// VolumeName.ino
// An example of how to retrieve Fat32 and ExFat volume names using SdFat.
// Works with SD cards and USB mass storage drives.
#include "Arduino.h"
#include "mscFS.h"
// Setup USBHost_t36 and as many HUB ports as needed.
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
// Setup MSC for the number of USB Drives you are using. (Two for this example)
// Mutiple USB drives can be used. Hot plugging is supported. There is a slight
// delay after a USB MSC device is plugged in. This is waiting for initialization
// but after it is initialized ther should be no delay.
msController msDrive1(myusb);
#define sdDrive 1
#define msDrive 2
#define SD_CONFIG SdioConfig(FIFO_SDIO)
// set up variables using the mscFS utility library functions:
UsbFs msc1;
SdFs sd;
// Get ExFat volume name.
bool getExFatVolumeLabel(uint8_t drvType) {
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
msController *mscDrive;
DirLabel_t *dir;
if (drvType == msDrive) {
mscDrive = &msDrive1;
if (!volName.begin(mscDrive)) {
return false;
if (!root.openRoot(&volName)) {
Serial.println("openRoot failed");
return false;
if (drvType == sdDrive) {
if (!volName1.begin(SD_CONFIG)) {
return false;
if (!root.openRoot(&volName1)) {
return false;
root.read(buf, 32);
dir = reinterpret_cast<DirLabel_t*>(buf);
Serial.print(F("Volume Name: "));
for (size_t i = 0; i < dir->labelLength; i++) {
Serial.write(dir->unicode[2 * i]);
return true;
// Get Fat32 volume name.
bool getFat32VolumeLabel(uint8_t drvType) {
uint8_t buf[512];
msc1.usbDrive()->readSector(msc1.dataStartSector(), buf);
sd.card()->readSector(sd.dataStartSector(), buf);
for (size_t i = 0; i < 11; i++) {
Serial.write(buf[i]);
return true;
while (!Serial) {
SysCall::yield(); // wait for serial port to connect.
// Start USBHost_t36, HUB(s) and USB devices.
myusb.begin();
Serial.printf("Initialize USB drive...");
void loop(void) {
myusb.Task();
if (!msDrive1) {
Serial.println("Waiting up to 5 seconds for USB drive");
elapsedMillis em = 0;
while (!msDrive1 && (em < 5000) ) myusb.Task();
if (msDrive1) {
if (!msc1.begin(&msDrive1)) {
msc1.errorPrint(&Serial);
Serial.println("initialization failed.\n");
Serial.println("USB drive 1 is present.\n");
if (msc1.fatType() == 32) {
Serial.printf("Fat Type: Fat32\n");
if (!getFat32VolumeLabel(msDrive))
Serial.printf("Failed to get volume label\n");
Serial.printf("Fat Type: ExFat\n");
if (!getExFatVolumeLabel(msDrive))
msc1.ls(LS_SIZE | LS_DATE | LS_R);
Serial.printf("\nInitialize SD card...");
if (!sd.begin(SD_CONFIG)) {
Serial.println("SD card is present.\n");
if (sd.fatType() == 32) {
if (!getFat32VolumeLabel(sdDrive))
Serial.printf("Fat Type: ExFAT\n");
if (!getExFatVolumeLabel(sdDrive)) {
sd.ls(LS_SIZE | LS_DATE | LS_R);
Serial.println("done...");
Serial.println("Press any key to run again");
while (Serial.read() == -1);
while (Serial.read() != -1);
Take this with a grain of salt, but what I am planning to look at includes:Question:
To set up a volume say for an exFat partion I do a:
expartVol.begin(sd.card(), true, 1);
for an SD Card. Now, if I am using a usb drive (non sd). What do I do for a blockdevice or pointer to the device. There is no equivalent .card() for a thumb drive?
In the sketches we have: msController msDrive1(myusb);
Each one of these is for a physical USB drive, I believe it claims the device at an interface level, but I am pretty sure that all of the partitions are one one of these.
And each one of these uses another class: UsbFs msc1;
And the call: if (!msc1.begin(&msDrive1)) {
Starts up the one logical drive using the msDrive1...
