usbhost midi device enumeration inconsistent
lokki
ok,
since my last post was a bit broad and (therefore) got no answers/ideas, i will try to clarify. i have a 7 port usb hub connected to a teensy 4.1 which is running the following code: (heavily based on the 16x16 example)
#include <MIDI.h>        // access to serial (5 pin DIN) MIDI
#include <USBHost_t36.h> // access to USB MIDI devices (plugged into 2nd USB port)
#define DEBUG
// Create the Serial MIDI ports
MIDI_CREATE_INSTANCE(HardwareSerial, Serial8, MIDI1);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial3, MIDI2);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial4, MIDI3);
MIDI_CREATE_INSTANCE(HardwareSerial, Serial5, MIDI4);
//midi::MidiInterface &SerialMidiList[6] = {MIDI1, MIDI2, MIDI3, MIDI4, MIDI5, MIDI6};
// Create the ports for USB devices plugged into Teensy's 2nd USB port (via hubs)
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
MIDIDevice midi01(myusb);
MIDIDevice midi02(myusb);
MIDIDevice midi03(myusb);
MIDIDevice midi04(myusb);
MIDIDevice midi05(myusb);
MIDIDevice midi06(myusb);
MIDIDevice midi07(myusb);
MIDIDevice * midilist[7] = {
  &midi01, &midi02, &midi03, &midi04, &midi05, &midi06, &midi07
// A variable to know how long the LED has been turned on
//elapsedMillis ledOnMillis;
//devices
int pulse2 = 7;
int keysaxo = 7;
int minitaur = 7;
int axodub = 7;
int dreadbox = 7;
//int macmini = 7;
//int preenfm = 7;
//int footpedal = 7;
//midibass
int midibass = 7;
  #ifdef DEBUG
  pinMode(13, OUTPUT); // LED pin
  digitalWrite(13, LOW);
  MIDI1.begin(MIDI_CHANNEL_OMNI);
  MIDI2.begin(MIDI_CHANNEL_OMNI);
  MIDI3.begin(MIDI_CHANNEL_OMNI);
  MIDI4.begin(MIDI_CHANNEL_OMNI);
  // Wait 1.5 seconds before turning on USB Host.  If connected USB devices
  // use too much power, Teensy at least completes USB enumeration, which
  // makes isolating the power issue easier.
  delay(1500);
  #ifdef DEBUG
  Serial.println("Interface_16x16 Example");
   //wait another 3 seconds for all usb synths to turn on
  delay(3000);
  myusb.begin();
  //wait another 1.5 seconds before enumerating the devices, hopefully by now they have settled.
  delay(1500);
Serial.println("");
Serial.println("------------NEW START--------------");
for (int i=0; i<7; i++) {
  if (midilist[i]->manufacturer() != NULL && midilist[i]->serialNumber() != NULL) {
    #ifdef DEBUG
     Serial.println("-----------------------------------");
     Serial.print("Serial:");
     Serial.println((char*)midilist[i]->serialNumber());
     Serial.print("ProductID:");
     Serial.println(midilist[i]->idProduct());
    if (midilist[i]->idProduct() == 22) {
      #ifdef DEBUG
      Serial.println("here is Pulse2");
      pulse2 = i;
     if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"003600433435511733353932")) {//Axoloti for qunexus/vocoder serial
     #ifdef DEBUG
      Serial.println("here is axovocoder");
      keysaxo = i;
       if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"325B346C3030")) {//typhon dreadbox
     #ifdef DEBUG
      Serial.println("here is typhon dreadbox");
      dreadbox = i;
       if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"6633190")) {//midibass
       #ifdef DEBUG
      Serial.println("here is MIDIBASS!!");
      midibass = i;
  if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"003500323532470532323631")) {//Axoloti for qunexus/vocoder serial
  #ifdef DEBUG
      Serial.println("here is axodub");
      axodub = i;
if (!strcmp(reinterpret_cast<const char *>(midilist[i]->serialNumber()),"MTc537ef")) {//moog minitaur
#ifdef DEBUG
      Serial.println("here is the minitaur");
      minitaur = i;
  delay(10);
Serial.println("------------Finished------------");
if (axodub < 7) midilist[axodub]->sendProgramChange(0,1);
if (pulse2 < 7) midilist[pulse2]->sendProgramChange(0,6);
if (minitaur < 7)  midilist[minitaur]->sendProgramChange(1,8);
if (dreadbox < 7) midilist[dreadbox]->sendProgramChange(0,9);
