Full debug output from T_3.6 noted below : [B][ATTACH]16624._xfImport[/ATTACH]
msController CallbackIn (static)
transfer->qtd.token = 0
msController dataIn (static): 13
55 53 42 53 4E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
<dir> System Volume Information
17173152 SDTEST4.WAV
0 SomeFile.txt
8894873 workshop.pdf
16787550 SDTEST1.WAV
16425698 SDTEST2.WAV
13617358 SDTEST3.WAV
<dir> Ascii
<dir> Binary
Test completed.
USB2 PLL running
reset waited 6
USBHS_ASYNCLISTADDR = 0
USBHS_PERIODICLISTBASE = 20004000
periodictable = 20004000
port change: 10001803
connect
begin reset
port change: 18001205
port enabled
end recovery
new_Device: 480 Mbit/sec
new_Pipe
upload@5794870-Teensy Uploading to board '5794870-Teensy' (Teensy 4.0)
upload@5794870-Teensy Triggering board reboot
upload@5794870-Teensy SetCommState() failed on '\\.\COM25': The semaphore timeout period has expired.
** CSWSIGNATURE
0 SomeFile.txt
<dir> Ascii
<dir> Binary
Test completed.
sizeof Device = 36
sizeof Pipe = 96
sizeof Transfer = 64
power up USBHS PHY
reset waited 5
USBHS_PERIODICLISTBASE = 1FFF4000
periodictable = 1FFF4000
upload@2272100-Teensy Uploading to board '2272100-Teensy' (Teensy 3.6)
upload@2272100-Teensy Triggering board reboot
upload@2272100-Teensy Reboot didn't work, press button manually
upload@2272100-Teensy Board '2272100-Teensy' has disappeared
Test uSDFS
1:/
Change drive
Create a new subdirectories.
Create a new file /Ascii/HELLO13.TXT.
Write some text lines. (Hello world!)
Close the file.
Open same file /Ascii/HELLO13.TXT.
Get the file content.
Hello world!
Second Line
Third Line
Fourth Line
Habe keine Phantasie
Close the file.
open binary file
write file
close file
Binary test done
Open root directory.
Directory listing...
0 SomeFile.txt
<dir> Ascii
<dir> Binary
Test completed.
[COLOR="#FF0000"]Test logger_RawWrite
2:/[/COLOR]
USB2 PLL running
reset waited 6
USBHS_PERIODICLISTBASE = 20014000
periodictable = 20014000
connect
begin reset
port enabled
end recovery
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 10 02 00 00 00 40 64 85 00 10 00 11 01 02 03 01
VendorID = 8564, ProductID = 1000, Version = 1100
Class/Subclass/Protocol = 0 / 0 / 0
Number of Configurations = 1
enumeration:
enumeration:
Manufacturer: JetFlash
enumeration:
Product: Mass Storage Device
enumeration:
Serial Number: 17Q880DIDAVC35MP
enumeration:
Config data length = 32
enumeration:
Configuration Descriptor:
09 02 20 00 01 01 00 80 96
NumInterfaces = 1
ConfigurationValue = 1
09 04 00 00 02 08 06 50 00
Interface = 0
Number of endpoints = 2
Class/Subclass/Protocol = 8(Mass Storage) / 6(SCSI) / 80(Bulk Only)
07 05 01 02 00 02 00
Endpoint = 1 OUT
Type = Bulk
Max Size = 512
Polling Interval = 0
07 05 82 02 00 02 00
Endpoint = 2 IN
Type = Bulk
Max Size = 512
enumeration:
msController claim this=20013780
Descriptor 4 = INTERFACE
09 04 00 00 02 08 06 50 00 07 05 01 02 00 02 00 07 05 82 02 00 02 00
numendpoint=2
endpointIn=82
endpointOut=1
packet size in (msController) = 512
packet size out (msController) = 512
polling intervalIn = 0
polling intervalOut = 0
new_Pipe
new_Pipe
Descriptor 5 = ENDPOINT
control CallbackIn (msController)
msController CallbackOut (static)
msController dataOut (static)31
55 53 42 43 02 00 00 00 00 00 00 00 80 00 06 1B 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 02 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 03 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 03 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 04 00 00 00 24 00 00 00 80 00 06 12 00 00 00 24 00 00 00 00 00 00 00 00 00 00 00
msController dataIn (static): 36
00 80 06 02 1F 73 6D 69 4A 65 74 46 6C 61 73 68 54 72 61 6E 73 63 65 6E 64 20 38 47 42 20 20 20
55 53 42 53 04 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 05 00 00 00 08 00 00 00 80 00 0A 25 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
msController dataIn (static): 8
00 E1 3F FF 00 00 02 00
55 53 42 53 05 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 06 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 06 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 07 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00
msController dataIn (static): 512
00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 07 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 08 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 08 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 09 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 20 00 00 00 01 00 00 00 00 00 00 00
EB 76 90 45 58 46 41 54 20 20 20 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 09 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 0A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 0A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 0B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 80 00 00 01 00 00 00 00 00 00 00
83 09 54 00 52 00 41 00 4E 00 53 00 43 00 45 00 4E 00 44 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 0B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 0C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 0C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 0D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 28 00 00 00 01 00 00 00 00 00 00 00
F8 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 0D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
[COLOR="#FF0000"]Free Disk Size -1 clusters
Cluster Size 64 sectors
Sector Size 512 bytes
Change drive
X_00001.dat[/COLOR]
55 53 42 43 0E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 0E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 0F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 80 00 00 01 00 00 00 00 00 00 00
55 53 42 53 0F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 10 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 10 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 11 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 81 00 00 01 00 00 00 00 00 00 00
