Using EXTMEM to Place Variables in External PSRAM
Thanks to all your help (esp Defragster) , I moved 200K of variables into DMAMEM and the project works better than ever.
I'm getting this warning and I suspect it means my array is not being allocated in DMAMEM. I'm trying to confirm this but I don't know the command to make teensy display available free memory. Since I have no sound engine inthe project yet, DisplayAudioMemoryUsage prints 0, which is not helpful. Can someone explain to me how I might put this array in DMAMEM? My code to use the array requires uint16_t* and everything I've tried thus far has been unsuccessful. The way I am doing it at least compiles. but I am suspicious it's putting the array in RAM1, not RAM2 but, as I said, I am unsure how to confirm this or how to get the result I need.
60 | uint16_t* displayValues = new DMAMEM uint16_t[xDisplay * yDisplay];
SimplexNoiseTest:60: warning: 'used' attribute does not apply to types
All malloc (and new) calls allocate from the heap which is located in RAM2. To confirm just print the address.
That snippet is a bit short of info - quick guess. It is complaining about 'used' which isn't shown there?
I do see "new" - which will by default will do a dynamic allocation in DMAMEM - and adding DMAMEM is at best redundant - and confusing to the compiler?
Perhaps this is the desired?: uint16_t* displayValues = new uint16_t[xDisplay * yDisplay];
Printing the pointer value will indicate where it is located:
Serial.printf("Address at %p\n", displayValues);
And it should be above this address: // RAM (rwx): ORIGIN = 0x20200000, LENGTH = 512K // RAM2 - DMAMEM