 // MIDI1.sendProgramChange(0,9);
  if (midibass < 7){
 if (midilist[midibass]->read()) {
      uint8_t type =       midilist[midibass]->getType();
      uint8_t data1 =      midilist[midibass]->getData1();
      uint8_t data2 =      midilist[midibass]->getData2();
      uint8_t channel =    midilist[midibass]->getChannel();
      uint8_t cable =      midilist[midibass]->getCable();
     // const uint8_t *sys = midilist[midibass]->getSysExArray();
    //  midi::MidiType mtype = (midi::MidiType)type;
      if (!cable) {
          if (channel == 1) {
            sendToMacMini(type, data1, data2, channel, 0);
            if (axodub < 7) midilist[axodub]->send(type, data1, data2, channel);
          if (channel == 6) {
            if (pulse2 < 7)  midilist[pulse2]->send(type, data1, data2, channel);
          if (channel == 7) {
          if (channel == 8) {
            if (minitaur < 7)  midilist[minitaur]->send(type, data1, data2, channel);
          if (channel == 9) {
            if (dreadbox < 7) midilist[dreadbox]->send(type, data1, data2, channel);
          if (((channel > 2) && (channel < 6)) || (channel > 9)) sendToMacMini(type, data1, data2, channel, 0); // channel 2-5 and 10-16
         // case 9: if (keysaxo < 7)  midilist[keysaxo]->send(type, data1, data2, channel); break;
        // case 9: MIDI1.send(mtype, data1, data2, channel); break;
      else if (cable == 1) {
       if ((channel > 9) && (channel < 14)) sendToMacMini(type, data1, data2, channel - 5, 0); //channel 14 will overlap computer and keysaxo for layered sounds
       if ((channel > 12) && (keysaxo < 7))  midilist[keysaxo]->send(type, data1, data2, channel);
     // activity = true;
void sendToMacMini(byte type, byte data1, byte data2, byte channel, byte cable)
  if (type != midi::SystemExclusive) {
    usbMIDI.send(type, data1, data2, channel, cable);
   // unsigned int SysExLength = data1 + data2 * 256;
   // usbMIDI.sendSysEx(SysExLength, sysexarray, true, cable);
the hub has 6 usb-midi devices connected:
-waldorf pulse2
-dreadbox typhon
-moog minitaur
-axoloti 1
-axoloti 2
-a teensy 3.6 acting as midi controller
the hub is powered via external 5v supply and when i plug the teensy 4.1. in after all usb-midi devices are turned on (and running) one of three things happens:
-no midi device is recognised, the serial code just returns ->Interface_16x16 Example->NEW START and Finished
-only some devices, usually 4 or 5 are recognised, not always the same though.
-all devices are correctly recognised
usually the first problem only happens after the first power up of the synths and the teensy. if i then unplug the teensy (but not the synths) and plug it in again it mostly works (or recognises 5 out of 6 devices).
is there something obviously wrong with my code? are there other things i can try to make the boot up more consistent?
i also have a follow up problem but i figure it might be good to tackle this first.
In the USBHost_t36.h file is a define, that you can uncomment. With that there is tons of debug informations in your serial console. It helped me a lot to understand how all this USB Magic and the. MIDI enumeration works. Maybe you can find in there, what works wrong?
About line #62 is this to uncomment:
// Uncomment this line to see lots of debugging info!
[B]//#define USBHOST_PRINT_DEBUG[/B]
lokki:
The first thing I would try before you spend a lot of time troubleshooting the USB code is check the +5VDC supply at the Teensy's input to see if you might have power supply droop. I seems you might have overloaded the 5 volt supply of the USB hub with all the USB devices plugged into it. Most USB hubs I have seen have only 2 amps (on a good day) available for all of the devices plugged into the HUB.
Regards,
Ed
lokki:
Regards,
Ed
will check that, although only the two axolotis and the typhon take power from the hub, the pulse2 and the minitaur have separate supplies.