85 02 DA E7 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 11 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 12 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 12 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 13 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 82 00 00 01 00 00 00 00 00 00 00
C0 01 00 0B BB 70 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 F0 03 00 00 00 00 7D 00 00 00 00 00
55 53 42 53 13 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 14 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 14 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 15 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 83 00 00 01 00 00 00 00 00 00 00
C1 00 5A 00 5F 00 30 00 30 00 30 00 31 00 34 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
55 53 42 53 15 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 16 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 16 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 17 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 84 00 00 01 00 00 00 00 00 00 00
85 02 59 2B 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 17 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 18 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 18 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 19 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 85 00 00 01 00 00 00 00 00 00 00
C0 01 00 0B FB 6E 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 C0 0B 00 00 00 00 7D 00 00 00 00 00
55 53 42 53 19 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 1A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 1A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 1B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 86 00 00 01 00 00 00 00 00 00 00
C1 00 5A 00 5F 00 30 00 30 00 30 00 33 00 30 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
55 53 42 53 1B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 1C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 1C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 1D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 87 00 00 01 00 00 00 00 00 00 00
85 02 44 52 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 1D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 1E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 1E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 1F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 88 00 00 01 00 00 00 00 00 00 00
C0 03 00 0B 3B 6D 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 0C 29 00 00 00 00 7D 00 00 00 00 00
55 53 42 53 1F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 20 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 20 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 21 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 89 00 00 01 00 00 00 00 00 00 00
C1 00 5A 00 5F 00 30 00 30 00 30 00 34 00 36 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
55 53 42 53 21 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 22 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 22 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 23 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8A 00 00 01 00 00 00 00 00 00 00
85 02 82 B1 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 23 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 24 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 24 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 25 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8B 00 00 01 00 00 00 00 00 00 00
C0 03 00 0B 5B 70 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 AC 38 00 00 00 00 7D 00 00 00 00 00
55 53 42 53 25 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 26 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 26 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 27 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8C 00 00 01 00 00 00 00 00 00 00
C1 00 5A 00 5F 00 30 00 30 00 30 00 36 00 32 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
55 53 42 53 27 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 28 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 28 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 29 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8D 00 00 01 00 00 00 00 00 00 00
85 02 45 CE 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 29 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 2A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 2A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 2B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8E 00 00 01 00 00 00 00 00 00 00
C0 03 00 0B 9B 6E 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 4C 48 00 00 00 00 7D 00 00 00 00 00
55 53 42 53 2B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 2C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 2C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 2D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8F 00 00 01 00 00 00 00 00 00 00
C1 00 5A 00 5F 00 30 00 30 00 30 00 37 00 38 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
55 53 42 53 2D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 2E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 2E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 2F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 90 00 00 01 00 00 00 00 00 00 00
85 02 03 EE 20 00 00 00 00 00 21 50 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 2F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 30 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 30 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 31 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 91 00 00 01 00 00 00 00 00 00 00
C0 03 00 0B BB 71 00 00 00 00 7D 00 00 00 00 00 00 00 00 00 EC 57 00 00 00 00 7D 00 00 00 00 00