And the begin code will sooner or later funnel down to call in the SDFat project:
bool ExFatPartition::init(BlockDevice* dev, uint8_t part);
Or the Fat version:
bool FatPartition::init(BlockDevice* dev, uint8_t part)
Need to walk back to where this one gets called... probably from the begin method which is called by the ...
Question:
UsbFs msc1;
expartVol.begin(msc1.usbDrive(), true, 1);
bool FsVolume::begin(BlockDevice* blockDev) {
Serial.printf("FsVolume::begin(%x)\n", (uint32_t)blockDev);
m_blockDev = blockDev;
m_fVol = nullptr;
m_xVol = new (m_volMem) ExFatVolume;
[COLOR="#FF0000"] if (m_xVol && m_xVol->begin(m_blockDev, false)) {[/COLOR]
goto done;
m_xVol = nullptr;
m_fVol = new (m_volMem) FatVolume;
[COLOR="#FF0000"] if (m_fVol && m_fVol->begin(m_blockDev, false)) {[/COLOR]
goto done;
m_cwv = nullptr;
m_fVol = nullptr;
return false;
done:
m_cwv = this;
return true;
bool mscBegin(msController *pDrive) {
return usbDriveBegin(pDrive) && Vol::begin(m_USBmscDrive);
bool begin(msController *pdrv) {
return mscBegin(pdrv);
msc1 Partition Table
part,boot,bgnCHS[3],type,endCHS[3],start,length
exFAT: 1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,204800000
FAT32: 2,0,0xFE,0xFF,0xFF,0xC,0xFE,0xFF,0xFF,204802048,29634560
3,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
Fat Type: ExFat
Volume Name: New Volume
Fat Type: Fat32
Volume Name: 3��м
bool getFat32VolumeLabel(uint8_t drvType, uint8_t part) {
FatVolume partVol;
uint8_t buf[512];
partVol.begin(msc1.usbDrive(), true, part);
partVol.chvol();
if(drvType == msDrive) {
[COLOR="#FF0000"]msc1.usbDrive()->readSector(dataStart[part],buf);[/COLOR]
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
msController msDrive2(myusb);
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
//FatVolume partVol;
//create holding array for partions
uint8_t partitionTable[4];
int32_t dataStart[4];
bool getExFatVolumeLabel(uint8_t drvType, uint8_t part) {
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
ExFatVolume expartVol;
if (!volName.begin(&msDrive1)) {
return false;
expartVol.begin(msc1.usbDrive(), true, part);
expartVol.chvol();
if (!root.openRoot(&expartVol)) {
return false;
if(drvType == sdDrive) {
return false;
return false;
root.read(buf,32);
Serial.write(dir->unicode[2*i]);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
sd.card()->readSector(sd.dataStartSector(),buf);
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
if (!msc1.usbDrive()->readSector(0, (uint8_t*)&mbr)) {
Serial.print("\nread MBR failed.\n");
//errorPrint();
return false;
Serial.print("\nmsc1 Partition Table\n");
Serial.print("part,boot,bgnCHS[3],type,endCHS[3],start,length\n");
for (uint8_t ip = 1; ip < 5; ip++) {
MbrPart_t *pt = &mbr.part[ip - 1];
// if ((pt->boot != 0 && pt->boot != 0X80) ||
// getLe32(pt->relativeSectors) > sdCardCapacity(&m_csd)) {
// valid = false;
if((pt->type) == 12) Serial.print("FAT32: ");
if((pt->type) == 7) Serial.print("exFAT: ");
partitionTable[ip-1] = pt->type;
dataStart[ip-1] = getLe32(pt->relativeSectors);
Serial.print( int(ip));Serial.print( ',');
Serial.print(int(pt->boot), HEX);Serial.print( ',');
for (int i = 0; i < 3; i++ ) {
Serial.print("0x");Serial.print(int(pt->beginCHS[i]), HEX); Serial.print( ',');
Serial.print("0x");Serial.print(int(pt->type), HEX); Serial.print( ',');
Serial.print("0x");Serial.print(int(pt->endCHS[i]), HEX); Serial.print( ',');
Serial.print(getLe32(pt->relativeSectors), DEC);Serial.print(',');
Serial.println(getLe32(pt->totalSectors));
return true;
while (!Serial) {
myusb.begin();
mbrDmp();
if(msc1.fatType() == 32) {
if(!getFat32VolumeLabel(msDrive))
if(!getExFatVolumeLabel(msDrive,1))
for(uint8_t i = 1; i < 5; i++){
if(partitionTable[i-1] == 7){
if(!getExFatVolumeLabel(msDrive,i))
} else if(partitionTable[i-1] == 12){
if(!getFat32VolumeLabel(msDrive, i))
Serial.println("No or Not Supported Partition");
if(sd.fatType() == 32) {
if(!getFat32VolumeLabel(sdDrive, 1))
if(!getExFatVolumeLabel(sdDrive,1)) {
//sd.ls(LS_SIZE | LS_DATE | LS_R);
void loop(void) {
Fat Type: ExFat
Fat Type: Fat32
Volume Name: ....
