#if defined(HAS_KINETIS_HSRUN) && defined(__MK66FX1M0__) && F_CPU > 120000000
// This reduce the cpu frequency to 120MHz and disable the HSRUN mode (high speed).
// This is copied from mk20dx128.c and added the RAMFUNC attrib to make sure its run from RAM.
RAMFUNC int kinetis_hsrun_disable_RAM(void)
if (SMC_PMSTAT == SMC_PMSTAT_HSRUN) {
// First, reduce the CPU clock speed, but do not change
// the peripheral speed (F_BUS). Serial1 & Serial2 baud
// rates will be impacted, but most other peripherals
// will continue functioning at the same speed.
#if F_CPU == 240000000 && F_BUS == 60000000
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(1, 3, 1, 7); // ok
#elif F_CPU == 240000000 && F_BUS == 80000000
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(2, 2, 2, 8); // ok
#elif F_CPU == 240000000 && F_BUS == 120000000
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(1, 1, 1, 7); // ok
#elif F_CPU == 216000000 && F_BUS == 54000000
#elif F_CPU == 216000000 && F_BUS == 72000000
#elif F_CPU == 216000000 && F_BUS == 108000000
#elif F_CPU == 192000000 && F_BUS == 48000000
#elif F_CPU == 192000000 && F_BUS == 64000000
#elif F_CPU == 192000000 && F_BUS == 96000000
#elif F_CPU == 180000000 && F_BUS == 60000000
#elif F_CPU == 180000000 && F_BUS == 90000000
#elif F_CPU == 168000000 && F_BUS == 56000000
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(2, 2, 2, 5); // ok
#elif F_CPU == 144000000 && F_BUS == 48000000
#elif F_CPU == 144000000 && F_BUS == 72000000
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(1, 1, 1, 5); // ok
#else
return 0;
// Then turn off HSRUN mode
SMC_PMCTRL = SMC_PMCTRL_RUNM(0);
while (SMC_PMSTAT == SMC_PMSTAT_HSRUN); // wait
return 1;
return 0;
RAMFUNC int kinetis_hsrun_enable_RAM(void)
if (SMC_PMSTAT == SMC_PMSTAT_RUN) {
// Turn HSRUN mode on
SMC_PMCTRL = SMC_PMCTRL_RUNM(3);
while (SMC_PMSTAT != SMC_PMSTAT_HSRUN) { ; } // wait
// Then configure clock for full speed
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 3, 0, 7);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 7);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 1, 0, 7);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 3, 0, 6);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 6);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 1, 0, 6);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 5);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 2, 0, 4);
SIM_CLKDIV1 = SIM_CLKDIV1_OUTDIVS(0, 1, 0, 4);
#else
return 0;
return 1;
return 0;
#else // HAS_KINETIS_HSRUN && F_CPU > 120000000
__attribute__((always_inline)) static inline int kinetis_hsrun_disable_RAM(void) { return 0; }
__attribute__((always_inline)) static inline int kinetis_hsrun_enable_RAM(void) { return 0; }
