paulfer
Hi All,
I have just ventured into the TEENSY world, coming from the STM32 world.
I have a sketch, that triggers a HIKVISION camera to send thru a photo.
All works well. What it can do on the TEENSY4.1 so far quite successfully is:
However, I also want to upload the image stored in the DMBuffer via POST and I am unsuccessful. I need guidance.
Here are some of the pertinent declarations
and this section where I read and save the image works fine too:
BUT immediatley after that I try to upload. And no matter how I upload, success is never achieved.
I tried simply posting it, but I understand that the buffer is only 2048 bytes big.
So this does not go:
I tried breaking it up into 2048 byte chunks, but that too, did not work.
Even writing in 200 byte chunks does not work:
I then tried only uploading the first 200 bytes of DMBuffer and that DOES WORK.
So my only question is how do I get to POST a 245KB image to the server?
here is the connectToLogwiz() code:
- Trigger the camera using the NativeEthernet port (ISAPI and DIGEST auth).
- Save the image data to the DMBuffer.
- Save the image to the USB host port.
#include <MD5.h>
#include <USBHost_t36.h>
#include "TimeLib.h"
#include "NativeEthernet.h"
#define DEBUG 1
/*========the ETHERNET stuff================*/
byte mac[] = { 0xDE, 0xAD, 0xBE, 0x1F, 0xFD, 0x1D };
IPAddress ip(192, 168, 1, 177);
IPAddress myDns(192, 168, 1, 1);
EthernetClient clientCAM;
EthernetClient clientLOGWIZ;
char serverCAM[] = "192.168.1.64";
//char serverLOGWIZ[] = "lexxatrexxa.co.za";
byte serverLOGWIZ[] = { 205, 144, 171, 137 };
const uint32_t postingInterval = 15 * 1000; // delay between updates, in milliseconds
uint32_t ctr = 0;
/*========the USB stuff================*/
USBHost myusb;
USBHub hub1(myusb);
USBDrive mbDrive1(myusb);
USBFilesystem usbFS(myusb);
/*===========Variables=============*/
#define BUFSIZE 2048
#define BIGBUFSIZE 400000
#define CHUNKSIZE 2048 //65536 // 64KB xferBuf size
#define REALMSIZE 32
#define NONCESIZE 65
bool fullres = true;
bool unauth = false;
bool isEthProblem = false;
bool isUSBProblem = false;
uint8_t attemptNumber = 1;
char cnonce[] = "MGZmYzRjNjU2YTM4NTUwZTJjOWY1YjdkMDM0Y2E2ODU="; //generic cnonce
char md5ha2[33];
char realm[REALMSIZE];
char nonce[NONCESIZE];
uint8_t buf[BUFSIZE];
uint8_t DMBuffer[BIGBUFSIZE] DMAMEM;
uint8_t xferBuf[CHUNKSIZE]; //FASTRUN
/*========Timers==========*/
uint32_t timer1second = 0;
uint32_t lastConnectionTime = 0;
/*==============2nd Attempt/DIGEST OK====================*/
if (attemptNumber == 2) {
#if DEBUG == 1
Serial.println("2:");
uint32_t x = millis();
/* clear the DMA buffer */
memset(DMBuffer, 0, BIGBUFSIZE);
uint32_t bxctr = 0;
delay(10);
/* create thr USB filename and file */
File testFile;
char filename[50];
memset(filename, 0, 50);
sprintf(filename, "%s_%04i_%02i_%02i_%02i_%02i_%02i_199.lwz", "CA", year(), month(), day(), hour(), minute(), second());
if (usbFS.exists(filename)) usbFS.remove(filename);
testFile = usbFS.open(filename, FILE_WRITE);
/* add the filename to the body of the USB file */
int filenamelength = strlen(filename);
testFile.write(&filename[0], filenamelength);
/* add the filename to the body of the DMABuffer */
for (int i = 0; i < filenamelength; i++) {
DMBuffer[bxctr] = filename[i];
bxctr++;
/* read all the data from the camera in chucks of 2048 */
while (clientCAM.available()) {
memset(buf, 0, BUFSIZE);
int bx = clientCAM.read(buf, BUFSIZE - 1);
for (int i = 0; i < bx; i++) {
DMBuffer[bxctr] = buf[i];
bxctr++;
/* append the data to the USB file if it exists */
if (testFile) {
testFile.write(&buf[0], bx);
delay(1);
testFile.close();
myusb.Task();
if (connectToLogwiz()) {
clientLOGWIZ.println("POST /cw3/cwpost.php HTTP/1.1");
clientLOGWIZ.println("Host: lexxatrexxa.co.za");
clientLOGWIZ.println("Content-Type: application/octet-stream");
clientLOGWIZ.println("Connection: keep-alive");
clientLOGWIZ.print("Content-Length: ");
clientLOGWIZ.println(bxctr);
clientLOGWIZ.println();
for (uint32_t i = 0; i < bxctr; i++) {
clientLOGWIZ.write(DMBuffer[i]);
char tempbuf[200];
for (uint32_t i = 0; i < bxctr; i += 200) {
memset(tempbuf, 0, 200);
strncpy(tempbuf, &DMBuffer[i], 200);
int buflen = strlen(tempbuf);
clientLOGWIZ.write(&DMBuffer[i], buflen);
//clientLOGWIZ.flush();//with or without flush yields same failure
bool connectToLogwiz() {
clientLOGWIZ.stop();
if (clientLOGWIZ.connect(serverLOGWIZ, 80)) {
#if DEBUG == 1
Serial.println("Logwiz OK");
return true;
#if DEBUG == 1
Serial.println("Logwiz FAIL");
return false;
