macdonaldtomw
Hello all,
I'm having trouble figuring out a way to wake from sleep mode using my 4x4 keypad. I'm trying to make it wake up when pin 15 changes
I'm using the Keypad.h library, and the LowPower_Teensy3 library.
Here is my code:
SOLVED:
The following code worked!
Here is my code:
#include <Keypad.h>
#include <LowPower_Teensy3.h>
TEENSY3_LP LP = TEENSY3_LP();
volatile boolean teensySleep=false;
int wakeUPpin=15;
uint32_t Serialbaud = 4800;
const byte ROWS = 4; //four rows
const byte COLS = 4; //three columns
char keys[ROWS][COLS] = {
'1','2','3','A' }
'4','5','6','B' }
'7','8','9','C' }
'*','0','#','D' }
byte colPins[COLS] = {
19, 20, 21, 22}; //connect to the row pinouts of the keypad
byte rowPins[ROWS] = {
15, 16, 17, 18}; //connect to the column pinouts of the keypad
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
char key;
String keyStrokes="";
int numStrokes=0;
KeyState keyState;
static byte kpadState;
void keypadEvent(KeypadEvent key) {
// in here when in alpha mode.
kpadState = keypad.getState( );
if (kpadState == RELEASED){
Serial.println(key);
switch(key){
case'A':
Serial.println("Function A called... putting Teensy to sleep");
teensySleep=true;
void callbackhandler() {
teensySleep= false;
Serial.println("Change on pin 15, disabling Teensy sleep");
//delay(3000);//Give yourself time to open up the serial monitor
pinMode(wakeUPpin, INPUT_PULLUP); //Setup wakeup pin for Teensy
attachInterrupt(wakeUPpin, callbackhandler, CHANGE);
Serial.begin(Serialbaud); //Begin serial communication with Serial Monitor
Serial.println("Serial monitor operational");
keypad.addEventListener(keypadEvent); //Add event listener for keypad strokes
Serial.println("Beginning main loop");
if(teensySleep){
Serial.println("Putting Teensy to sleep");
LP.Sleep();
else{
key= keypad.getKey();
SOLVED:
#include <Keypad.h>
int greenLED1=29;
const byte COLS = 4; //four columns
'1','2','3','A' }
'4','5','6','B' }
'7','8','9','C' }
'*','0','#','D' }
char key;
int numStrokes=0;
KeyState keyState;
switch(key){
case'A':
prepSleepKeys();
digitalWrite(greenLED1, LOW);
delay(50);
Serial.end();
LP.Sleep();
default:
void prepSleepKeys(){
for(int r=0; r<ROWS; r++){ //Configure row pins
pinMode(rowPins[r],INPUT_PULLUP); //Pull row pin high (internal pullup)
attachInterrupt(rowPins[r], callbackhandler, CHANGE); //Add Interrupt on row pin
for (int c=0; c<COLS; c++){
pinMode(colPins[c], OUTPUT); //Connect columns to ground
digitalWrite(colPins[c], LOW);
for(int r=0; r<ROWS; r++){ //Output state of Row pins to serial monitor
if(digitalRead(rowPins[r])){
Serial.println("Row pin " + String(rowPins[r]) + " is HIGH");
else{
Serial.println("Row pin " + String(rowPins[r]) + " is LOW");
for(int c=0; c<COLS; c++){ //Output state of Col pins to serial monitor
if(digitalRead(colPins[c])){
Serial.println("Col pin " + String(colPins[c]) + " is HIGH");
else{
Serial.println("Col pin " + String(colPins[c]) + " is LOW");
Serial.println("Change on a row pin! Teensy now awake!");
digitalWrite(greenLED1, HIGH);
pinMode(greenLED1,OUTPUT); //Define green LED pin
digitalWrite(greenLED1, OUTPUT); //Turn on green LED
delay(5000);
