2.0f*SIG_G_D*SIG_G_D/TAU_G; Rw(11,11) = 2.0f*SIG_G_D*SIG_G_D/TAU_G;
// ... P
P(0,0) = P_P_INIT*P_P_INIT; P(1,1) = P_P_INIT*P_P_INIT; P(2,2) = P_P_INIT*P_P_INIT;
P(3,3) = P_V_INIT*P_V_INIT; P(4,4) = P_V_INIT*P_V_INIT; P(5,5) = P_V_INIT*P_V_INIT;
P(6,6) = P_A_INIT*P_A_INIT; P(7,7) = P_A_INIT*P_A_INIT; P(8,8) = P_HDG_INIT*P_HDG_INIT;
P(9,9) = P_AB_INIT*P_AB_INIT; P(10,10) = P_AB_INIT*P_AB_INIT; P(11,11) = P_AB_INIT*P_AB_INIT;
P(12,12) = P_GB_INIT*P_GB_INIT; P(13,13) = P_GB_INIT*P_GB_INIT; P(14,14) = P_GB_INIT*P_GB_INIT;
// ... R
R(0,0) = SIG_GPS_P_NE*SIG_GPS_P_NE; R(1,1) = SIG_GPS_P_NE*SIG_GPS_P_NE; R(2,2) = SIG_GPS_P_D*SIG_GPS_P_D;
R(3,3) = SIG_GPS_V*SIG_GPS_V; R(4,4) = SIG_GPS_V*SIG_GPS_V; R(5,5) = SIG_GPS_V*SIG_GPS_V;
// .. then initialize states with GPS Data
lat_ins = lat;
lon_ins = lon;
alt_ins = alt;
vn_ins = vn;
ve_ins = ve;
vd_ins = vd;
// specific force
f_b(0,0) = ax;
f_b(1,0) = ay;
f_b(2,0) = az;
/* initialize the time */
_t = 0;
// initialized flag
initialized = true;
// get the change in time
_dt = (float)_t/1e6;
_t = 0;
lla_ins(0,0) = lat_ins;
lla_ins(1,0) = lon_ins;
lla_ins(2,0) = alt_ins;
V_ins(0,0) = vn_ins;
V_ins(1,0) = ve_ins;
V_ins(2,0) = vd_ins;
// AHRS Transformations
C_N2B = quat2dcm(quat);
C_B2N = C_N2B.transpose();
// Attitude Update
dq(0) = 1.0f;
dq(1) = 0.5f*om_ib(0,0)*_dt;
dq(2) = 0.5f*om_ib(1,0)*_dt;
dq(3) = 0.5f*om_ib(2,0)*_dt;
quat = qmult(quat,dq);
quat.normalize();
// Avoid quaternion flips sign
if (quat(0) < 0) {
quat = -1.0f*quat;
// obtain euler angles from quaternion
theta = asinf(-2.0f*(quat(1,0)*quat(3,0)-quat(0,0)*quat(2,0)));
phi = atan2f(2.0f*(quat(0,0)*quat(1,0)+quat(2,0)*quat(3,0)),1.0f-2.0f*(quat(1,0)*quat(1,0)+quat(2,0)*quat(2,0)));
psi = atan2f(2.0f*(quat(1,0)*quat(2,0)+quat(0,0)*quat(3,0)),1.0f-2.0f*(quat(2,0)*quat(2,0)+quat(3,0)*quat(3,0)));
// Velocity Update
dx = C_B2N*f_b + grav;
vn_ins += _dt*dx(0,0);
ve_ins += _dt*dx(1,0);
vd_ins += _dt*dx(2,0);
// Position Update
dxd = llarate(V_ins,lla_ins);
lat_ins += _dt*dxd(0,0);
lon_ins += _dt*dxd(1,0);
alt_ins += _dt*dxd(2,0);
// Jacobian
Fs.setZero();
// ... pos2gs
Fs.block(0,3,3,3) = Eigen::Matrix<float,3,3>::Identity();
// ... gs2pos
Fs(5,2) = -2.0f*G/EARTH_RADIUS;
// ... gs2att
Fs.block(3,6,3,3) = -2.0f*C_B2N*sk(f_b);
// ... gs2acc
Fs.block(3,9,3,3) = -C_B2N;
// ... att2att
Fs.block(6,6,3,3) = -sk(om_ib);
// ... att2gyr
Fs.block(6,12,3,3) = -0.5f*Eigen::Matrix<float,3,3>::Identity();
// ... Accel Markov Bias
Fs.block(9,9,3,3) = -1.0f/TAU_A*Eigen::Matrix<float,3,3>::Identity();
Fs.block(12,12,3,3) = -1.0f/TAU_G*Eigen::Matrix<float,3,3>::Identity();