2020-12-27 14:47 5725283 VSLAM_and_Navigation_System_of_Unmanned_Ground_Vehicle_Based_on_RGB-D_Camera.pdf
Fat Type: ExFat
Fat Type: Fat32
Volume Name: NEW VOLUME
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
return false;
expartVol.chvol();
return false;
return false;
return false;
root.read(buf,32);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
msc1.usbDrive()->readSector(partVol.dataStartSector(),buf);
partVol.ls(LS_SIZE | LS_DATE | LS_R);
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
//errorPrint();
return false;
// valid = false;
return true;
while (!Serial) {
myusb.begin();
mbrDmp();
void loop(void) {
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
return false;
expartVol.chvol();
return false;
return false;
return false;
root.read(buf, 32);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
msc1.usbDrive()->readSector(partVol.dataStartSector(), buf);
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
//errorPrint();
return false;
// valid = false;
if ((pt->type) == 12) Serial.print("FAT32: ");
if ((pt->type) == 7) Serial.print("exFAT: ");
partitionTable[ip - 1] = pt->type;
dataStart[ip - 1] = getLe32(pt->relativeSectors);
Serial.print( int(ip)); Serial.print( ',');
Serial.print(int(pt->boot), HEX); Serial.print( ',');
Serial.print("0x"); Serial.print(int(pt->beginCHS[i]), HEX); Serial.print( ',');
Serial.print("0x"); Serial.print(int(pt->type), HEX); Serial.print( ',');
Serial.print("0x"); Serial.print(int(pt->endCHS[i]), HEX); Serial.print( ',');
Serial.print(getLe32(pt->relativeSectors), DEC); Serial.print(',');
return true;
while (!Serial) {
myusb.begin();
void loop(void) {
myusb.Task();
if (!msDrive1) {
if (msDrive1) {
mbrDmp();
for (uint8_t i = 1; i < 5; i++) {
if (partitionTable[i - 1] == 7) {
if (!getExFatVolumeLabel(msDrive, i))
} else if (partitionTable[i - 1] == 12) {
if (!getFat32VolumeLabel(msDrive, i))
if (!getFat32VolumeLabel(sdDrive, 1))
if (!getExFatVolumeLabel(sdDrive, 1)) {
connected 1
initialized 0
Initialize USB drive...mscIint()
msReset()
msGetMaxLun()
WaitMediaReady()
msTestReady()
msGetCSW()
msDeviceInquiry()
msDoCommand():
msGetCSW()
msProcessError()
msReadDeviceCapacity()
msDoCommand():
msGetCSW()
msProcessError()
checkConnectedInitialized()
FsVolume::begin(20001c60)
ExFatPartition::init(20001c60, 1)
<<< msReadBlocks(0 1 200)
msDoCommand():
msGetCSW()
msProcessError()
<<< msReadBlocks(800 1 200)
msDoCommand():
msGetCSW()
msProcessError()
msDoCommand():
msGetCSW()
msProcessError()
msDoCommand():
msGetCSW()
msProcessError()
msDoCommand():
msGetCSW()
msProcessError()
1,0,0x4,0x1,0x4,0xB,0xFE,0xC2,0xFF,2048,8192000
2,0,0xE,0x51,0xFE,0xE,0x98,0x98,0x80,8194048,2097152
exFAT: 3,0,0x98,0x99,0x80,0x7,0xEE,0xDC,0xD2,10291200,5435392
Fat Type: ExFat
mscIint()
msReset()
msGetMaxLun()
WaitMediaReady()
msTestReady()
msGetCSW()
msDeviceInquiry()
msDoCommand():
msGetCSW()
msProcessError()
msDoCommand():
msGetCSW()
msProcessError()
ExFatPartition::init(2006fb0c, 1)
msDoCommand():
msGetCSW()
msProcessError()
msDoCommand():
msGetCSW()
msProcessError()
Initialize SD card...FsVolume::begin(200034f0)
ExFatPartition::init(200034f0, 1)
SD card is present.
