I'm working on a pair of devices that send (Mini Pro + NRF24L01) and receive (Teensy + NRF24L01) raw MIDI bytes from the source device. Currently, I don't even care about what kind of MIDI message it is, I just want to forward it to USB MIDI. There will be no Sysex messages coming in from the source device. I'm not quite sure about running status though - the source might be sending messages with running status.
Teensy's documentation says:
To use this function, I would need to parse the MIDI message.
I have looked at the Interface_3x3 example and it uses SerialMIDI library to read and parse the incoming data:
Is there any way to feed the raw bytes into serialMIDI? Should I use a serial port with TX+RX connected, send raw bytes to it, and read from it using serialMIDI? Seems somewhat overkill to me. Or should I use some other library that's capable of collecting raw bytes and parsing them?
A generic send function is also available, primarily meant for use to forward messages between Serial (5 pin DIN) MIDI or USB Host MIDI.
usbMIDI.send(type, data1, data2, channel)
MIDI_CREATE_INSTANCE(HardwareSerial, Serial1, MIDI1);
if (MIDI1.read()) {
// get a MIDI IN1 (Serial) message
byte type = MIDI1.getType();
byte channel = MIDI1.getChannel();
byte data1 = MIDI1.getData1();
byte data2 = MIDI1.getData2();
usbMIDI.send(type, data1, data2, channel, 0);
