I'm recently having an issue with my Teensy hanging in what appears to be the EthernetUDP constructor. I have simplified the code to the following which loads and runs fine as long as the declaration is left commented out. If I declare the Udp variable it hangs and doesn't connect COM3 or get to the point of starting Serial Monitor. I had been using a program successfully receiving UDP packets for several weeks and only ran into this issue this week when I wanted to make a couple changes.
#include <NativeEthernet.h>
#include <NativeEthernetUdp.h>
// MAC address and IP address for the Teensy board.
byte mac[] = { 0x04, 0xE9, 0xE5, 0x0D, 0x31, 0x2B };
bool useDHCP = false;
IPAddress ip(192, 168, 0, 5);
unsigned int localPort = 8888; // local port to listen on
// An EthernetUDP instance to let us send and receive packets over UDP
EthernetUDP Udp;
int led = 8;
// the setup routine runs once when you press reset:
// initialize the digital pin as an output.
pinMode(led, OUTPUT);
pinMode(13, OUTPUT);
while (!Serial)
; // wait for serial port to connect. Needed for native USB port only
delay(10);
Serial.println("Serial Connection complete");
digitalWrite(13, HIGH); // turn the LED on (HIGH is the voltage level)
digitalWrite(led, HIGH); // turn the LED on (HIGH is the voltage level)
delay(100); // wait for a second
digitalWrite(13, LOW); // turn the LED on (HIGH is the voltage level)
digitalWrite(led, LOW); // turn the LED off by making the voltage LOW
Serial.println("Serial looping");
The compiler produces the following output:
Warning: Board teensy:avr:teensy32 doesn't define a 'build.board' preference. Auto-set to: AVR_TEENSY32
Memory Usage on Teensy 4.1:
FLASH: code:195788, data:72960, headers:8748 free for files:7848968
RAM1: variables:23840, code:61384, padding:4152 free for local variables:434912
RAM2: variables:12416 free for malloc/new:511872
No Teensy boards were found on any USB ports of your computer.
RUN: "C:\Program Files (x86)\Arduino\hardware\teensy\..\tools\arm\bin\\arm-none-eabi-gdb" -ex "target extended-remote \\.\COM3" "C:\Users\vandertr\AppData\Local\Temp\arduino_build_473643\MyBlink.ino.elf"
Board at COM3 is not available
I have seen a reference to the QNEthernet library but haven't tried it. I'm looking to use a very simple library since all I'm doing is receiving packets being sent.
Thanks in Advance.
EthernetUDP Udp;
int led = 8;
while (!Serial)
delay(10);
Thanks in Advance.
