Connection Status Device connected
Current Configuration 1
Speed Low (1.5 Mbit/s)
Device Address 2
Number Of Open Pipes 2
Device Descriptor Generic USB Joystick
Offset Field Size Value Description
0 bLength 1 12h
1 bDescriptorType 1 01h Device
2 bcdUSB 2 0100h USB Spec 1.0
4 bDeviceClass 1 00h Class info in Ifc Descriptors
5 bDeviceSubClass 1 00h
6 bDeviceProtocol 1 00h
7 bMaxPacketSize0 1 08h 8 bytes
8 idVendor 2 0079h
10 idProduct 2 0006h
12 bcdDevice 2 0107h 1.07
14 iManufacturer 1 01h "DragonRise Inc. "
15 iProduct 1 02h "Generic USB Joystick "
16 iSerialNumber 1 00h
17 bNumConfigurations 1 01h
Configuration Descriptor 1 Bus Powered, 500 mA
0 bLength 1 09h
1 bDescriptorType 1 02h Configuration
2 wTotalLength 2 0029h
4 bNumInterfaces 1 01h
5 bConfigurationValue 1 01h
6 iConfiguration 1 00h
7 bmAttributes 1 80h Bus Powered
4..0: Reserved ...00000
5: Remote Wakeup ..0..... No
6: Self Powered .0...... No, Bus Powered
7: Reserved (set to one)
(bus-powered for 1.0) 1.......
8 bMaxPower 1 FAh 500 mA
Interface Descriptor 0/0 HID, 2 Endpoints
0 bLength 1 09h
1 bDescriptorType 1 04h Interface
2 bInterfaceNumber 1 00h
3 bAlternateSetting 1 00h
4 bNumEndpoints 1 02h
5 bInterfaceClass 1 03h HID
6 bInterfaceSubClass 1 00h
7 bInterfaceProtocol 1 00h
8 iInterface 1 00h
HID Descriptor
0 bLength 1 09h
1 bDescriptorType 1 21h HID
2 bcdHID 2 0110h 1.10
4 bCountryCode 1 21h US
5 bNumDescriptors 1 01h
6 bDescriptorType 1 22h Report
7 wDescriptorLength 2 0065h 101 bytes
Endpoint Descriptor 81 1 In, Interrupt, 10 ms
0 bLength 1 07h
1 bDescriptorType 1 05h Endpoint
2 bEndpointAddress 1 81h 1 In
3 bmAttributes 1 03h Interrupt
1..0: Transfer Type ......11 Interrupt
7..2: Reserved 000000..
4 wMaxPacketSize 2 0008h 8 bytes
6 bInterval 1 0Ah 10 ms
Endpoint Descriptor 01 1 Out, Interrupt, 10 ms
0 bLength 1 07h
2 bEndpointAddress 1 01h 1 Out
Interface 0 HID Report Descriptor Joystick
Item Tag (Value) Raw Data
Usage Page (Generic Desktop) 05 01
Usage (Joystick) 09 04
Collection (Application) A1 01
Report ID (1) 85 01
Collection (Logical) A1 02
Report Size (8) 75 08
Report Count (4) 95 04
Logical Minimum (0) 15 00
Logical Maximum (255) 26 FF 00
Physical Minimum (0) 35 00
Physical Maximum (255) 46 FF 00
Usage (X) 09 30
Usage (Y) 09 31
Usage (Z) 09 32
Usage (Rz) 09 35
Input (Data,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 02
Report Size (4) 75 04
Report Count (1) 95 01
Logical Maximum (7) 25 07
Physical Maximum (315) 46 3B 01
Unit (Eng Rot: Degree) 65 14
Usage (Hat Switch) 09 39
Input (Data,Var,Abs,NWrp,Lin,Pref,Null,Bit) 81 42
Unit (None) 65 00
Report Size (1) 75 01
Report Count (12) 95 0C
Logical Maximum (1) 25 01
Physical Maximum (1) 45 01
Usage Page (Button) 05 09
Usage Minimum (Button 1) 19 01
Usage Maximum (Button 12) 29 0C
Usage Page (Vendor-Defined 1) 06 00 FF
Report Count (8) 95 08
Usage (Vendor-Defined 1) 09 01
End Collection C0
Report Count (7) 95 07
Usage (Vendor-Defined 2) 09 02
Output (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) 91 02
Report Count (21) 95 15
Usage (Vendor-Defined 1:Vendor-Defined 3) 0B 03 00 00 FF
Feature (Data,Var,Abs,NWrp,Lin,Pref,NNul,NVol,Bit) B1 02
End Collection C0
End Collection C0
Usage (Keyboard) 09 06
Report ID (2) 85 02
Usage Page (Keyboard/Keypad) 05 07
Usage Minimum (Keyboard Left Control) 19 E0
Usage Maximum (Keyboard Right GUI) 29 E7
Input (Cnst,Var,Abs,NWrp,Lin,Pref,NNul,Bit) 81 03
Report Count (5) 95 05
Logical Maximum (101) 25 65
Usage Minimum (Undefined) 19 00
Usage Maximum (Keyboard Application) 29 65
Input (Data,Ary,Abs) 81 00
End Collection C0
Usage (Mouse) 09 02
Report ID (3) 85 03
Usage (Pointer) 09 01
Collection (Physical) A1 00
Usage Maximum (Button 3) 29 03
Report Count (3) 95 03
Report Size (5) 75 05
Input (Cnst,Ary,Abs) 81 01
Usage (X) 09 30
Usage (Y) 09 31
Usage (Wheel) 09 38
Logical Minimum (-127) 15 81
Logical Maximum (127) 25 7F
Physical Minimum (-127) 35 81
Physical Maximum (127) 45 7F
Input (Data,Var,Rel,NWrp,Lin,Pref,NNul,Bit) 81 06
End Collection C0
End Collection C0