if i enable debug (don't know why i did not think about that before) i get this on a "normal" boot, where everything works:
USB2 PLL running
 reset waited 6
USBHS_ASYNCLISTADDR = 0
USBHS_PERIODICLISTBASE = 20003000
periodictable = 20003000
port change: 10001803
    connect
  begin reset
port change: 18001205
  port enabled
  end recovery
new_Device: 480 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 09 00 02 40 40 1A 01 02 00 01 00 01 00 01
    VendorID = 1A40, ProductID = 0201, Version = 0100
    Class/Subclass/Protocol = 9(Hub) / 0 / 2(Multi-TT)
    Number of Configurations = 1
enumeration:
enumeration:
Product: USB 2.0 Hub [MTT]
enumeration:
Config data length = 41
enumeration:
Configuration Descriptor:
  09 02 29 00 01 01 00 E0 32
    NumInterfaces = 1
    ConfigurationValue = 1
  09 04 00 00 01 09 00 01 00
    Interface = 0
    Number of endpoints = 1
    Class/Subclass/Protocol = 9(Hub) / 0 / 1(Single-TT)
  07 05 81 03 01 00 0C
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 1
    Polling Interval = 12
  09 04 00 01 01 09 00 02 00
    Interface = 0
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 1
enumeration:
USBHub memory usage = 960
USBHub claim_device this=200031E0
found possible interface, altsetting=0
found possible interface, altsetting=1
number of interfaces found = 2
best interface is 0 using altsetting 1
USBHub control callback
09 29 07 88 00 32 64 00 FF 00 00 00 00 00 00 00
Hub ports = 7
unhandled setup, message = 10B01
power turned on to all ports
device addr = 1
new_Pipe
allocate_interrupt_pipe_bandwidth
  ep interval = 12
  interval = 256
 best_bandwidth = 2, at offset = 0
pipe cap1 = F0012101
HUB Callback (member)
status = 7E
getstatus, port = 1
deferred getstatus, port = 2
deferred getstatus, port = 3
deferred getstatus, port = 4
deferred getstatus, port = 5
deferred getstatus, port = 6
01 01 01 00
New Port Status
  status=10101  port=1
  state=0
  Device is present:
  Has Power
Port Status Cleared, port=1
getstatus, port = 2
01 01 01 00
New Port Status
  status=10101  port=2
  state=0
  Device is present:
  Has Power
Port Status Cleared, port=2
getstatus, port = 3
01 01 01 00
New Port Status
  status=10101  port=3
  state=0
  Device is present:
  Has Power
Port Status Cleared, port=3
getstatus, port = 4
01 01 01 00
New Port Status
  status=10101  port=4
  state=0
  Device is present:
  Has Power
Port Status Cleared, port=4
getstatus, port = 5
01 01 01 00
New Port Status
  status=10101  port=5
  state=0
  Device is present:
  Has Power
Port Status Cleared, port=5
getstatus, port = 6
01 01 01 00
New Port Status
  status=10101  port=6
  state=0
  Device is present:
  Has Power
Port Status Cleared, port=6
timer event (19999 us): Debounce Timer, this = 200031E0, timer = 200034F8
ports in use bitmask = 7E
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=2
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=2
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=2
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=2
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=2
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=2
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=3
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=3
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=3
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=3
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=3
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=3
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=4
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=4
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=4
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=4
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=4
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=4
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=5
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=5
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=5
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=5
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=5
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=5
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
unhandled setup, message = 40323
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
ports in use bitmask = 7C
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 2
getstatus, port = 1
03 01 10 00
New Port Status
  status=100103  port=1
  state=7
  Device is present:
  Enabled, speed = 12 Mbit/sec
  Has Power
unhandled setup, message = 140123
timer event (20000 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
timer event (24999 us): Hello, I'm resettimer, this = 200031E0, timer = 20003518
port_doing_reset = 1
PORT_RECOVERY
new_Device: 12 Mbit/sec
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 EF 02 01 40 C0 16 42 04 00 02 01 05 03 01