55 53 42 53 31 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 32 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 32 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 33 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 92 00 00 01 00 00 00 00 00 00 00
C1 00 5A 00 5F 00 30 00 30 00 30 00 39 00 34 00 2E 00 64 00 61 00 74 00 00 00 00 00 00 00 00 00
55 53 42 53 33 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 34 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 34 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 35 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 93 00 00 01 00 00 00 00 00 00 00
85 02 D0 8F 20 00 00 00 00 00 21 50 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 35 00 00 00 00 00 00 00 00
** CSWSIGNATURE
stat FR_OK 0
55 53 42 43 36 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 36 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 37 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 80 00 00 01 00 00 00 00 00 00 00
55 53 42 53 37 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 38 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 38 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 39 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 81 00 00 01 00 00 00 00 00 00 00
55 53 42 53 39 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 3A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 3A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 3B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 82 00 00 01 00 00 00 00 00 00 00
55 53 42 53 3B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 3C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 3C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 3D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 83 00 00 01 00 00 00 00 00 00 00
55 53 42 53 3D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 3E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 3E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 3F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 84 00 00 01 00 00 00 00 00 00 00
55 53 42 53 3F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 40 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 40 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 41 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 85 00 00 01 00 00 00 00 00 00 00
55 53 42 53 41 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 42 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 42 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 43 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 86 00 00 01 00 00 00 00 00 00 00
55 53 42 53 43 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 44 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 44 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 45 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 87 00 00 01 00 00 00 00 00 00 00
55 53 42 53 45 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 46 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 46 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 47 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 88 00 00 01 00 00 00 00 00 00 00
55 53 42 53 47 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 48 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 48 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 49 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 89 00 00 01 00 00 00 00 00 00 00
55 53 42 53 49 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 4A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 4A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 4B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8A 00 00 01 00 00 00 00 00 00 00
55 53 42 53 4B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 4C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 4C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 4D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8B 00 00 01 00 00 00 00 00 00 00
55 53 42 53 4D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 4E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 4F 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8C 00 00 01 00 00 00 00 00 00 00
55 53 42 53 4F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 50 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 50 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 51 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8D 00 00 01 00 00 00 00 00 00 00
55 53 42 53 51 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 52 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 52 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 53 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8E 00 00 01 00 00 00 00 00 00 00
55 53 42 53 53 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 54 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 54 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 55 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 8F 00 00 01 00 00 00 00 00 00 00
55 53 42 53 55 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 56 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 56 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 57 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 90 00 00 01 00 00 00 00 00 00 00
55 53 42 53 57 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 58 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 58 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 59 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 91 00 00 01 00 00 00 00 00 00 00
55 53 42 53 59 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 5A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 5A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 5B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 92 00 00 01 00 00 00 00 00 00 00
55 53 42 53 5B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 5C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 5C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 5D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 93 00 00 01 00 00 00 00 00 00 00
