Hello!
I'm trying to use Serial1.addMemoryForWrite() to increase the size of the transmit buffer so that I can load up my entire serial packet in one go, then go off and do other stuff while it's transmitting.
However, I'm getting the following error:
error: 'class HardwareSerial' has no member named 'addMemoryForWrite'
Serial1.addMemoryForWrite(_serialTXBuff,24);
I'm using a Teensy 3.6 and am using Visual Code / PlatformIO for the IDE. I have Teensyduino 1.55 installed with Arduino 1.8.15.
When I dig into HardwareSerial.h I do not see addMemoryForWrite.
However, when I look at https://github.com/PaulStoffregen/cores/blob/master/teensy3/HardwareSerial.h I do see it there. In fact, that file looks significantly different than what I have (copied below).
Do I have an out of date version, or is this not supported on Teensy 3.6, or am I completely missing something else
#ifdef __cplusplus
#include "Stream.h"
class HardwareSerial : public Stream
public:
constexpr HardwareSerial() {}
virtual void begin(uint32_t baud) { serial_begin(BAUD2DIV(baud)); }
virtual void begin(uint32_t baud, uint32_t format) {
serial_format(format); }
virtual void end(void) { serial_end(); }
virtual void transmitterEnable(uint8_t pin) { serial_set_transmit_pin(pin); }
virtual void setRX(uint8_t pin) { serial_set_rx(pin); }
virtual void setTX(uint8_t pin, bool opendrain=false) { serial_set_tx(pin, opendrain); }
virtual bool attachRts(uint8_t pin) { return serial_set_rts(pin); }
virtual bool attachCts(uint8_t pin) { return serial_set_cts(pin); }
virtual int available(void) { return serial_available(); }
virtual int peek(void) { return serial_peek(); }
virtual int read(void) { return serial_getchar(); }
virtual void flush(void) { serial_flush(); }
virtual void clear(void) { serial_clear(); }
virtual int availableForWrite(void) { return serial_write_buffer_free(); }
using Print::write;
virtual size_t write(uint8_t c) { serial_putchar(c); return 1; }
virtual size_t write(unsigned long n) { return write((uint8_t)n); }
virtual size_t write(long n) { return write((uint8_t)n); }
virtual size_t write(unsigned int n) { return write((uint8_t)n); }
virtual size_t write(int n) { return write((uint8_t)n); }
virtual size_t write(const uint8_t *buffer, size_t size)
{ serial_write(buffer, size); return size; }
virtual size_t write(const char *str) { size_t len = strlen(str);
serial_write((const uint8_t *)str, len);
return len; }
virtual size_t write9bit(uint32_t c) { serial_putchar(c); return 1; }
operator bool() { return true; }
extern HardwareSerial Serial1;
extern void serialEvent1(void);
