Raspberry (wav, mp3, ...) --(I2S)--> Teensy --(USB)--> PC ?
faboo
Hi forum!
For my next project, I am trying to play audio from my RPi3, transfer it to my Teensy 4.0 with I2S, and then from the Teensy to my PC via USB.
I have no problem with the audio USB part (I have modified the PlaySynthMusic example with a AudioOutputUSB object and I could perfectly capture the sound with Audacity on my PC.)
Now, I would like to do the same with the audio played on the RPi.
I have setup an I2S connection between the RPi and the Teensy, by connecting GPIO 18, 19, 21 on the RPi to pins BCLK1, LRCLK1, IN1 on the teensy.
I use the following program on teensy:
AudioInputI2Sslave      i2s1;
AudioOutputUSB           usb1;
AudioConnection          patchCord1(i2s1, 0, usb1, 0);
AudioConnection          patchCord2(i2s1, 1, usb1, 1);
   AudioMemory(40);
On the Raspberry, I have modified /boot/config.txt with
dtparam=i2s=on
and
dtoverlay=hifiberry-dac
(I know teensy is not a dac, but what should I use then?)
Then I play some mp3 on the RPi with mpg123, and record on my PC with Audacity.
I get something but... the quality is really bad: the voice sounds like pitched-down + some buzz :lol:
Here is a sample of the sound I get:
http://quefaitesvous.fr/audio/audio-usb.wav
I looked at the wave form of the sound with Audacity, it looks like if the data was chopped and interleaved with blanks:
http://quefaitesvous.fr/audio/scr-audio.png
Any idea for fixing this problem?
Do you have a multimeter which can measure frequency? Or another Teensy which can run the FreqMeasure library?
Can you check what frequency your Raspberry Pi is actually sending on the LRCLK pin?
Hi Paul,
Thanks for such a quick answer!
I am poorly equiped and not used to these technicalities :) but I tried with my multimeter on the LRCK pin (see picture).
1 period = 4.5 x 5us = 22.5us
Then that would be 1/0.0000225 = 44 444Hz
That's the most precise I can do, sorry. Does it help ?
Actually, the simplest way to reproduce the problem is as follow:
I took the example file MyPlaySynth.
I changed the output to USB:
AudioOutputUSB  audioOut;
I added a dummy non-slave I2S input: (I say "dummy" because it's not connected to anything, but without it, I don't get any sound, I don't know why...)
AudioInputI2S       i2s1;
I record from my PC in Audacity --> PERFECT sound
Now I replace the non-slave I2S input by a slave one:
(not connected either)
I record from my PC in Audacity --> BAD sound (actually interleaving audio and blanks every ~135 samples, see picture below)
Is it me who does things wrongly or there is a bug somewhere?
