I'm just trying to write a sketch in order to send a note on/off message. I've copied the code from the example. I just seem to get a random note appear now and then when using a simple max object.
Also, does the Bounce library use interrupts? Its just I thought if you want a MIDI message to take precedence you would need an interrupt?
Edit: After taking away the CC send command, the problem went away which leads me to ask, how can I transmit CC messages and note messages at the same time efficiently?
#include <Bounce.h> // Bounce library makes button change detection easy
#define kMidiChannel 1
#define kMidiControl 1
Bounce button1 = Bounce(1, 5); // 5 = 5 ms debounce time
pinMode(1, INPUT_PULLUP);
int val = analogRead(14);
val = map(val, 0, 1023, 0, 127);
usbMIDI.sendControlChange(kMidiControl, val, kMidiChannel);
button1.update();
// Note On messages when each button is pressed
if (button1.fallingEdge()) {
usbMIDI.sendNoteOn(60, 99, kMidiChannel); // 60 = C4
// Note Off messages when each button is released
if (button1.risingEdge()) {
usbMIDI.sendNoteOff(60, 0, kMidiChannel); // 60 = C4