Fat Type: ExFAT
ExFatPartition::init(2006ff9c, 1)
done...
1,0,0x4,0x1,0x4,[COLOR="#FF0000"]0xB[/COLOR],0xFE,0xC2,0xFF,2048,8192000
2,0,0xE,0x51,0xFE,[COLOR="#FF0000"]0xE,[/COLOR]0x98,0x98,0x80,8194048,2097152
exFAT: 3,0,0x98,0x99,0x80,[COLOR="#FF0000"]0x7[/COLOR],0xEE,0xDC,0xD2,10291200,5435392
Fat Type: ExFat
@all - Wondering in my above Partition table dump you see:
Code:msc1 Partition Table part,boot,bgnCHS[3],type,endCHS[3],start,length 1,0,0x4,0x1,0x4,[COLOR="#FF0000"]0xB[/COLOR],0xFE,0xC2,0xFF,2048,8192000 2,0,0xE,0x51,0xFE,[COLOR="#FF0000"]0xE,[/COLOR]0x98,0x98,0x80,8194048,2097152 exFAT: 3,0,0x98,0x99,0x80,[COLOR="#FF0000"]0x7[/COLOR],0xEE,0xDC,0xD2,10291200,5435392 4,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0 No or Not Supported Partition No or Not Supported Partition Fat Type: ExFat
The three partition types:
Only one was understood 7 for ExFat
The first partition: I formatted for Fat32: Turns out there are at least two different Fat32s.
0xb - FAT32 with CHS addressing - The one that was formatted on it...
0xc - FAT32 with LBA addressing - The one you are looking for
Then the second partition: Fat16 with LBA... Not sure if we support?
There appear to be a few different Fat16, like 4 and 6...
exFAT: 1,0,0x20,0x21,0x0,0x7,0xFE,0xFF,0xFF,2048,234436608
2,0,0x0,0x0,0x0,0x0,0x0,0x0,0x0,0,0
Fat Type: ExFat
Volume Name: 120GB_Ext
Initialize SD card...SD card is present.
Fat Type: Fat32
Volume Name: B
[B][COLOR="#FF0000"]if ( buf[i] > 0 && buf[i] < 127 )[/COLOR][/B]
Initialize USB drive...USB drive 1 is present.