55 53 42 53 5D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
opened FR_OK 0
55 53 42 43 5E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 5E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 5F 00 00 00 00 02 00 00 00 00 0A 2A 00 00 00 30 93 00 00 01 00 00 00 00 00 00 00
msController dataOut (static)512
55 53 42 53 5F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 60 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 60 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 61 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 00 00 00 01 00 00 00 00 00 00 00
FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
55 53 42 53 61 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 62 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 62 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 63 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 01 00 00 01 00 00 00 00 00 00 00
55 53 42 53 63 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 64 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 64 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 65 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 02 00 00 01 00 00 00 00 00 00 00
55 53 42 53 65 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 66 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 66 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 67 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 03 00 00 01 00 00 00 00 00 00 00
55 53 42 53 67 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 68 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 68 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 69 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 04 00 00 01 00 00 00 00 00 00 00
55 53 42 53 69 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 6A 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 6A 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 6B 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 05 00 00 01 00 00 00 00 00 00 00
55 53 42 53 6B 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 6C 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 6C 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 6D 00 00 00 00 02 00 00 80 00 0A 28 00 00 00 30 06 00 00 01 00 00 00 00 00 00 00
55 53 42 53 6D 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 6E 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
55 53 42 53 6E 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 6F 00 00 00 00 80 00 00 00 00 0A 2A 00 00 19 18 80 00 00 40 00 00 00 00 00 00 00
upload@2272100-Teensy Uploading to board '2272100-[B]Teensy' (Teensy 3.6)[/B]
[B]8192<< BUFFSIZE _ Dev Type >>2:/[/B]
Change drive
Z_00001.dat
stat FR_OK 0
[COLOR="#FF0000"] opened 0 0
// THEN NOTHING[/COLOR]
[B]2048<< BUFFSIZE _ Dev Type >>2:/[/B]
Change drive
Z_00001.dat
stat FR_OK 0
opened 0 0
.................................... (7111926 - 1.151868 MB/s)
(open: 5064 us; close: 25000 us; write: min,max: 4945 191951 us)
while(!Serial);
Serial.println("Test logger_RawWrite");
[B][U] Serial.print(BUFFSIZE);
Serial.print("<< BUFFSIZE _ Dev Type >>");
[/U][/B] Serial.println(Dev);
Z_00008.dat
stat FR_OK 1586
opened 0 0
.................................... (7109975 - 1.152184 MB/s)
(open: 238928 us; close: 24999 us; write: min,max: 4945 [COLOR="#FF0000"]585951[/COLOR] us)
// last qTD needs info for followup
data->qtd.next = 1;
data->pipe = pipe;
data->buffer = buffer;
data->length = len;
data->setup.word1 = 0;
data->setup.word2 = 0;
data->driver = driver;
// initialize all qTDs
data = transfer;
while (1) {
uint32_t count = len;
if (count > 16384) {
count = 16384;
last = true;
init_qTD(data, p, count, pipe->direction, 0, last);
if (last) break;
p += count;
len -= count;
data = (Transfer_t *)(data->qtd.next);
else { // Data to device
queue_Data_Transfer(datapipeOut, CBW, sizeof(msCommandBlockWrapper_t), this);
[COLOR="#FF0000"]if(CBW->CommandData[0]==CMDWR10) println("A");[/COLOR]
while(!msOutCompleted); // Wait for out transaction to complete.
[COLOR="#FF0000"]if(CBW->CommandData[0]==CMDWR10) println("B");[/COLOR]
msOutCompleted = false;
queue_Data_Transfer(datapipeOut, buffer, CBW->TransferLength, this);
[COLOR="#FF0000"]if(CBW->CommandData[0]==CMDWR10) println("C");[/COLOR]
while(!msOutCompleted); // Wait for second out transaction to complete.
[COLOR="#FF0000"]if(CBW->CommandData[0]==CMDWR10) println("D");[/COLOR]
if((CSWResult = msGetCSW()) != 0)
return CSWResult;
[COLOR="#FF0000"]Write 191880 64
TransferLength 32768 CommandData 2A 0 0 19 18 80 0 0 40 0
A[/COLOR]
[COLOR="#FF0000"]B
C[/COLOR]
[COLOR="#FF0000"]Write 191880 32
TransferLength 16384 CommandData 2A 0 0 19 18 80 0 0 20 0
A[/COLOR]
55 53 42 43 6F 00 00 00 00 40 00 00 00 00 0A 2A 00 00 19 18 80 00 00 20 00 00 00 00 00 00 00
[COLOR="#FF0000"]B
C[/COLOR]
[COLOR="#FF0000"]D[/COLOR]
55 53 42 53 6F 00 00 00 00 00 00 00 00
** CSWSIGNATURE
55 53 42 43 70 00 00 00 00 00 00 00 80 00 06 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Write 103c6 1
TransferLength 512 CommandData 2A 0 0 1 3 C6 0 0 1 0
A
55 53 42 43 29 00 00 00 00 02 00 00 00 00 0A 2A 00 00 01 03 C6 00 00 01 00 00 00 00 00 00 00
B
C
[B]msController dataOut (static)512[/B]
5A 5F 30 30 30 39 36 20 44 41 54 20 10 00 00 00 21 50 00 00 00 00 00 00 21 50 62 5D 00 00 7D 00
D
** CSWSIGNATURE
EndWrite
D
Write 199440 32
TransferLength 16384 CommandData 2A 0 0 19 94 40 0 0 20 0
A
55 53 42 43 2D 00 00 00 00 40 00 00 00 00 0A 2A 00 00 19 94 40 00 00 20 00 00 00 00 00 00 00
B
C
[B]msController dataOut (static)31[/B]
D
** CSWSIGNATURE
EndWrite
Using Post #78 zip and github : ...\libraries\uSDFS\examples\uSDFS_test\uSDFS_test.ino
Compiled and built for T$ - using SD card as #1_SDHC the card works. Moving that card to #2_USB in a USB adapter - get TONS of spew that ends like this:
[/B]Code:Full debug output from T_3.6 noted below : [B][ATTACH]16624[/ATTACH]
Code:…...