    VendorID = 16C0, ProductID = 0442, Version = 0200
    Class/Subclass/Protocol = 239 / 2 / 1
enumeration:
enumeration:
Manufacturer: Axoloti
enumeration:
Product: Axoloti Core
enumeration:
Serial Number: 003500323532470532323631
enumeration:
Config data length = 140
enumeration:
  09 02 8C 00 03 01 05 C0 32
    NumInterfaces = 3
  08 0B 00 02 01 03 00 00
    Interface Association = 0 through 1
    Class / Subclass / Protocol = 1 / 3 / 0
  09 04 00 00 00 01 01 00 00
    Interface = 0
    Number of endpoints = 0
    Class/Subclass/Protocol = 1 / 1 / 0
  09 24 01 00 01 09 00 01 01
  09 04 01 00 02 01 03 00 00
    Interface = 1
    Number of endpoints = 2
    Class/Subclass/Protocol = 1 / 3 / 0
  07 24 01 00 01 41 00
  06 24 02 01 01 05
  06 24 02 02 02 06
  09 24 03 01 03 01 02 01 06
  09 24 03 02 04 01 01 01 02
  09 05 01 02 40 00 00 00 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
    Polling Interval = 0
  05 25 01 01 01
  09 05 81 02 40 00 00 00 00
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
  08 0B 02 01 FF 00 00 04
    Interface Association = 2 through 2
    Class / Subclass / Protocol = 255 / 0 / 4
  09 04 02 00 02 FF 00 00 04
    Interface = 2
    Class/Subclass/Protocol = 255 / 0 / 0
  07 05 02 02 40 00 00
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
  07 05 82 02 40 00 00
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
timer event (23015 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 2
enumeration:
USBHub claim_device this=200035A0
USBHub claim_device this=20003960
USBHub claim_device this=20003D20
Descriptor 11 = IAD
Descriptor 4 = INTERFACE
MIDIDevice claim this=200040E0
len = 123
  Interface is unknown (might be Yahama)
type: 36, len: 9
    MIDI Header (ignored)
type: 4, len: 9
MIDIDevice claim this=200047E0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=20004EE0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=200055E0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=20005CE0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=200063E0
len = 123
type: 36, len: 9
type: 4, len: 9
MIDIDevice claim this=20006AE0
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 105
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
    MIDI IN Jack (ignored)
type: 36, len: 6
type: 36, len: 9
    MIDI OUT Jack (ignored)
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
    MIDI Endpoint Jack Association (ignored)
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 5 = ENDPOINT
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
This interface is not MIDI
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
ports in use bitmask = 78
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 4
getstatus, port = 2
03 01 10 00
New Port Status
  status=100103  port=2
  state=7
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
timer event (24997 us): Hello, I'm resettimer, this = 200031E0, timer = 20003518
port_doing_reset = 2
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
Serial Number: 003600433435511733353932
enumeration:
enumeration:
    NumInterfaces = 3
    Interface = 0
    Interface = 1
  06 24 02 01 01 05
  06 24 02 02 02 06
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
    Interface = 2
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
enumeration:
Descriptor 11 = IAD
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 105
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
ports in use bitmask = 70
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 8
getstatus, port = 3
03 01 10 00
New Port Status
  status=100103  port=3
  state=7
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
port_doing_reset = 3
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 00 00 00 08 E6 12 16 00 1A 01 01 02 03 01
    VendorID = 12E6, ProductID = 0016, Version = 011A
    Class/Subclass/Protocol = 0 / 0 / 0
enumeration:
enumeration:
Manufacturer: Waldorf Music GmbH
enumeration:
Product: Pulse2
enumeration:
Serial Number: 9
enumeration:
Config data length = 86
enumeration:
  09 02 56 00 02 01 00 80 03
    NumInterfaces = 2
    Interface = 0
    Interface = 1
  07 24 01 00 01 32 00
  06 24 02 01 01 00
  09 24 03 01 02 01 01 01 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
  09 05 82 02 40 00 00 00 00
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 02
enumeration:
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 59
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
ports in use bitmask = 60
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 10
getstatus, port = 4
03 01 10 00
New Port Status
  status=100103  port=4
  state=7
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
port_doing_reset = 4
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 10 01 00 00 00 40 C0 16 85 04 11 02 01 02 03 01
    VendorID = 16C0, ProductID = 0485, Version = 0211