FAT32: 1,80,0x20,0x21,0x0,0xC,0xFE,0xFF,0xFF,2048,67108864
FAT32: 2,0,0xFE,0xFF,0xFF,0xC,0xFE,0xFF,0xFF,67110912,54128640
Fat Type: Fat32
Volume Name: [B][COLOR="#FF0000"]B Info[/COLOR][/B]
2017-10-06 02:44 0 efi/
2017-10-06 02:44 0 boot/
2017-09-18 16:30 1224608 bootx64.efi
2017-10-06 02:44 0 microsoft/
2017-03-18 13:59 16384 BCD
2017-10-06 02:44 0 fonts/
2017-03-18 13:57 3695719 chs_boot.ttf
2018-04-26 19:30 0 ICON/
2018-04-26 19:30 34145 remove.ico
2018-04-26 19:30 0 Metadata/
2018-04-26 19:30 59471 767402d9-4a9b-4b86-a7cc-87ee0b9dda64.devicemetadata-ms
2018-04-26 19:30 132642 7da5fe49-047b-4050-af5d-4db9c0b308b1.devicemetadata-ms
2018-04-26 19:30 59446 90faa471-b2ba-4151-a2ae-42a27fa17081.devicemetadata-ms
2018-04-26 19:30 59468 bbf1d96f-8f14-4421-afd3-00c29d8c5ae0.devicemetadata-ms
2018-04-26 19:30 59445 c4d649ac-a413-49dd-845f-0c1ca1416b1a.devicemetadata-ms
2018-04-26 19:30 137533 cf65cfb5-3970-491b-bb2b-15660bf3abab.devicemetadata-ms
2018-04-26 19:30 59075 d22853f4-2a28-43da-9432-cba889d49fa8.devicemetadata-ms
2018-04-26 19:30 75178 fc02c085-991f-446a-a8c4-c4945bd9f129.devicemetadata-ms
2018-04-26 19:30 280279 ffd10825-4187-4972-bc05-15501fc41dd7.devicemetadata-ms
2017-11-06 16:59 0 PATCH/
2018-04-26 19:30 0 README/
2018-04-26 19:30 81920 AdvProperties.html
2018-04-26 19:30 0 TOOL/
2018-04-26 19:30 256352 RTInstaller32.dat
2018-04-26 19:30 287584 RTInstaller64.dat
2018-04-26 19:30 0 WIN10/
2018-04-26 19:30 0 32/
2018-04-26 19:30 19307 rtux86w10.cat
2018-04-26 19:30 451154 rtux86w10.INF
2018-04-26 19:30 344544 rtux86w10.sys
2018-04-26 19:30 0 64/
2018-04-26 19:30 19340 rtux64w10.cat
2018-04-26 19:30 451154 rtux64w10.INF
2018-04-26 19:30 429024 rtux64w10.sys
done...
[B]Fat Type: Fat32
Volume Name: 64G_PT#2
2021-02-24 09:01 0 FPartTwo.txt
[/B]No or Not Supported Partition
Initialize SD card...initialization failed.
Fat Type: ExFAT
done...
Initialize USB drive...FsVolume::begin(20001b28)
ExFatPartition::init(20001b28, 1)
FAT32: 1,0,0x4,0x1,0x4,0xB,0xFE,0xC2,0xFF,2048,8192000
FAT16: 2,0,0xE,0x51,0xFE,0xE,0x98,0x98,0x80,8194048,2097152
Fat Type: Fat32
Volume Name: FAT32
2010-03-22 07:11 3343737 DSC03357.JPG
2021-01-01 00:00 0 example.txt
Fat Type: Fat16
FatPartition::init(20001b28, 2)
2E 20 20 20 20 20 20 20 20 20 20 10 00 60 AE 6D 56 52 56 52 00 00 AF 6D 56 52 02 00 00 00 00 00 :. ..`.mVRVR...mVR......
2E 2E 20 20 20 20 20 20 20 20 20 10 00 60 AE 6D 56 52 56 52 00 00 AF 6D 56 52 00 00 00 00 00 00 :.. ..`.mVRVR...mVR......
42 74 00 00 00 FF FF FF FF FF FF 0F 00 CE FF FF FF FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF :Bt..............................
01 57 00 50 00 53 00 65 00 74 00 0F 00 CE 74 00 69 00 6E 00 67 00 73 00 2E 00 00 00 64 00 61 00 :.W.P.S.e.t....t.i.n.g.s.....d.a.
57 50 53 45 54 54 7E 31 44 41 54 20 00 64 AE 6D 56 52 58 52 00 00 AF 6D 56 52 03 00 0C 00 00 00 :WPSETT~1DAT .d.mVRXR...mVR......
42 47 00 75 00 69 00 64 00 00 00 0F 00 FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 FF FF FF FF :BG.u.i.d........................
01 49 00 6E 00 64 00 65 00 78 00 0F 00 FF 65 00 72 00 56 00 6F 00 6C 00 75 00 00 00 6D 00 65 00 :.I.n.d.e.x....e.r.V.o.l.u...m.e.
49 4E 44 45 58 45 7E 31 20 20 20 20 00 7B 11 5D 58 52 58 52 00 00 12 5D 58 52 19 00 4C 00 00 00 :INDEXE~1 .{.]XRXR...]XR..L...
