vBat specs??
internett
Hi together,
now searching for couple of hours for vBat specs voltage. I found many info how to connect a coin battery and some use 3.3v (LDO) and/or 3.6/3.7v...(LiPo)
but nowhere found a real spec how much to put in vBat: minimum until it works secured and maximum to not break it/anything.
Please give me a hint or link or information about min/max specs...
Thanks in advance for your support,
The Battery Backup operating range is listed in 1060 Electrical spec as 2.4V to 3.6V on page 23.
There's also a Note #3:
In setting VDD_SNVS_IN voltage with regards to Charging Currents and RTC, refer to the i.MX RT1060 Hardware Development Guide (IMXRT1060HDG).
Assuming OP is talking about Teensy4.x, the above applies.
Also note if a LiPo is used and it's freshly charged, it could present 4.2V to 1060 pin. Magic smoke!