enumeration:
enumeration:
Manufacturer: Teensyduino
enumeration:
Product: Teensy MIDIx4
enumeration:
Serial Number: 6633190
enumeration:
Config data length = 211
enumeration:
  09 02 D3 00 02 01 00 C0 32
    NumInterfaces = 2
  09 04 00 00 02 01 03 00 00
    Interface = 0
  07 24 01 00 01 7F 00
  06 24 02 01 01 05
  06 24 02 02 02 05
  09 24 03 01 03 01 02 01 05
  09 24 03 02 04 01 01 01 05
  06 24 02 01 05 06
  06 24 02 02 06 06
  09 24 03 01 07 01 06 01 06
  09 24 03 02 08 01 05 01 06
  06 24 02 01 09 07
  06 24 02 02 0A 07
  09 24 03 01 0B 01 0A 01 07
  09 24 03 02 0C 01 09 01 07
  06 24 02 01 0D 08
  06 24 02 02 0E 08
  09 24 03 01 0F 01 0E 01 08
  09 24 03 02 10 01 0D 01 08
  09 05 04 02 40 00 00 00 00
    Endpoint = 4 OUT
    Type = Bulk
    Max Size = 64
  08 25 01 04 01 05 09 0D
  09 05 83 02 40 00 00 00 00
    Endpoint = 3 IN
    Type = Bulk
    Max Size = 64
  08 25 01 04 03 07 0B 0F
  09 04 01 00 02 03 00 00 00
    Interface = 1
    Class/Subclass/Protocol = 3(HID) / 0 / 0
  09 21 11 01 00 01 22 21 00
    HID, 1 report descriptor
  07 05 81 03 40 00 01
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 64
  07 05 02 03 20 00 02
    Endpoint = 2 OUT
    Type = Interrupt
    Max Size = 32
    Polling Interval = 2
timer event (22802 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 5
enumeration:
len = 202
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 4
      tx_size = 64
type: 37, len: 8
type: 5, len: 9
    MIDI Endpoint: 83
      rx_size = 64
type: 37, len: 8
type: 4, len: 9
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
len = 32
len = 32
len = 32
Descriptor 33 = HID
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
ports in use bitmask = 40
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 20
getstatus, port = 5
03 01 10 00
New Port Status
  status=100103  port=5
  state=7
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
port_doing_reset = 5
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 00 02 00 00 00 40 83 04 40 57 00 02 01 02 03 01
    VendorID = 0483, ProductID = 5740, Version = 0200
enumeration:
enumeration:
Manufacturer: Dreadbox
enumeration:
Product: Typhon
enumeration:
Serial Number: 325B346C3030
enumeration:
Config data length = 204
enumeration:
  09 02 CC 00 04 01 00 80 EF
    NumInterfaces = 4
  08 0B 00 02 01 00 20 00
    Class / Subclass / Protocol = 1 / 0 / 0
  09 04 00 00 00 01 01 20 00
    Interface = 0
    Class/Subclass/Protocol = 1 / 1 / 32
  09 24 01 00 02 09 2E 00 00
  08 24 0A 01 01 01 00 00
  11 24 02 03 02 06 00 01 02 00 00 00 00 00 00 00 00
  0C 24 03 04 01 01 00 03 01 00 00 00
  09 04 01 00 00 01 02 20 00
    Interface = 1
    Class/Subclass/Protocol = 1 / 2 / 32
  09 04 01 01 01 01 02 20 00
    Interface = 1
  10 24 01 04 00 01 01 00 00 00 02 00 00 00 00 00
  06 24 02 01 02 10
  07 05 81 05 C4 00 01
    Endpoint = 1 IN
    Type = Isochronous
    Max Size = 196
  08 25 01 00 00 00 00 00
  09 04 02 00 00 01 01 00 00
    Interface = 2
  09 24 01 00 01 09 00 01 03
  09 04 03 00 02 01 03 00 00
    Interface = 3
  06 24 02 01 01 00
  09 05 02 02 40 00 00 00 00
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 02
timer event (22619 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 6
enumeration:
Descriptor 11 = IAD
len = 187
type: 36, len: 9
type: 36, len: 8
    Unknown MIDI CS_INTERFACE descriptor!
len = 187
type: 36, len: 9
type: 36, len: 8
len = 187
type: 36, len: 9
type: 36, len: 8
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 59
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 2
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
ports in use bitmask = 0
status = 40
getstatus, port = 6
03 01 10 00
New Port Status
  status=100103  port=6
  state=7
  Device is present:
  Has Power
port_doing_reset = 6
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
  12 01 10 01 00 00 00 40 62 26 F8 0F 21 02 01 02 03 01
    VendorID = 2662, ProductID = 0FF8, Version = 0221
enumeration:
enumeration:
Manufacturer: Moog Music, Inc.
enumeration:
Product: Moog Minitaur
enumeration:
Serial Number: MTc537ef
enumeration:
Config data length = 101
enumeration:
  09 02 65 00 02 01 05 C0 00
    NumInterfaces = 2
  09 04 00 00 00 01 01 00 04
    Interface = 0
    Interface = 1
  06 24 02 01 01 00
  06 24 02 02 02 06
  09 24 03 01 03 01 02 01 00
  09 24 03 02 04 01 01 01 07
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
enumeration:
len = 92
type: 36, len: 9
type: 4, len: 9
len = 92
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 74
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 2
      tx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Serial:003500323532470532323631
ProductID:1090
here is axodub
Serial:003600433435511733353932
ProductID:1090
here is axovocoder
Serial:9
ProductID:22
here is Pulse2
Serial:6633190
ProductID:1157
here is MIDIBASS!!
