Using of SdFat
Powersoft
I use the code below for acces sd card on a esp32.
The goal is to read blocks. This is my routine to read a Forth screen into the memory.
This is part of my 6502 emulator running with the teensy 4.1.
Is this possible, and what to change to get it running on my teensy.
Thanks for any help.
Cheers,
Jan
C++:
#include "SdFat.h"
SdFat32 sd; // for FAT16/FAT32
File32 file;
File32 file_RW;
void RW(byte *codebuffer, int adr, int blk, int f)
  int bytes_per_block = 128;
  if (f==1) /* read from disk to memory */
    file_RW.seekSet(blk*bytes_per_block);
    for (int i=0; i<bytes_per_block; i++) codebuffer[adr+i] = file_RW.read() & 0x7f;
  else /* write from disk to memory */
    for (int i=0; i<bytes_per_block; i++) file_RW.write(codebuffer[adr+i]);
  SPI.begin(14, 2, 15, 13); //SCK, MISO, MOSI,SS
  Wire.begin();
  if (!sd.begin(13,SD_CONFIG))
    Serial.println("sd.begin failed!");
    return;
  else Serial.println("sd active");
Looks like it ought to work if you delete the unnecessary SPI.begin() and Wire.begin(), and if your SD_CONFIG is defined properly (not shown in the code fragment).
Wich
Thanks, shouls I install a special SDFat library to get it running?
I have no clou how to atach the sd card. Use this code but sd card is not mounted.
File32 file;
File32 file_RW;
#define SD_CONFIG  SdioConfig(FIFO_SDIO)
//#define SD_CONFIG SdSpiConfig(SD_CS_PIN, SHARED_SPI, SD_SCK_MHZ(16))
  Serial.begin(230400);
  // Initialize the SD.
  if (!sd.begin(SD_CONFIG))
    Serial.println("Error mounting sdcard");
You are printing an error message even if sd.begin() succeeds, so maybe it is actually working
   Serial.println("Error mounting sdcard");  // <---- this should be something like "sdcard mounted OK"