// State Transition Matrix
PHI = Eigen::Matrix<float,15,15>::Identity()+Fs*_dt;
// Process Noise
Gs.setZero();
Gs.block(3,0,3,3) = -C_B2N;
Gs.block(6,3,3,3) = -0.5f*Eigen::Matrix<float,3,3>::Identity();
Gs.block(9,6,6,6) = Eigen::Matrix<float,6,6>::Identity();
// Discrete Process Noise
Q = PHI*_dt*Gs*Rw*Gs.transpose();
Q = 0.5f*(Q+Q.transpose());
// Covariance Time Update
P = PHI*P*PHI.transpose()+Q;
P = 0.5f*(P+P.transpose());
// Gps measurement update
if ((TOW - previousTOW) > 0) {
previousTOW = TOW;
lla_gps(0,0) = lat;
lla_gps(1,0) = lon;
lla_gps(2,0) = alt;
V_gps(0,0) = vn;
V_gps(1,0) = ve;
V_gps(2,0) = vd;
// Position, converted to NED
pos_ecef_ins = lla2ecef(lla_ins);
pos_ned_ins = ecef2ned(pos_ecef_ins,lla_ins);
pos_ecef_gps = lla2ecef(lla_gps);
pos_ned_gps = ecef2ned(pos_ecef_gps,lla_ins);
// Create measurement Y
y(0,0) = (float)(pos_ned_gps(0,0) - pos_ned_ins(0,0));
y(1,0) = (float)(pos_ned_gps(1,0) - pos_ned_ins(1,0));
y(2,0) = (float)(pos_ned_gps(2,0) - pos_ned_ins(2,0));
y(3,0) = (float)(V_gps(0,0) - V_ins(0,0));
y(4,0) = (float)(V_gps(1,0) - V_ins(1,0));
y(5,0) = (float)(V_gps(2,0) - V_ins(2,0));
// Kalman gain
K = P*H.transpose()*(H*P*H.transpose() + R).inverse();
// Covariance update
P = (Eigen::Matrix<float,15,15>::Identity()-K*H)*P*(Eigen::Matrix<float,15,15>::Identity()-K*H).transpose() + K*R*K.transpose();
// State update
x = K*y;
denom = (1.0 - (ECC2 * pow(sin(lla_ins(0,0)),2.0)));
denom = sqrt(denom*denom);
Re = EARTH_RADIUS / sqrt(denom);
Rn = EARTH_RADIUS*(1.0-ECC2) / denom*sqrt(denom);
alt_ins = alt_ins - x(2,0);
lat_ins = lat_ins + x(0,0) / (Re + alt_ins);
lon_ins = lon_ins + x(1,0) / (Rn + alt_ins) / cos(lat_ins);
vn_ins = vn_ins + x(3,0);
ve_ins = ve_ins + x(4,0);
vd_ins = vd_ins + x(5,0);
// Attitude correction
dq(0,0) = 1.0f;
dq(1,0) = x(6,0);
dq(2,0) = x(7,0);
dq(3,0) = x(8,0);
quat.normalize();
abx = abx + x(9,0);
aby = aby + x(10,0);
abz = abz + x(11,0);
gbx = gbx + x(12,0);
gby = gby + x(13,0);
gbz = gbz + x(14,0);
// Get the new Specific forces and Rotation Rate,
// use in the next time update
f_b(0,0) = ax - abx;
f_b(1,0) = ay - aby;
f_b(2,0) = az - abz;
om_ib(0,0) = p - gbx;
om_ib(1,0) = q - gby;
om_ib(2,0) = r - gbz;
// returns the pitch angle, rad
float uNavINS::getPitch_rad() {
return theta;
// returns the roll angle, rad
float uNavINS::getRoll_rad() {
return phi;
// returns the yaw angle, rad
float uNavINS::getYaw_rad() {
return constrainAngle180(psi-psi_initial);
// returns the heading angle, rad
float uNavINS::getHeading_rad() {
return constrainAngle360(psi);
// returns the INS latitude, rad
