centralcat
Hello, i'm currently working on a project that uses the USB Host and Ethernet functionality on the Teensy 4.1 to inject / modify mouse input. I've attached an example with the whole ethernet side removed and just acting as a forwarder.
During my testing I've noticed that using my mouse with report rates above 1000hz produced noticeable stutter movements that look like jumps (missed polls?) semi-consistently.
I've modified the descriptors of the Teensy to be a 1:1 match of the mouse and can see a max polling rate of about ~1850hz when set to 2000hz on the mouse, which is pretty inline with what i see on a direct connection to my computer. When the sutters occur there is a drop in reported polling rate of about -500 which then shoots back up shortly after.
Tested on multiple USB ports on my computer, making sure to test CPU and Chipset ports for different behavior. This is also replicated when using my laptop. This behavior also stops happening when using the exact same mouse set to a lower report rate such as 1000hz or 500hz.
Mouse used: Attack Shark R5 Ultra set to 2000hz.
C++:
#include <USBHost_t36.h>
#include <Mouse.h>
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHIDParser hid1(myusb);
USBHIDParser hid2(myusb);
USBHIDParser hid3(myusb);
USBHIDParser hid4(myusb);
USBHIDParser hid5(myusb);
MouseController mouse1(myusb);
myusb.begin();
Mouse.begin();
myusb.Task();
if (!mouse1.available()) return;
int dx = mouse1.getMouseX();
int dy = mouse1.getMouseY();
int8_t wheel = mouse1.getWheel();
uint8_t buttons = mouse1.getButtons();
mouse1.mouseDataClear();
if (dx != 0 || dy != 0 || wheel != 0) {
Mouse.move(dx, dy, wheel);
Mouse.set_buttons(
buttons & MOUSE_LEFT,
buttons & MOUSE_MIDDLE,
buttons & MOUSE_RIGHT,
buttons & MOUSE_BACK,
buttons & MOUSE_FORWARD
//Serial.printf("dx=%d dy=%d wheel=%d btn=0x%02X\n", dx, dy, wheel, buttons);
Connection Status Device connected
Current Configuration 1
Speed High
Device Address 94
Number Of Open Pipes 3
Device Descriptor R5 Ultra Mouse 2.4G
Offset Field Size Value Description
0 bLength 1 12h
1 bDescriptorType 1 01h Device
2 bcdUSB 2 0200h USB Spec 2.0
4 bDeviceClass 1 00h Class info in Ifc Descriptors
5 bDeviceSubClass 1 00h
6 bDeviceProtocol 1 00h
7 bMaxPacketSize0 1 40h 64 bytes
8 idVendor 2 373Eh
10 idProduct 2 0047h
12 bcdDevice 2 0200h 2.00
14 iManufacturer 1 01h "ATTACK SHARK"
15 iProduct 1 02h "R5 Ultra Mouse 2.4G"
16 iSerialNumber 1 03h "REDACTED"
17 bNumConfigurations 1 01h
Configuration Descriptor 1 Bus Powered, 100 mA
0 bLength 1 09h
1 bDescriptorType 1 02h Configuration
2 wTotalLength 2 0054h
4 bNumInterfaces 1 03h
5 bConfigurationValue 1 01h
6 iConfiguration 1 00h
7 bmAttributes 1 A0h Bus Powered, Remote Wakeup
4..0: Reserved ...00000
5: Remote Wakeup ..1..... Yes
6: Self Powered .0...... No, Bus Powered
7: Reserved (set to one)
(bus-powered for 1.0) 1.......
8 bMaxPower 1 32h 100 mA
Interface Descriptor 0/0 HID, 1 Endpoint
0 bLength 1 09h
1 bDescriptorType 1 04h Interface
2 bInterfaceNumber 1 00h
3 bAlternateSetting 1 00h
4 bNumEndpoints 1 01h
5 bInterfaceClass 1 03h HID
6 bInterfaceSubClass 1 01h Boot Interface
7 bInterfaceProtocol 1 02h Mouse
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
1 bDescriptorType 1 21h HID
2 bcdHID 2 0111h 1.11
4 bCountryCode 1 00h
5 bNumDescriptors 1 01h
6 bDescriptorType 1 22h Report
7 wDescriptorLength 2 005Bh 91 bytes
Endpoint Descriptor 81 1 In, Interrupt, 125 us
0 bLength 1 07h
1 bDescriptorType 1 05h Endpoint
2 bEndpointAddress 1 81h 1 In
3 bmAttributes 1 03h Interrupt
1..0: Transfer Type ......11 Interrupt
7..2: Reserved 000000..
