HTU21D negative humidity!
Matadormac
Good morning all.
I am working with a HTU21D humidity and temperature sensor, the same as SparkFun URL https://www.sparkfun.com/products/12064
I am using the i2C communication path and there are no other devices/sensors connected to my Teensy 3.2. I am using Windows 10, Arduino 1.6.8 and TeensyLoader 1.28. I really don't know what to make of this.
Here is what the code below outputs to the serial window: Temperature: -44.2 C Relative Humidity: -6.0 %
I have checked and redone wiring several times.
The only difference between the unit as shown by SparkFun, is that in their image the pull up resistors' solder bridge is shown soldered, on mine they are not yet soldered. However, I have 4.7K pull up resistors on my pcb/Teensy board.
Here is my code (from SparkFun GitHub):
 HTU21D Humidity Sensor Example Code
 By: Nathan Seidle
 SparkFun Electronics
 Date: September 15th, 2013
 License: This code is public domain but you buy me a beer if you use this and we meet someday (Beerware license).
 Get humidity and temperature from the HTU21D sensor.
 Hardware Connections (Breakoutboard to Arduino):
 -VCC = 3.3V
 -GND = GND
 -SDA = A4
 -SCL = A5
 Serial.print it out at 9600 baud to serial monitor.
#define HTDU21D_ADDRESS 0x40  //Unshifted 7-bit I2C address for the sensor
#define TRIGGER_TEMP_MEASURE_HOLD  0xE3
#define TRIGGER_HUMD_MEASURE_HOLD  0xE5
#define TRIGGER_TEMP_MEASURE_NOHOLD  0xF3
#define TRIGGER_HUMD_MEASURE_NOHOLD  0xF5
#define WRITE_USER_REG  0xE6
#define READ_USER_REG  0xE7
#define SOFT_RESET  0xFE
byte sensorStatus;
  delay(2000);
  Serial.println("HTU21D Example!");
  Wire.begin();
  unsigned int rawHumidity = htdu21d_readHumidity();
  unsigned int rawTemperature = htdu21d_readTemp();
  float temperature = calc_temp(rawTemperature);
  float relativeHumidity = calc_humidity(rawHumidity); //Turn the humidity signal into actual humidity
  Serial.print("Temperature: ");
  Serial.print(temperature, 1); //Print float with one decimal
  Serial.print(" C");
  Serial.print(" Relative Humidity: ");
  Serial.print(relativeHumidity, 1);
  Serial.print(" %");
//Read the uncompensated temperature value
unsigned int htdu21d_readTemp()
  //Request the temperature
  Wire.beginTransmission(HTDU21D_ADDRESS);
  Wire.write(TRIGGER_TEMP_MEASURE_NOHOLD);
  Wire.endTransmission();
  //Wait for sensor to complete measurement
  delay(60); //44-50 ms max - we could also poll the sensor
  //Comes back in three bytes, data(MSB) / data(LSB) / CRC
  Wire.requestFrom(HTDU21D_ADDRESS, 3);
  //Wait for data to become available
  int counter = 0;
  while(Wire.available() < 3)
    counter++;
    delay(1);
    if(counter > 100) return 998; //Error out
  unsigned char msb, lsb, crc;
  msb = Wire.read();
  lsb = Wire.read();
  crc = Wire.read(); //We don't do anything with CRC for now
  unsigned int temperature = ((unsigned int)msb << 8) | lsb;
  temperature &= 0xFFFC; //Zero out the status bits but keep them in place
  return temperature;
//Read the humidity
unsigned int htdu21d_readHumidity()
  byte msb, lsb, checksum;
  //Request a humidity reading
  Wire.write(TRIGGER_HUMD_MEASURE_NOHOLD); //Measure humidity with no bus holding
  //Hang out while measurement is taken. 50mS max, page 4 of datasheet.