double uNavINS::getLatitude_rad() {
return lat_ins;
// returns the INS longitude, rad
double uNavINS::getLongitude_rad() {
return lon_ins;
// returns the INS altitude, m
double uNavINS::getAltitude_m() {
return alt_ins;
// returns the INS north velocity, m/s
double uNavINS::getVelNorth_ms() {
return vn_ins;
// returns the INS east velocity, m/s
double uNavINS::getVelEast_ms() {
return ve_ins;
// returns the INS down velocity, m/s
double uNavINS::getVelDown_ms() {
return vd_ins;
// returns the INS ground track, rad
float uNavINS::getGroundTrack_rad() {
return atan2f((float)ve_ins,(float)vn_ins);
// returns the gyro bias estimate in the x direction, rad/s
float uNavINS::getGyroBiasX_rads() {
return gbx;
// returns the gyro bias estimate in the y direction, rad/s
float uNavINS::getGyroBiasY_rads() {
return gby;
// returns the gyro bias estimate in the z direction, rad/s
float uNavINS::getGyroBiasZ_rads() {
return gbz;
// returns the accel bias estimate in the x direction, m/s/s
float uNavINS::getAccelBiasX_mss() {
return abx;
// returns the accel bias estimate in the y direction, m/s/s
float uNavINS::getAccelBiasY_mss() {
return aby;
// returns the accel bias estimate in the z direction, m/s/s
float uNavINS::getAccelBiasZ_mss() {
return abz;
// This function gives a skew symmetric matrix from a given vector w
Eigen::Matrix<float,3,3> uNavINS::sk(Eigen::Matrix<float,3,1> w) {
Eigen::Matrix<float,3,3> C;
C(0,0) = 0.0f; C(0,1) = -w(2,0); C(0,2) = w(1,0);
C(1,0) = w(2,0); C(1,1) = 0.0f; C(1,2) = -w(0,0);
C(2,0) = -w(1,0); C(2,1) = w(0,0); C(2,2) = 0.0f;
return C;
// This function calculates the rate of change of latitude, longitude, and altitude.
Eigen::Matrix<double,3,1> uNavINS::llarate(Eigen::Matrix<double,3,1> V,Eigen::Matrix<double,3,1> lla) {
double Rew, Rns, denom;
Eigen::Matrix<double,3,1> lla_dot;
denom = (1.0 - (ECC2 * pow(sin(lla(0,0)),2.0)));
Rew = EARTH_RADIUS / sqrt(denom);
Rns = EARTH_RADIUS*(1.0-ECC2) / denom*sqrt(denom);
lla_dot(0,0) = V(0,0)/(Rns + lla(2,0));
lla_dot(1,0) = V(1,0)/((Rew + lla(2,0))*cos(lla(0,0)));
lla_dot(2,0) = -V(2,0);
return lla_dot;
// This function calculates the ECEF Coordinate given the Latitude, Longitude and Altitude.
Eigen::Matrix<double,3,1> uNavINS::lla2ecef(Eigen::Matrix<double,3,1> lla) {
double Rew, denom;
Eigen::Matrix<double,3,1> ecef;
ecef(0,0) = (Rew + lla(2,0)) * cos(lla(0,0)) * cos(lla(1,0));
ecef(1,0) = (Rew + lla(2,0)) * cos(lla(0,0)) * sin(lla(1,0));
ecef(2,0) = (Rew * (1.0 - ECC2) + lla(2,0)) * sin(lla(0,0));
return ecef;
// This function converts a vector in ecef to ned coordinate centered at pos_ref.