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 :................................
Volume Name: .
2021-01-13 17:56 340510 T4-Cardlike.jpg
Fat Type: ExFat
Initialize SD card...FsVolume::begin(200033b0)
ExFatPartition::init(200033b0, 1)
SD card is present.
Fat Type: ExFAT
done...
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
return false;
expartVol.chvol();
return false;
return false;
return false;
root.read(buf, 32);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
return true;
// Get Fat16 volume name.
bool getFat16VolumeLabel(uint8_t drvType, uint8_t part) {
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
print_hexbytes(buf, 512);
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
//errorPrint();
return false;
// valid = false;
switch (pt->type) {
case 4:
case 6:
case 0xe:
Serial.print("FAT16: ");
case 11:
case 12:
case 7:
return true;
while (!Serial) {
myusb.begin();
void loop(void) {
myusb.Task();
if (!msDrive1) {
if (msDrive1) {
mbrDmp();
switch (partitionTable[i - 1]) {
case 11:
case 12:
case 4:
case 6:
case 0xe:
Serial.printf("Fat Type: Fat16\n");
if (!getFat16VolumeLabel(msDrive, i))
case 7:
default:
void print_hexbytes(const void *ptr, int len)
if (ptr == NULL || len <= 0) return;
const uint8_t *p = (const uint8_t *)ptr;
while (len) {
for (uint8_t i = 0; i < 32; i++) {
if (i > len) break;
Serial.printf("%02X ", p[i]);
Serial.print(":");
if (i > len) break;
Serial.printf("%c", ((p[i] >= ' ') && (p[i] <= '~')) ? p[i] : '.');
p += 32;
len -= 32;
Fat Type: ExFAT
done...
FAT32: >>>pt->type: 12
1,80,0x20,0x21,0x0,0xC,0xFE,0xFF,0xFF,2048,30963712
>>>pt->type: 0
>>>pt->type: 0
>>>pt->type: 0
Fat Type: Fat32
[B]Volume Name: B Info[/B]
2020-05-10 23:45 128 autorun.inf
2020-05-30 16:22 0 boot/
2020-05-10 23:45 16384 bcd
2020-05-10 23:45 3170304 boot.sdi
2020-05-10 23:45 1024 bootfix.bin
2020-05-10 23:45 110392 bootsect.exe
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
Serial.println("EXFat volName.begin failed");
return false;
expartVol.chvol();
return false;
return false;
return false;
root.read(buf, 32);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
return true;
FatVolume partVol;
MbrSector_t mbr;
uint8_t buf[512];
partVol.chvol();
// lets read in the Master boot record...
msc1.usbDrive()->readSector(0, (uint8_t*)&mbr);
MbrPart_t *pt = &mbr.part[part - 1];
uint32_t starting_sector = getLe32(pt->relativeSectors);
msc1.usbDrive()->readSector(starting_sector, buf);
Serial.printf("\nFAT first sector:(%x)\n", starting_sector);
pbs_t* pbs = (pbs_t*)&buf;
BpbFat16_t *bpt16 = reinterpret_cast<BpbFat16_t*>(pbs->bpb);
Serial.write(bpt16->volumeLabel[i]);
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
//errorPrint();
return false;
// valid = false;
switch (pt->type) {
case 4:
case 6:
case 0xe:
case 11:
case 12:
case 7:
return true;
while (!Serial) {
myusb.begin();
void loop(void) {
myusb.Task();
if (!msDrive1) {
if (msDrive1) {
mbrDmp();
case 11:
case 12:
Serial.printf("\nFat Type: Fat32\n");
case 4:
case 6:
case 0xe:
Serial.printf("\nFat Type: Fat16\n");
case 7:
Serial.printf("\nFat Type: ExFat\n");
default:
while (len) {
if (i > len) break;
Serial.print(":");
if (i > len) break;
p += 32;
len -= 32;
Initialize USB drive...FsVolume::begin(20001b70)
ExFatPartition::init(20001b70, 1)
Fat Type: Fat32
Volume Name: VOLFAT32
2021-02-24 16:35 0 OnFat32.txt
Fat Type: Fat16
FatPartition::init(20001b70, 2)
FAT first sector:(7d0800)
EB 3C 90 4D 53 44 4F 53 35 2E 30 00 02 20 08 00 02 00 02 00 00 F8 00 01 3F 00 FF 00 00 08 7D 00 :.<.MSDOS5.0.. ..........?.....}.