Serial:325B346C3030
ProductID:22336
Serial:MTc537ef
ProductID:4088
MIDIDevice transmit complete
  MIDI Data: 0C C0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
on a boot that does not work, i get this
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
which repeats forever. it might be that there are other messages at the beginning, but the serial port is flooded with those Descriptor 0 = ??? messages, so i can't recall those. i will try to unplug the teensy fast enough next time it happens.
which brings me to the next point. with debug enabled, the likelihood of a non working boot is far less likely somehow. could it be that all that serial printing is slowing down the usb enumeration a bit? and this makes things more stable... seems unlikely, but it is definitely more stable now..
and here is one that misses the minitaur:
USB2 PLL running
 reset waited 6
    connect
  begin reset
  port enabled
  end recovery
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 1
    Interface = 0
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 1
    Interface = 0
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 1
enumeration:
Hub ports = 7
device addr = 1
new_Pipe
  ep interval = 12
  interval = 256
status = 7E
getstatus, port = 1
01 01 01 00
New Port Status
  status=10101  port=1
  state=0
  Device is present:
  Has Power
getstatus, port = 2
01 01 01 00
New Port Status
  status=10101  port=2
  state=0
  Device is present:
  Has Power
getstatus, port = 3
01 01 01 00
New Port Status
  status=10101  port=3
  state=0
  Device is present:
  Has Power
getstatus, port = 4
01 01 01 00
New Port Status
  status=10101  port=4
  state=0
  Device is present:
  Has Power
getstatus, port = 5
01 01 01 00
New Port Status
  status=10101  port=5
  state=0
  Device is present:
  Has Power
getstatus, port = 6
01 01 01 00
New Port Status
  status=10101  port=6
  state=0
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=2
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=2
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=2
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=2
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=2
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=2
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=3
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=3
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=3
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=3
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=3
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=3
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=4
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=4
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=4
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=4
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=4
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=4
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=5
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=5
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=5
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=5
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=5
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=5
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 2
getstatus, port = 1
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 3
    Interface = 0
    Interface = 1
  06 24 02 01 01 05
  06 24 02 02 02 06
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
    Interface = 2
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
enumeration:
Descriptor 11 = IAD
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 105
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
timer event (27416 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 4
getstatus, port = 2
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 3
    Interface = 0
    Interface = 1
  06 24 02 01 01 05
  06 24 02 02 02 06
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
    Interface = 2
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
enumeration:
Descriptor 11 = IAD
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 105
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
timer event (27357 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 8
getstatus, port = 3
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
Product: Pulse2
enumeration:
Serial Number: 9
enumeration:
enumeration:
    NumInterfaces = 2
    Interface = 0
    Interface = 1
  06 24 02 01 01 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 02
timer event (22733 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 4
enumeration:
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 59
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 10
getstatus, port = 4
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 2
    Interface = 0
  06 24 02 01 01 05
  06 24 02 02 02 05
  06 24 02 01 05 06
  06 24 02 02 06 06
  06 24 02 01 09 07
  06 24 02 02 0A 07
  06 24 02 01 0D 08
  06 24 02 02 0E 08
    Endpoint = 4 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 3 IN
    Type = Bulk
    Max Size = 64
    Interface = 1
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 64
    Endpoint = 2 OUT
    Type = Interrupt
    Max Size = 32
timer event (24613 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 5
enumeration:
len = 202
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 4
      tx_size = 64
type: 37, len: 8
type: 5, len: 9
    MIDI Endpoint: 83
      rx_size = 64
type: 37, len: 8
type: 4, len: 9
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
len = 32
len = 32
len = 32
Descriptor 33 = HID
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 20
getstatus, port = 5
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
Product: Typhon
enumeration:
enumeration:
enumeration:
    NumInterfaces = 4
    Interface = 0
    Interface = 1
    Interface = 1
  06 24 02 01 02 10
    Endpoint = 1 IN
    Type = Isochronous
    Max Size = 196
    Interface = 2
    Interface = 3
  06 24 02 01 01 00
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 02
enumeration:
Descriptor 11 = IAD
len = 187
type: 36, len: 9
type: 36, len: 8
len = 187
type: 36, len: 9
type: 36, len: 8
len = 187
type: 36, len: 9
type: 36, len: 8
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 59
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 2
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
timer event (29367 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
status = 40
getstatus, port = 6
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
ERROR Followup
    remain on followup list
ProductID:1090
here is axodub
ProductID:1090
here is axovocoder
Serial:9
ProductID:22
here is Pulse2
Serial:6633190
ProductID:1157
here is MIDIBASS!!
