Hello! Long story short, I accidentally ordered this one instead of the 512Mb version, which is officially supported by LittleFS, and it is soldered to the larger QSPI expansion pads on the back of the Teensy. Using LittleFS normally with the standard init code they have on Github they have in the examples folder, the chip fails to initialize. Looking on Github, there was a commit a while back that added the chip to the list of supported chips in the LittleFS code, so I replaced the library being used by PlatformIO with the version of the code on Github and enabled a bunch of normally disabled print statements in LittleFS itself, and doing this I can tell that the chip is correctly detected by the Teensy as a 128 MB Flash chip, but fails to initialize. Is there a way to get the chip to work with LittleFS (or any other library for that matter- I don't really care a ton about write speed so if a different library works I'm open to using it), or do I need to go back and buy the correct chip?
Thank you
Thank you