Eigen::Matrix<double,3,1> uNavINS::ecef2ned(Eigen::Matrix<double,3,1> ecef,Eigen::Matrix<double,3,1> pos_ref) {
Eigen::Matrix<double,3,1> ned;
ned(2,0)=-cos(pos_ref(0,0))*cos(pos_ref(1,0))*ecef(0,0)-cos(pos_ref(0,0))*sin(pos_ref(1,0))*ecef(1,0)-sin(pos_ref(0,0))*ecef(2,0);
ned(1,0)=-sin(pos_ref(1,0))*ecef(0,0) + cos(pos_ref(1,0))*ecef(1,0);
ned(0,0)=-sin(pos_ref(0,0))*cos(pos_ref(1,0))*ecef(0,0)-sin(pos_ref(0,0))*sin(pos_ref(1,0))*ecef(1,0)+cos(pos_ref(0,0))*ecef(2,0);
return ned;
// quaternion to dcm
Eigen::Matrix<float,3,3> uNavINS::quat2dcm(Eigen::Matrix<float,4,1> q) {
Eigen::Matrix<float,3,3> C_N2B;
C_N2B(0,0) = 2.0f*powf(q(0,0),2.0f)-1.0f + 2.0f*powf(q(1,0),2.0f);
C_N2B(1,1) = 2.0f*powf(q(0,0),2.0f)-1.0f + 2.0f*powf(q(2,0),2.0f);
C_N2B(2,2) = 2.0f*powf(q(0,0),2.0f)-1.0f + 2.0f*powf(q(3,0),2.0f);
C_N2B(0,1) = 2.0f*q(1,0)*q(2,0) + 2.0f*q(0,0)*q(3,0);
C_N2B(0,2) = 2.0f*q(1,0)*q(3,0) - 2.0f*q(0,0)*q(2,0);
C_N2B(1,0) = 2.0f*q(1,0)*q(2,0) - 2.0f*q(0,0)*q(3,0);
C_N2B(1,2) = 2.0f*q(2,0)*q(3,0) + 2.0f*q(0,0)*q(1,0);
C_N2B(2,0) = 2.0f*q(1,0)*q(3,0) + 2.0f*q(0,0)*q(2,0);
C_N2B(2,1) = 2.0f*q(2,0)*q(3,0) - 2.0f*q(0,0)*q(1,0);
return C_N2B;
// quaternion multiplication
Eigen::Matrix<float,4,1> uNavINS::qmult(Eigen::Matrix<float,4,1> p, Eigen::Matrix<float,4,1> q) {
Eigen::Matrix<float,4,1> r;
r(0,0) = p(0,0)*q(0,0) - (p(1,0)*q(1,0) + p(2,0)*q(2,0) + p(3,0)*q(3,0));
r(1,0) = p(0,0)*q(1,0) + q(0,0)*p(1,0) + p(2,0)*q(3,0) - p(3,0)*q(2,0);
r(2,0) = p(0,0)*q(2,0) + q(0,0)*p(2,0) + p(3,0)*q(1,0) - p(1,0)*q(3,0);
r(3,0) = p(0,0)*q(3,0) + q(0,0)*p(3,0) + p(1,0)*q(2,0) - p(2,0)*q(1,0);
return r;
// bound yaw angle between -180 and 180
float uNavINS::constrainAngle180(float dta) {
if(dta > M_PI) dta -= (M_PI*2.0f);
if(dta < -M_PI) dta += (M_PI*2.0f);
return dta;
// bound heading angle between 0 and 360
float uNavINS::constrainAngle360(float dta){
dta = fmod(dta,2.0f*M_PI);
if (dta < 0)
dta += 2.0f*M_PI;
return dta;