00 00 20 00 80 00 29 19 4C 09 02 4E 4F 20 4E 41 4D 45 20 20 20 20 46 41 54 31 36 20 20 20 33 C9 :.. ...).L..NO NAME FAT16 3.
8E D1 BC F0 7B 8E D9 B8 00 20 8E C0 FC BD 00 7C 38 4E 24 7D 24 8B C1 99 E8 3C 01 72 1C 83 EB 3A :....{.... .....|8N$}$....<.r...:
66 A1 1C 7C 26 66 3B 07 26 8A 57 FC 75 06 80 CA 02 88 56 02 80 C3 10 73 EB 33 C9 8A 46 10 98 F7 :f..|&f;.&.W.u.....V....s.3..F...
66 16 03 46 1C 13 56 1E 03 46 0E 13 D1 8B 76 11 60 89 46 FC 89 56 FE B8 20 00 F7 E6 8B 5E 0B 03 :f..F..V..F....v.`.F..V.. ....^..
C3 48 F7 F3 01 46 FC 11 4E FE 61 BF 00 00 E8 E6 00 72 39 26 38 2D 74 17 60 B1 0B BE A1 7D F3 A6 :.H...F..N.a......r9&8-t.`....}..
61 74 32 4E 74 09 83 C7 20 3B FB 72 E6 EB DC A0 FB 7D B4 7D 8B F0 AC 98 40 74 0C 48 74 13 B4 0E :at2Nt... ;.r.....}.}....@t.Ht...
BB 07 00 CD 10 EB EF A0 FD 7D EB E6 A0 FC 7D EB E1 CD 16 CD 19 26 8B 55 1A 52 B0 01 BB 00 00 E8 :.........}....}......&.U.R......
3B 00 72 E8 5B 8A 56 24 BE 0B 7C 8B FC C7 46 F0 3D 7D C7 46 F4 29 7D 8C D9 89 4E F2 89 4E F6 C6 :;.r.[.V$..|...F.=}.F.)}...N..N..
06 96 7D CB EA 03 00 00 20 0F B6 C8 66 8B 46 F8 66 03 46 1C 66 8B D0 66 C1 EA 10 EB 5E 0F B6 C8 :..}..... ...f.F.f.F.f..f....^...
4A 4A 8A 46 0D 32 E4 F7 E2 03 46 FC 13 56 FE EB 4A 52 50 06 53 6A 01 6A 10 91 8B 46 18 96 92 33 :JJ.F.2....F..V..JRP.Sj.j...F...3
D2 F7 F6 91 F7 F6 42 87 CA F7 76 1A 8A F2 8A E8 C0 CC 02 0A CC B8 01 02 80 7E 02 0E 75 04 B4 42 :......B...v..............~..u..B
8B F4 8A 56 24 CD 13 61 61 72 0B 40 75 01 42 03 5E 0B 49 75 06 F8 C3 41 BB 00 00 60 66 6A 00 EB :...V$..aar.@u.B.^.Iu...A...`fj..
B0 42 4F 4F 54 4D 47 52 20 20 20 20 0D 0A 52 65 6D 6F 76 65 20 64 69 73 6B 73 20 6F 72 20 6F 74 :.BOOTMGR ..Remove disks or ot
68 65 72 20 6D 65 64 69 61 2E FF 0D 0A 44 69 73 6B 20 65 72 72 6F 72 FF 0D 0A 50 72 65 73 73 20 :her media....Disk error...Press
61 6E 79 20 6B 65 79 20 74 6F 20 72 65 73 74 61 72 74 0D 0A 00 00 00 00 00 00 00 AC CB D8 55 AA :any key to restart............U.