Serial:325B346C3030
ProductID:22336
and this seems to be the problem?
ERROR Followup
but i wouldn't know what to make of this...
and i managed to catch another example of a "no device working" example. this time i pulled the plug on the teensy soon enough to still catch the beginning of the serial stream.
USB2 PLL running
 reset waited 6
    connect
  begin reset
  port enabled
  end recovery
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 1
    Interface = 0
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 1
    Interface = 0
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 1
enumeration:
Hub ports = 7
device addr = 1
new_Pipe
  ep interval = 12
  interval = 256
status = 7E
getstatus, port = 1
01 01 01 00
New Port Status
  status=10101  port=1
  state=0
  Device is present:
  Has Power
getstatus, port = 2
01 01 01 00
New Port Status
  status=10101  port=2
  state=0
  Device is present:
  Has Power
getstatus, port = 3
01 01 01 00
New Port Status
  status=10101  port=3
  state=0
  Device is present:
  Has Power
getstatus, port = 4
01 01 01 00
New Port Status
  status=10101  port=4
  state=0
  Device is present:
  Has Power
getstatus, port = 5
01 01 01 00
New Port Status
  status=10101  port=5
  state=0
  Device is present:
  Has Power
getstatus, port = 6
01 01 01 00
New Port Status
  status=10101  port=6
  state=0
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=2
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=2
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=2
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=2
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=2
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=2
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=3
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=3
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=3
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=3
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=3
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=3
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=4
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=4
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=4
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=4
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=4
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=4
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=5
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=5
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=5
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=5
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=5
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=5
  Device is present:
  Has Power
getstatus, port = 1
01 01 00 00
New Port Status
  status=101  port=1
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 2
getstatus, port = 1
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 3
    Interface = 0
    Interface = 1
  06 24 02 01 01 05
  06 24 02 02 02 06
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
    Interface = 2
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
enumeration:
Descriptor 11 = IAD
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 105
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
timer event (27214 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 2
01 01 00 00
New Port Status
  status=101  port=2
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 4
getstatus, port = 2
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 3
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 3
    Interface = 0
    Interface = 1
  06 24 02 01 01 05
  06 24 02 02 02 06
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 1 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 03
    Interface = 2
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
timer event (20108 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 3
enumeration:
Descriptor 11 = IAD
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
len = 123
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 105
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 81
      rx_size = 64
type: 37, len: 5
type: 11, len: 8
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 11 = IAD
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
len = 23
type: 5, len: 7
    MIDI Endpoint: 2
      tx_size = 64
type: 5, len: 7
    MIDI Endpoint: 82
      rx_size = 64
01 01 00 00
New Port Status
  status=101  port=3
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 8
getstatus, port = 3
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
timer event (24998 us): Hello, I'm resettimer, this = 200031E0, timer = 20003518
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
Product: Pulse2
enumeration:
Serial Number: 9
enumeration:
enumeration:
    NumInterfaces = 2
    Interface = 0
    Interface = 1
  06 24 02 01 01 00
    Endpoint = 1 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 02
enumeration:
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 59
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 1
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
getstatus, port = 4
01 01 00 00
New Port Status
  status=101  port=4
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 10
getstatus, port = 4
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
