Use USB mouse mode to drag?
dude8604
I'm using my Teensy 3.1 to control the mouse on my computer. Everything works except for dragging. When I call Mouse.move(), it seems to reset the mouse button state and just move the mouse. Is there anything else I can do? Thanks.
Also, a slightly related question - I might use a Teensy based keyboard while developing for another Teensy. If both Teensys are connected, how can I make sure it programs the right one when I reprogram it?
Re#2: If you do an IDE Verify - the one getting the button pressed will get the new code.
Re#1: check your code - look at samples - to get other help :: reduce your code to show the problem and post it per 'Forum Rule /\'
@dude8604 - if you have a sample of your efforts it likely would help Paul get to the bottom of it - per msg #3
That Verify is a recurring secret - glad it came back to working for 1.6.3 - but not intuitive as I re-posted twice here and the mag #4 link.
I cannot confirm that there is a problem with drag and drop.
I have a Teensy 3.1 and drag drop works perfectly using Mouse.move() and with Mouse.moveTo().
It works on Windows and on Linux.
There must be a bug in your code.