So it see the files then goes into an odd state were the #1 interface ended with a blink, the #2 ends with LED ON?
And the T$ is in an odd state - it won't take an upload without a button press - or placed into bootloader before?
Using TyCommander from SublimeText editor:
Putting this code and same card on a T_3.6 [ FrankB Teensy64 ] it is similar and asking for fresh upload turns off LED and the T_3.6 disappears >> Full text attached above:
Using TyCommander from SublimeText editor:Code:…..
And like the T$ - on the T_3.6 same code on #1 SDHC leaves it running with LED blink on same card:Code:…..
Code:…
Test uSDFS
0:/
Change drive
Close the file.
Hello world!
Second Line
Third Line
Fourth Line
Close the file.
open binary file
write file
close file
Binary test done
29162 DATALOG.TXT
<dir> Ascii
772140 operational.wav
<dir> 2001
<dir> Flac
30401785 Berlin - Take My Breathe Away theme from Top Gun with Lyrics.flac
3177823 Christina Aguilera - Candyman (2009) 720p.aac
0 mtpindex.dat
21430 odd.mp3
46888 odd1.mp3
489461 zarathustra.mp3
553004 odd1.wav
16787550 SDTEST1.wav
426300 calculations.wav
<dir> Binary
131072000 Z_00001.dat
131072000 Z_00002.dat
131072000 Z_00003.dat
131072000 Z_00004.dat
131072000 Z_00005.dat
0 Z_00006.dat
Test completed.
EDIT: OK if I run the same test on USB I see the same issue with the T$ as you do
Is the extra while for "D" needed - seems to be there for A,B, and C
uint8_t msController::msDoCommand(msCommandBlockWrapper_t *CBW, void *buffer)
if(CBWTag == 0xFFFFFFFF)
CBWTag = 1;
if((CBW->Flags == CMDDIRDATAIN)) { // Data from device
if (!queue_Data_Transfer(datapipeOut, CBW, sizeof(msCommandBlockWrapper_t), this)) {
println("msController::msDoCommand QDT failed CMDDIRDATAIN OUT");
if (!queue_Data_Transfer(datapipeIn, buffer, CBW->TransferLength, this)) {
println("msController::msDoCommand QDT failed CMDDIRDATAIN IN");
while(!msInCompleted); // Wait for in transaction to complete.
} else { // Data to device
println("msController::msDoCommand QDT failed ELSE OUT");
if (!queue_Data_Transfer(datapipeOut, buffer, CBW->TransferLength, this)) {
println("msController::msDoCommand QDT failed ELSE OUT 2");
// Reset completion flags.
msInCompleted = false;
return msGetCSW(); // Get status of last transaction
//Copyright 2019 by Walter Zimmer
// Version 07-may-19
#include "uSDFS.h"
#include <USBHost_t36.h>
extern USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
#define TEST_DRV 2
#if TEST_DRV == 0
const char *Dev = "0:/"; // SPI
#elif TEST_DRV == 1
const char *Dev = "1:/"; // SDHC
#elif TEST_DRV == 2
const char *Dev = "2:/"; // USB
for (count=(len >> 14); count; count--) {
next = allocate_Transfer();
if (!next) {
// free already-allocated qTDs
while (1) {
next = (Transfer_t *)transfer->qtd.next;
free_Transfer(transfer);
if (transfer == data) break;
transfer = next;
return false;
data->qtd.next = (uint32_t)next;
data = next;
while (1) {
count = 16384;
last = true;
if (last) break;
p += count;
len -= count;
return queue_Transfer(pipe, transfer);
Got it
IMO, the line must read
for 16k and smaller there should be no additional transactionCode:for (count=((len-1) >> 14); count; count--) {
I agree, other than I also put that test in a conditional if (count)...
