I have added new definitions for USB_DUAL_SERIAL_AUDIO and USB_TRIPLE_SERIAL_AUDIO to cores/teensy4/usb_desc.h.USB_TRIPLE_SERIAL_AUDIO does not seem to be working properly.
Is there a bug in my definition?
C++:
#elif defined(USB_DUAL_SERIAL_AUDIO)
#define VENDOR_ID 0x16C0
#define PRODUCT_ID 0x048B
#define MANUFACTURER_NAME {'T','e','e','n','s','y','d','u','i','n','o'}
#define MANUFACTURER_NAME_LEN 11
#define PRODUCT_NAME {'D','u','a','l',' ','S','.',' ','A','u','d','i','o'}
#define PRODUCT_NAME_LEN 13
#define EP0_SIZE 64
#define NUM_ENDPOINTS 7
#define NUM_INTERFACE 7
#define CDC_IAD_DESCRIPTOR 1 // Serial
#define CDC_STATUS_INTERFACE 0
#define CDC_DATA_INTERFACE 1
#define CDC_ACM_ENDPOINT 2
#define CDC_RX_ENDPOINT 3
#define CDC_TX_ENDPOINT 3
#define CDC_ACM_SIZE 16
#define CDC_RX_SIZE_480 512
#define CDC_TX_SIZE_480 512
#define CDC_RX_SIZE_12 64
#define CDC_TX_SIZE_12 64
#define CDC2_STATUS_INTERFACE 2 // SerialUSB1
#define CDC2_DATA_INTERFACE 3
#define CDC2_ACM_ENDPOINT 4
#define CDC2_RX_ENDPOINT 5
#define CDC2_TX_ENDPOINT 5
#define AUDIO_INTERFACE 4 // Audio (uses 3 consecutive interfaces)
#define AUDIO_TX_ENDPOINT 6
#define AUDIO_TX_SIZE 180
#define AUDIO_RX_ENDPOINT 6
#define AUDIO_RX_SIZE 180
#define AUDIO_SYNC_ENDPOINT 7
#define ENDPOINT2_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT3_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
#define ENDPOINT4_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT5_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
// AUDIO
#define ENDPOINT6_CONFIG ENDPOINT_RECEIVE_ISOCHRONOUS + ENDPOINT_TRANSMIT_ISOCHRONOUS
#define ENDPOINT7_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_ISOCHRONOUS
#elif defined(USB_TRIPLE_SERIAL_AUDIO)
#define PRODUCT_ID 0x048C
#define PRODUCT_NAME {'T','r','i','p','l','e','S',' ','A','u','d','i','o'}
#define EP0_SIZE 64
#define NUM_ENDPOINTS 9
#define NUM_INTERFACE 9
#define CDC3_STATUS_INTERFACE 4 // SerialUSB2
#define CDC3_DATA_INTERFACE 5
#define CDC3_ACM_ENDPOINT 6
#define CDC3_RX_ENDPOINT 7
#define CDC3_TX_ENDPOINT 7
#define AUDIO_INTERFACE 6 // Audio (uses 3 consecutive interfaces)
#define AUDIO_TX_ENDPOINT 8
#define AUDIO_RX_ENDPOINT 8
#define AUDIO_SYNC_ENDPOINT 9
#define ENDPOINT6_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_INTERRUPT
#define ENDPOINT7_CONFIG ENDPOINT_RECEIVE_BULK + ENDPOINT_TRANSMIT_BULK
// AUDIO
#define ENDPOINT8_CONFIG ENDPOINT_RECEIVE_ISOCHRONOUS + ENDPOINT_TRANSMIT_ISOCHRONOUS
#define ENDPOINT9_CONFIG ENDPOINT_RECEIVE_UNUSED + ENDPOINT_TRANSMIT_ISOCHRONOUS
