USing a NV3030B with Teensy 4.1
janhartmann
Hello,
I would like to ask whether anyone knows of a reason not to use this display with a Teensy 4.1:
Display Waveshare
Wiki Display Waveshare
On the Waveshare Wiki there is an Arduino example, which uses a library written by Waveshare.
I included that in the attachment.
I'm trying to understand if this library will work on the Teensy before buying a bunch of them.
Thanks in advance for any help!
Kind regards
Jan
  • LCD_1inch83 Example Arduino.zip
In my experience, usually the Waveshare libraries work as intended. Hard to say whether this will be the case as well with this particular library.
Can't you just buy 1 piece of display to check it out before ordering a whole bunch? Luckily they are not that expensive.
Paul
