Hello All
I am a musician, and since i discovered , micro computers, i love working with them.
They have opened a lot of doors that i never knew existed, that i have used in my music journey.
But i still have a lot to learn.
But Learning is the best part
I am using a teensy 4.1 ,and I'm running drums via midi through the ( TEENSY) 4.1.
and i am using Electronic Solenoids to hit the drums.
It works great
But now and then, ( very rarely) a drum may get stuck closed.
This is problematic, because when that happens , the power going to the solenoids ( 24volts) is constant.
Heating up the coil in the solenoid.
If i Diosconnect the teensy from the computer, it un-sticks and rest's
Now these solenoids are strong , and can take the heat, if that happens , but i dont want to damage them.
I got a phone call one day and was not paying attention and one of the solenoids got stuck, and it took at least 40 minutes , but the solenoid caught fire, and i had to make a mad dash for the fire extinguisher.needless to say that solenoid had to be replaced.
But i don't want to have a replay of that.
What I'm trying to do is counter act that when it happens.
From what I understand, this can be counteracted with a watch dog timer.
If i get a stuck drum witch is a stuck midi note,
Now I have the watch dog timer library.
But I don't have enough knowledge to know how to set it up yet.
This is why I need your help can anyone help me with this problem thank you very much in advance.
Here is my sketch
#include <Watchdog_t4.h>
#include <MIDIUSB.h>
// these are the arduino pins that the solenoids are hooked up to
enum drumPins {kickPin = 6, snarePin = 3, hhPin = 5, crashPin = 3, cowbellPin = 4 , openhatPin = 0};
// these are the midi notes that each solenoid triggers on, as well as an alternate for each
enum midiNotes {kickMidi = 2, snareMidi = 4, hhMidi = 3, crashMidi = 49, cowbellMidi = 39, openhatMidi = 46};
enum midiNoteAlts {kickMidiAlt = 44, snareMidiAlt = 48, hhMidiAlt = 45, crashMidiAlt = 149, cowbellMidiAlt = 47, openhatMidiAlt = 146};
// the serial port is just used as a monitor for debugging
// it is not needed for midi
// setup all output pins
for(int i=0; i<=8; i++) {
pinMode(i, OUTPUT);
//listen for new MIDI messages
midiEventPacket_t rx = MidiUSB.read();
processMidi(rx);
void processMidi(midiEventPacket_t rx) {
switch (rx.header) {
case 0x0:
// do nothing
//note on
case 0x9:
handleNoteOn(rx.byte1 & 0xF, rx.byte2, rx.byte3);
//note off
case 0x8:
handleNoteOn(rx.byte1 & 0xF, rx.byte2, 0);
// control change
case 11:
Serial.print("CC: ");
Serial.print(rx.byte2);
Serial.print(":");
Serial.print(rx.byte3);
Serial.print("\n");
default:
Serial.println(rx.header);
void handleNoteOn(byte channel, byte pitch, byte velocity) {
// it is possible to use the actual midi velocity here, just be sure to
// double to value because midi is 0-127
// and then change digitalWrite to analogWrite
if(velocity > 0) {
velocity = HIGH;
switch (pitch) {
case kickMidi:
case kickMidiAlt:
Serial.print("Kick: ");
digitalWrite(kickPin, velocity);
case snareMidi:
case snareMidiAlt:
Serial.print("Snare: ");
digitalWrite(snarePin, velocity);
case hhMidi:
case hhMidiAlt:
Serial.print("HH: ");
digitalWrite(hhPin, velocity);
case crashMidi:
case crashMidiAlt:
Serial.print("Crash: ");
digitalWrite(crashPin, velocity);
case cowbellMidi:
case cowbellMidiAlt:
Serial.print("Cowbell: ");
digitalWrite(cowbellPin, velocity);
case openhatMidi:
case openhatMidiAlt:
Serial.print("Open hat: ");
digitalWrite(openhatPin, velocity);
default:
// print the midi note value, handy for adding new notes
Serial.print("Note(");
Serial.print(pitch);
Serial.print("): ");
if(velocity == 0) {
Serial.println("off");
Serial.println("on");
It works great
Here is my sketch
pinMode(i, OUTPUT);
processMidi(rx);
case 0x0:
// do nothing
//note on
case 0x9:
//note off
case 0x8:
// control change
case 11:
Serial.print(":");
Serial.print("\n");
default:
if(velocity > 0) {
velocity = HIGH;
switch (pitch) {
case kickMidi:
case kickMidiAlt:
case snareMidi:
case snareMidiAlt:
case hhMidi:
case hhMidiAlt:
case crashMidi:
case crashMidiAlt:
case cowbellMidi:
case openhatMidi:
default:
if(velocity == 0) {
