TeensyPhonon
I am trying to do a synchronized emission en reception with 2 teensy 4.1.
The first code, for the "master", which put it's pin 1 to LOW (to trigger the second teensy) and play a signal (chirp[12800], here some dummy sine at 500Hz) stored in memory.
And the second code for the "slave", which wait the signal from the master, record the sound with the microphone and transmit it to a PC.
Unfortunately, I see that the recording begin 30ms too early...
No, it is not due to the propagation of sound, as the microphone and the speaker are really close to each other.
I thought it was due to the audio memory (10 blocks of 128) as 10*128/44100 = 0.029s, but it seems that delaying the recording has no effect...
C:
digitalWrite(1,LOW);
for (i = 0; i < nfor; i++) {
sp_L = Q_out_L.getBuffer();
arm_float_to_q15 (&chirp[partitionsize * i], sp_L, partitionsize);
Q_out_L.playBuffer();
digitalWrite(1,HIGH);
C:
while(digitalRead(0) == HIGH);
while(Q_in_L.available() < 1);
sp_L = Q_in_L.readBuffer();
arm_q15_to_float (sp_L, &float_buffer_L[partitionsize * i], partitionsize);
Q_in_L.freeBuffer();
bool wait = true;
while(wait){
if(Serial.available() > 0){
command = Serial.readString();
if(command.startsWith("ready")){wait = false;}
char conv[4];
for(i=0;i<nc;i++){
memcpy(conv,&float_buffer_L[i],4);
Serial.write(conv,4);
delay(0.5);
