I currently use in one of my projects 2 teensy 3.6 (which will probably be replaced by teensy 4.x that it will have as much pin as the teensy 3.6).
The problem is this, it is necessary for my project to be able to switch from one programe to another and to be able to do it from an external support will be a big plus.
I think the solution would be to "inject" a pre-compiler program that found on an SD card but I don't see how to do it.
thank you in advance for your help.