Volume Name: NO NAME
2021-02-24 16:34 0 OnFat16.txt
Fat Type: ExFat
Initialize SD card...FsVolume::begin(200033f0)
ExFatPartition::init(200033f0, 1)
SD card is present.
Fat Type: ExFAT
done...
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
return false;
expartVol.chvol();
return false;
return false;
return false;
root.read(buf, 32);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
return true;
FatVolume partVol;
MbrSector_t mbr;
uint8_t buf[512];
partVol.chvol();
msc1.usbDrive()->readSector(partVol.rootDirStart(), buf);
// print_hexbytes(buf, 512);
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
//errorPrint();
return false;
// valid = false;
switch (pt->type) {
case 4:
case 6:
case 0xe:
case 11:
case 12:
case 7:
return true;
while (!Serial) {
myusb.begin();
void loop(void) {
myusb.Task();
if (!msDrive1) {
if (msDrive1) {
mbrDmp();
case 11:
case 12:
case 4:
case 6:
case 0xe:
case 7:
default:
while (len) {
if (i > len) break;
Serial.print(":");
if (i > len) break;
p += 32;
len -= 32;
Initialize USB drive...FsVolume::begin(20001b58)
ExFatPartition::init(20001b58, 1)
Fat Type: Fat32
Fat Type: Fat16
FatPartition::init(20001b58, 2)
Volume Name: VOLFAT16
Fat Type: ExFat
SD card is present.
Fat Type: ExFAT
done...
FAT16: 1,80,0x1,0x1,0x0,0xE,0xFE,0x3F,0x79,63,1974208
Fat Type: Fat16
2020-11-17 13:56 220021 T4.1-Cardlike0.jpg
sd.card()->readSector(sd.rootDirStart(), buf);
Fat Type: ExFAT
done...
Fat Type: Fat32
Volume Name: B
// VolumeName.ino
#include "mscFS.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
USBHub hub4(myusb);
IntervalTimer clocked100ms;
volatile int32_t cmsReport = -1;
#define sdDrive 1
#define msDrive 2
UsbFs msc1;
SdFs sd;
uint8_t buf[32];
UsbExFat volName;
SdExFat volName1;
ExFatFile root;
DirLabel_t *dir;
return false;
expartVol.chvol();
return false;
return false;
return false;
root.read(buf, 32);
return true;
FatVolume partVol;
uint8_t buf[512];
partVol.chvol();
return true;
// Get Fat16 .
FatVolume partVol;
MbrSector_t mbr;
uint8_t buf[512];
partVol.chvol();
return true;
bool mbrDmp() {
MbrSector_t mbr;
bool valid = true;
//errorPrint();
return false;
// valid = false;
switch (pt->type) {
case 4:
case 6:
case 0xe:
case 11:
case 12:
case 7:
return true;
#if 0 // easy test to check HardFault Detection response
int *pp=0;
*pp=5;
while (!Serial) {
myusb.begin();
[B]//#define SHOW_CLOCK_CARAT 1
#ifdef SHOW_CLOCK_CARAT
clocked100ms.begin(clock_isr, 100000);
[/B]
void clock_isr() {
if (cmsReport >= 0 ) {
if (cmsReport > 0 ) {
if (cmsReport <10 )
Serial.print( "^");
else if ( !(cmsReport%10) )
Serial.print( "~");
cmsReport++;
void loop(void) {
[B] cmsReport=0;
[/B] myusb.Task();
if (!msDrive1) {
if (msDrive1) {
[B] cmsReport=-1;
[/B]
mbrDmp();
case 11:
case 12:
case 4:
case 6:
case 0xe:
case 7:
default:
[B] cmsReport=-1;
[/B] //--------------------------------------------------
while (len) {
if (i > len) break;
Serial.print(":");
if (i > len) break;
p += 32;
len -= 32;
USBHS_USBCMD = USBHS_USBCMD_ITC(1) | USBHS_USBCMD_RS |
^Waiting up to 5 seconds for USB drive
^^Initialize USB drive...^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^Waiting up to 5 seconds for USB drive
Fat Type: ExFAT
done...
Initialize USB drive...^^^^^^^^^USB drive 1 is present.
^^^^^^^^^^^^^Initialize USB drive...USB drive 1 is present.