  delay(55);
  //Read result
  int counter = 0;
    counter++;
    delay(1);
    if(counter > 100) return 0; //Error out
  msb = Wire.read();
  lsb = Wire.read();
  checksum = Wire.read();
  unsigned int rawHumidity = ((unsigned int) msb << 8) | (unsigned int) lsb;
  rawHumidity &= 0xFFFC; //Zero out the status bits but keep them in place
  return(rawHumidity);
//Given the raw temperature data, calculate the actual temperature
float calc_temp(int SigTemp)
  float tempSigTemp = SigTemp / (float)65536; //2^16 = 65536
  float realTemperature = -46.85 + (175.72 * tempSigTemp); //From page 14
  return(realTemperature);
//Given the raw humidity data, calculate the actual relative humidity
float calc_humidity(int SigRH)
  float tempSigRH = SigRH / (float)65536; //2^16 = 65536
  float rh = -6 + (125 * tempSigRH); //From page 14
  return(rh);
//Read the user register
byte read_user_register(void)
  byte userRegister;
  //Request the user register
  Wire.write(READ_USER_REG); //Read the user register
  //Read result
  Wire.requestFrom(HTDU21D_ADDRESS, 1);
  userRegister = Wire.read();
  return(userRegister);
//Write to the user register
//NOTE: We disable all bits except for measurement resolution
//Bit 7 & 0 = Measurement resolution
//Bit 6 = Status of battery
//Bit 5/4/3 = Reserved
//Bit 2 = Enable on-board heater
//Bit 1 = Disable OTP reload
void write_user_register(byte thing_to_write)
  byte userRegister = read_user_register(); //Go get the current register state
  userRegister &= 0b01111110; //Turn off the resolution bits
  thing_to_write &= 0b10000001; //Turn off all other bits but resolution bits
  userRegister |= thing_to_write; //Mask in the requested resolution bits
  //Request a write to user register
  Wire.write(WRITE_USER_REG); //Write to the user register
  Wire.write(userRegister); //Write to the data
//Give this function the 2 byte message (measurement) and the check_value byte from the HTU21D
//If it returns 0, then the transmission was good
//If it returns something other than 0, then the communication was corrupted
//From: http://www.nongnu.org/avr-libc/user-manual/group__util__crc.html
//POLYNOMIAL = 0x0131 = x^8 + x^5 + x^4 + 1 : http://en.wikipedia.org/wiki/Computation_of_cyclic_redundancy_checks
#define SHIFTED_DIVISOR 0x988000 //This is the 0x0131 polynomial shifted to farthest left of three bytes
unsigned int check_crc(uint16_t message_from_sensor, uint8_t check_value_from_sensor)
  //Test cases from datasheet:
  //message = 0xDC, result is 0x79
  //message = 0x683A, result is 0x7C
  //message = 0x4E85, result is 0x6B
  uint32_t remainder = (uint32_t)message_from_sensor << 8; //Pad with 8 bits because we have to add in the result/check value
  remainder |= check_value_from_sensor; //Add on the check value
  uint32_t divsor = (uint32_t)SHIFTED_DIVISOR;
  for (int i = 0 ; i < 16 ; i++) //Operate on only 16 positions of max 24. The remaining 8 are our remainder and should be zero when we're done.
    //Serial.print("remainder:  ");
    //Serial.println(remainder, BIN);
    //Serial.print("divsor:     ");
    //Serial.println(divsor, BIN);
    //Serial.println();
    if( remainder & (uint32_t)1<<(23 - i) ) //Check if there is a one in the left position
      remainder ^= divsor;
    divsor >>= 1; //Rotate the divsor max 16 times so that we have 8 bits left of a remainder
  return remainder;
Hello the list.
My bad. An accidental brush of the mini USB connection resulted in normal function of the sensor and correct seeming temp and Rh readings. It appears that the usb connector on my Teensy has become worn and the mechanical/electrical connection is sometimes faulty. A slight downward pressure on the USB male connector and the readings are correct.
Oh well, better late than never.
Thank you
