I'm reporting a bug with the USB Host library. The setup uses 2 Teensy 3.6 devices running the exact same code shown below. USB Type is MIDI. Tested with 3 different USB hubs.
Description of problem
When hot hotplugging a Teensy USB MIDI device, plugged into a USB hub connected to the host port of a Teensy 3.6, the USB Hub driver goes into an endless loop and eventually crashes the host teensy.
If the MIDIDevice driver is removed from the sketch, the problem goes away.
Test Setup
Connect a USB hub to the host port of one of the Teensys. Connect / disconnect the second Teensy to the hub. I sure way to trigger the problem is to press the program button on the teensy connected to the hub.
Simplest Sketch to Reproduce (USB Type MIDI)
Sample Debugging Output (truncated)
Test Setup
#include <USBHost_t36.h>
USBHost myusb;
USBHub usbHub(myusb);
MIDIDevice midi1(myusb); // if removed from the shetch, the problem goes away!
bool ledOn = false;
#define LEDPIN 5
while (!Serial && millis() < 5000) {
// wait for serial port to connect.
myusb.begin();
sizeof Device = 36
sizeof Pipe = 96
sizeof Transfer = 64
power up USBHS PHY
reset waited 5
USBHS_ASYNCLISTADDR = 0
USBHS_PERIODICLISTBASE = 1FFF3000
periodictable = 1FFF3000
port change: 10001803
connect
begin reset
port change: 18001205
port enabled
end recovery
new_Device: 480 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 09 00 01 40 E3 05 05 06 0B 06 00 01 00 01
VendorID = 05E3, ProductID = 0605, Version = 060B
Class/Subclass/Protocol = 9(Hub) / 0 / 1(Single-TT)
Number of Configurations = 1
enumeration:
enumeration:
Product: USB2.0 Hub
enumeration:
Config data length = 25
enumeration:
Configuration Descriptor:
09 02 19 00 01 01 00 E0 32
NumInterfaces = 1
ConfigurationValue = 1
09 04 00 00 01 09 00 00 00
Interface = 0
Number of endpoints = 1
Class/Subclass/Protocol = 9(Hub) / 0 / 0
07 05 81 03 01 00 0C
Endpoint = 1 IN
Type = Interrupt
Max Size = 1
Polling Interval = 12
enumeration:
USBHub memory usage = 960
USBHub claim_device this=1FFF2720
found possible interface, altsetting=0
number of interfaces found = 1
USBHub control callback
09 29 04 E9 00 32 64 00 FF 00 00 00 00 00 00 00
Hub ports = 4
power turned on to all ports
device addr = 1
new_Pipe
allocate_interrupt_pipe_bandwidth
ep interval = 12
interval = 256
best_bandwidth = 2, at offset = 0
pipe cap1 = F0012101
HUB Callback (member)
status = 10
getstatus, port = 4
01 01 01 00
New Port Status
status=10101 port=4
state=0
Device is present:
Has Power
Port Status Cleared, port=4
timer event (199999 us): Debounce Timer, this = 1FFF2720, timer = 1FFF2A38
ports in use bitmask = 10
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=2
Device is present:
Has Power
timer event (19999 us): Debounce Timer, this = 1FFF2720, timer = 1FFF2A38
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=3
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=4
Device is present:
Has Power
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=5
Device is present:
Has Power
timer event (20000 us): Debounce Timer, this = 1FFF2720, timer = 1FFF2A38
getstatus, port = 4
01 01 00 00
New Port Status
status=101 port=4
state=6
Device is present:
Has Power
sending reset
send_setreset
unhandled setup, message = 40323
ports in use bitmask = 0
status = 10
getstatus, port = 4
03 01 10 00
New Port Status
status=100103 port=4
state=7
Device is present:
Enabled, speed = 12 Mbit/sec
Has Power
unhandled setup, message = 140123
timer event (25000 us): Hello, I'm resettimer, this = 1FFF2720, timer = 1FFF2A58
port_doing_reset = 4
PORT_RECOVERY
new_Device: 12 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 10 01 00 00 00 40 C0 16 85 04 77 02 01 02 03 01
VendorID = 16C0, ProductID = 0485, Version = 0277
Class/Subclass/Protocol = 0 / 0 / 0
enumeration:
enumeration:
Manufacturer: Teensyduino
enumeration:
Product: Teensy MIDI
enumeration:
Serial Number: 3614610
enumeration:
Config data length = 115
enumeration:
09 02 73 00 02 01 00 C0 32
NumInterfaces = 2
09 04 00 00 02 01 03 00 00
Interface = 0
Number of endpoints = 2
Class/Subclass/Protocol = 1 / 3 / 0
07 24 01 00 01 25 00
06 24 02 01 01 05
06 24 02 02 02 05
09 24 03 01 03 01 02 01 05
09 24 03 02 04 01 01 01 05
09 05 04 02 40 00 00 00 00
Endpoint = 4 OUT
Type = Bulk
Max Size = 64
Polling Interval = 0
05 25 01 01 01
09 05 83 02 40 00 00 00 00
Endpoint = 3 IN
Type = Bulk
Max Size = 64
05 25 01 01 03
09 04 01 00 02 03 00 00 00
Interface = 1
Class/Subclass/Protocol = 3(HID) / 0 / 0
09 21 11 01 00 01 22 21 00
HID, 1 report descriptor
07 05 81 03 40 00 01
Endpoint = 1 IN
Type = Interrupt
Max Size = 64
07 05 02 03 20 00 02
Endpoint = 2 OUT
Type = Interrupt
Max Size = 32
Polling Interval = 2
enumeration:
Descriptor 4 = INTERFACE
MIDIDevice claim this=1FFF2020
len = 106
Interface is MIDI
type: 36, len: 7
MIDI Header (ignored)
type: 36, len: 6
MIDI IN Jack (ignored)
type: 36, len: 6
type: 36, len: 9
MIDI OUT Jack (ignored)
type: 36, len: 9
type: 5, len: 9
MIDI Endpoint: 4
tx_size = 64
type: 37, len: 5
MIDI Endpoint Jack Association (ignored)
type: 5, len: 9
MIDI Endpoint: 83
rx_size = 64
type: 37, len: 5
type: 4, len: 9
new_Pipe
new_Pipe
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 36 = ???
Descriptor 5 = ENDPOINT
Descriptor 37 = ???
Descriptor 37 = ???
Descriptor 33 = HID
status = 10
getstatus, port = 4
status = 10
deferred getstatus, port = 4
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
status = 10