enumeration:
    NumInterfaces = 2
    Interface = 0
  06 24 02 01 01 05
  06 24 02 02 02 05
  06 24 02 01 05 06
  06 24 02 02 06 06
  06 24 02 01 09 07
  06 24 02 02 0A 07
  06 24 02 01 0D 08
  06 24 02 02 0E 08
    Endpoint = 4 OUT
    Type = Bulk
    Max Size = 64
    Endpoint = 3 IN
    Type = Bulk
    Max Size = 64
    Interface = 1
    Endpoint = 1 IN
    Type = Interrupt
    Max Size = 64
    Endpoint = 2 OUT
    Type = Interrupt
    Max Size = 32
enumeration:
len = 202
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 36, len: 6
type: 36, len: 6
type: 36, len: 9
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 4
      tx_size = 64
type: 37, len: 8
type: 5, len: 9
    MIDI Endpoint: 83
      rx_size = 64
type: 37, len: 8
type: 4, len: 9
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
len = 32
len = 32
len = 32
Descriptor 33 = HID
getstatus, port = 5
01 01 00 00
New Port Status
  status=101  port=5
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
status = 20
getstatus, port = 5
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
getstatus, port = 6
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
    Number of Configurations = 1
enumeration:
enumeration:
enumeration:
Product: Typhon
enumeration:
enumeration:
enumeration:
Configuration Descriptor:
    NumInterfaces = 4
    ConfigurationValue = 1
    Interface = 0
    Interface = 1
    Interface = 1
    Number of endpoints = 1
  06 24 02 01 02 10
    Endpoint = 1 IN
    Type = Isochronous
    Max Size = 196
    Polling Interval = 1
    Interface = 2
    Interface = 3
  06 24 02 01 01 00
    Endpoint = 2 OUT
    Type = Bulk
    Max Size = 64
  05 25 01 01 01
    Endpoint = 2 IN
    Type = Bulk
    Max Size = 64
  05 25 01 01 02
enumeration:
USBHub memory usage = 960
Descriptor 11 = IAD
len = 187
type: 36, len: 9
type: 36, len: 8
len = 187
type: 36, len: 9
type: 36, len: 8
len = 187
type: 36, len: 9
type: 36, len: 8
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 132
type: 4, len: 9
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 123
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
len = 77
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 59
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 2
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
new_Pipe
new_Pipe
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
timer event (25688 us): Debounce Timer, this = 200031E0, timer = 200034F8
getstatus, port = 6
USBHub control callback
01 01 00 00
New Port Status
  status=101  port=6
  state=6
  Device is present:
  Has Power
sending reset
send_setreset
timer event (19999 us): Debounce Timer, this = 200031E0, timer = 200034F8
HUB Callback (member)
status = 40
getstatus, port = 6
03 01 10 00
New Port Status
  state=7
  Device is present:
  Has Power
PORT_RECOVERY
new_Pipe
enumeration:
ERROR Followup
    remove from followup list
    stray halted 20005A60
  qtd: 20005A60, token=80008180, next=20003120
  dummy halt: 20003120
enumeration:
ERROR Followup
    stray halted 200060A0
  qtd: 200059E0, token=80120180, next=200060A0
  qtd: 200060A0, token=80008080, next=200060E0
  dummy halt: 200060E0
enumeration:
Device Descriptor:
  12 01 10 01 00 00 00 40 EF 08 0B 00 02 01 00 20 00 09
    VendorID = 08EF, ProductID = 000B, Version = 0102
    Number of Configurations = 9
  qtd: 200059A0, token=87FC0180, next=20005A60
  qtd: 20005A60, token=80008080, next=20003120
enumeration:
ERROR Followup
  qtd: 20005960, token=80090180, next=200060A0
enumeration:
Config data length = 256
  qtd: 20005920, token=81000180, next=20005A60
enumeration:
  error: config must be 9 bytes
ERROR Followup
  qtd: 200060A0, token=80008180, next=200060E0
enumeration:
Descriptor 11 = IAD
len = 239
type: 36, len: 9
type: 36, len: 8
len = 239
type: 36, len: 9
type: 36, len: 8
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
len = 184
type: 4, len: 9
len = 184
type: 4, len: 9
len = 175
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
len = 175
type: 36, len: 16
type: 36, len: 6
type: 5, len: 7
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
len = 129
type: 36, len: 9
type: 4, len: 9
len = 129
type: 36, len: 9
type: 4, len: 9
Descriptor 36 =  ???
len = 111
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 2
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
type: 5, len: 7
    MIDI Endpoint: 2
len = 111
  Interface is MIDI
type: 36, len: 7
type: 36, len: 6
type: 36, len: 9
type: 5, len: 9
    MIDI Endpoint: 2
      tx_size = 64
type: 37, len: 5
type: 5, len: 9
    MIDI Endpoint: 82
      rx_size = 64
type: 37, len: 5
type: 5, len: 7
    MIDI Endpoint: 2
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 36 =  ???
Descriptor 37 =  ???
Descriptor 37 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ???
Descriptor 0 =  ??
the Descriptor 0 = ??? part simply repeats forever...
there are many errors before that. again this is the exact same boot process, first all devices are started, then after ten seconds i plug in the teensy (all usb midi devices have been started by now)
and i also measured the 5v line on the HUB. with all devices connected and booted it reads 4.91v. note though that the teensy does not get power from the HUB (which i could enable by means of a jumper) but from the macbook or Mac mini i am connecting it to.