Not sure what it would do with 0 count, but...
Maybe someone will beat me to it, I did push up a change into my PS3_Motion.... branch, but have not tried to see if it fixes all of the issues yet.I let you the mods and PR
2:/
Change drive
Z_00001.dat
stat FR_OK 0
opened FR_OK 0
.................................... (29888996 - 4.385293 MB/s)
(open: 366048 us; close: 20000 us; write: min,max: 23889 247891 us)
Z_00002.dat
stat FR_OK 801
opened FR_OK 0
.................................... (30065996 - 4.359477 MB/s)
(open: 361989 us; close: 20000 us; write: min,max: 23889 249891 us
Z_00001.dat
stat FR_OK 0
opened FR_OK 0
.................................... (968335988 - 0.135358 MB/s)
(open: 4051 us; close: 390000 us; write: min,max: 626891 1846877 us)
2:/
Change drive
Z_00001.dat
stat FR_NO_FILE 0
opened FR_OK 0
.................................... (62346995 - 2.102298 MB/s)
(open: 76045 us; close: 25000 us; write: min,max: 39889 2925891 us)
For the heck of it I tried it with my SSD external drive but got an error:
It did write the file name thoughCode:Change drive Z_00001.dat stat FR_OK 0 opened FR_OK 0 write FR_DISK_ERR
Serial.printf(" write FR_DISK_ERR at count #%d\n",count);
Here is today MSC.zip from mjs513 with the uSDFS_Files directory removed.
Code:[ATTACH]16622[/ATTACH]
this MSCv3 did build ...
USBHost_t36 updates working with this : https://github.com/KurtE/USBHost_t36/tree/PS3_Motion_WIP2-Bluetooth
sizeof Device = 36
sizeof Pipe = 96
power up USBHS PHY
reset waited 5
USBHS_PERIODICLISTBASE = 1FFF5000
periodictable = 1FFF5000
connect
begin reset
port enabled
end recovery
new_Pipe
enumeration:
enumeration:
enumeration:
Device Descriptor:
12 01 00 02 00 00 00 40 30 09 45 65 00 01 01 02 03 01
VendorID = 0930, ProductID = 6545, Version = 0100
enumeration:
enumeration:
Manufacturer: Kingston
enumeration:
Product: DataTraveler SE9
enumeration:
Serial Number: 001D0F1F90CAECB0472700A4
enumeration:
enumeration:
09 02 20 00 01 01 00 80 64
NumInterfaces = 1
Interface = 0
07 05 81 02 00 02 00
Endpoint = 1 IN
Type = Bulk
Max Size = 512
07 05 02 02 00 02 00
Endpoint = 2 OUT
Type = Bulk
Max Size = 512
enumeration:
new_Pipe
new_Pipe
@defragster
All I did was to download Kurt's USBHost_t36 ps3_Move_bluetooth branch and substitute it for what is installed with Teensyduino. Did not touch MSC.h at all as far as I know.
"T:\\TEMP\\arduino_build_logger_RawWrite.ino/logger_RawWrite.ino.elf"
Multiple libraries were found for "USBHost_t36.h"
Used: T:\tCode\libraries\USBHost_t36
Not used: T:\Ard186t4b2\hardware\teensy\avr\libraries\USBHost_t36
Using library uSDFS at version 1.1.0 in folder: T:\tCode\libraries\uSDFS [COLOR="#FF0000"]:: 12 May WMXZ github[/COLOR]
Using library MSC at version 1.0.0 in folder: T:\tCode\libraries\MSC [COLOR="#FF0000"]:: posted MSCV3 zip[/COLOR]
Using library USBHost_t36 at version 0.1 in folder: T:\tCode\libraries\USBHost_t36 [COLOR="#FF0000"]:: linked KurtE github[/COLOR]