4 wMaxPacketSize 2 0008h 8 bytes
6 bInterval 1 01h 125 us
Interface Descriptor 1/0 HID, 1 Endpoint
0 bLength 1 09h
2 bInterfaceNumber 1 01h
7 bInterfaceProtocol 1 01h Keyboard
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
7 wDescriptorLength 2 00A3h 163 bytes
Endpoint Descriptor 82 2 In, Interrupt, 125 us
0 bLength 1 07h
2 bEndpointAddress 1 82h 2 In
4 wMaxPacketSize 2 0040h 64 bytes
Interface Descriptor 2/0 HID, 1 Endpoint
0 bLength 1 09h
2 bInterfaceNumber 1 02h
6 bInterfaceSubClass 1 00h
7 bInterfaceProtocol 1 00h
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
7 wDescriptorLength 2 0014h 20 bytes
Endpoint Descriptor 83 3 In, Interrupt, 125 us
0 bLength 1 07h
2 bEndpointAddress 1 83h 3 In
Interface 0 HID Report Descriptor Mouse
Item Tag (Value) Raw Data
Usage Page (Generic Desktop) 05 01
Usage (Mouse) 09 02
Collection (Application) A1 01
Usage (Pointer) 09 01
Collection (Physical) A1 00
Usage Page (Button) 05 09
Usage Minimum (Button 1) 19 01
Usage Maximum (Button 5) 29 05
Logical Minimum (0) 15 00
Logical Maximum (1) 25 01
Report Size (1) 75 01
Report Count (5) 95 05
Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
Report Count (3) 95 03
Input (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 03
Usage (Wheel) 09 38
Logical Minimum (-127) 15 81
Logical Maximum (127) 25 7F
Report Size (8) 75 08
Report Count (1) 95 01
Input (Data,Var,Rel,NWrp,Lin,Pref,NNul,Bit) 81 06
Usage (X) 09 30
Usage (Y) 09 31
Logical Minimum (-32768) 16 00 80
Logical Maximum (32767) 26 FF 7F
Report Size (16) 75 10
Report Count (2) 95 02
Usage Page (Consumer Devices) 05 0C
Usage (AC Pan) 0A 38 02
Usage (Undefined) 09 00
End Collection C0
End Collection C0
Interface 1 HID Report Descriptor Consumer Control
Usage (Consumer Control) 09 01
Report ID (1) 85 01
Usage Minimum (Undefined) 19 00
Usage Maximum (AC Format) 2A 3C 02
Logical Maximum (572) 26 3C 02
Input (Data,Ary,Abs) 81 00
End Collection C0
Usage (System Control) 09 80
Report ID (2) 85 02
Usage Minimum (System Power Down) 19 81
Usage Maximum (System Wake Up) 29 83
Input (Cnst,Ary,Abs) 81 01
End Collection C0
Usage (Keyboard) 09 06
Report ID (3) 85 03
Usage Page (Keyboard/Keypad) 05 07
Usage Minimum (Keyboard Left Control) 19 E0
Usage Maximum (Keyboard Right GUI) 29 E7
Report Count (8) 95 08
Usage Page (LEDs) 05 08
Usage Minimum (Num Lock) 19 01
Usage Maximum (Kana) 29 05
Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
Report Size (3) 75 03
Output (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 03
Report Count (6) 95 06
Logical Maximum (101) 25 65
Usage Maximum (Keyboard Application) 29 65
End Collection C0
Usage Page (Vendor-Defined 161) 06 A0 FF
Usage (Vendor-Defined 1) 09 01
Report ID (4) 85 04
Logical Maximum (255) 26 FF 00
End Collection C0
Usage Page (Vendor-Defined 256) 06 FF FF
Report ID (5) 85 05
End Collection C0
Interface 2 HID Report Descriptor
Report Count (64) 95 40
Feature (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) B1 02
End Collection C0
Speed High
Device Address 1
0 bLength 1 12h
8 idVendor 2 373Eh
Device Qualifier Descriptor
0 bLength 1 0Ah
1 bDescriptorType 1 06h Device Qualifier
8 bNumConfigurations 1 01h
9 bReserved 1 00h
0 bLength 1 09h
0 bLength 1 09h
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
0 bLength 1 07h
0 bLength 1 09h
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
0 bLength 1 07h
0 bLength 1 09h
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
0 bLength 1 07h
Other Speed Configuration Descriptor 1 Bus Powered, 100 mA
0 bLength 1 09h
1 bDescriptorType 1 07h Other Speed Configuration
2 wTotalLength 2 0022h
4 bNumInterfaces 1 01h
0 bLength 1 09h
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
0 bLength 1 07h
Usage (Mouse) 09 02
Usage (Wheel) 09 38
Usage (X) 09 30
Usage (Y) 09 31
End Collection C0
End Collection C0
Report ID (1) 85 01
End Collection C0
Report ID (2) 85 02
End Collection C0
Report ID (3) 85 03
End Collection C0
Report ID (4) 85 04
End Collection C0
Report ID (5) 85 05
End Collection C0
End Collection C0
OS: Up to date Windows 11
CPU: 9800X3D
Motherboard: MSI B650 Tomahawk
RAM: 32GB DDR5 6000MT CL36
Mice Tested: Attack Shark R5 Ultra (8000hz Max), VGN Dragonfly F1 Pro (1000hz)
