Why is there no example of Teensyduino's USB Raw HID
Boaas
I am using teensy2.0, and I can see in the Code Library of the image below that there is a USB: Raw HID, but WANING: observer
So I clicked on Teensyduino to check, but found that Teensyduino does not have a USB Raw HID. So I wanted to ask if Teensyduino has any examples of writing USB Raw HID's Host and Device. I want to use Teensyduino USB Raw HID to connect and operate the mouse in Teensy2.0
There is a RawHID example. In the Arduino IDE, open File > Examples > Teensy > RawHID > Basic
Paul
Paul
But I took a look at what you said and found no examples of Teensy. My Arduino IDE version is 2.3.2, and I installed package_teensy_index.json in the Additional boards manager URLs, so where is the problem with me?
You are missing all the _Teensy examples
Here this is on my screen
I guess, you first need to select Teensy 4.1 as board
Arduino IDE menus automatically change depending on the selected board. If you haven't selected Teensy, the IDE won't show you Teensy's examples.
Click the "Select Board" drop-down if a Teensy is connected to your PC. Or if you don't have a Teensy connected, use Tools > Board to select any Teensy model. Then you should see the Teensy examples in the File > Example menu.
Thank you
