Code Troubleshoot -- FastLED+Audio+Servo
Okay, still working on my animatronics project.
Note that I am using a Teensy 3.5 and a custom PCB
Using PWMServo.h rather than Servo.h so that the servo motor runs simultaneously with the audio amplitude reading. It works pretty well!!
Also, using the "WS2812" serial library and I pasted in parts of "DemoReel100" from the FastLED library.
Long story short -- The LEDs do not run while the other code is going.
I believe the function called void loop_state_playing() needs to be worked on. Inserting a fastLED.delay here will stop the servo from functioning so... not sure what to do.
The LED code and the other code in here have been tested independently and they work.
Any advice?
Thanks y'all!
#include <PWMServo.h>
// From FastLED Cylon Example, using Non-Blocking WS2812Serial
#include <WS2812Serial.h>
#define USE_WS2812SERIAL
#include <FastLED.h>
// Configuration
// Connections
#define SERVO_PIN 10 // Jaw servo
#define PING_PIN 5 // ping / echo for sonar distance sensor
#define ECHO_PIN 6
#define MOSFETPin 9 // mostfet for servo power control
// How long until the ping returns to consider it a "trigger"
#define SONAR_THRESHOLD 900 // microseconds.
// Speed of sound in air is about 343 m/s, so this is about 15 cm (~6 in), or a 30cm round trip.
// Quick calculators:
// const SONAR_THRESHOLD (148 * 6) // ~inches
// const SONAR_THRESHOLD (58 * 15) // ~cm
// Servo range configuration
#define JAW_OPEN 70
#define JAW_CLOSED 0
// Length of time for `loop()` to run. 1000/25 Hz (40ms) should be pretty fluid
#define SAMPLE_TIME 200 // ms
// Sound file to play when sonar triggers
#define SAMPLE_FILE "01.wav"
// Delay playback to compensate for the jaw servo's lag.
#define SERVO_DELAY 50 // ms
// FastLED settings
#define LED_TYPE WS2812
#define COLOR_ORDER GRB
#define NUM_LEDS 10
CRGB leds[NUM_LEDS];
#define BRIGHTNESS 20
#define FRAMES_PER_SECOND 200
// To play with this, import the below block into https://www.pjrc.com/teensy/gui/
// playSdWav1 will use the built-in sd card slot, assumed to have a fat32 filesystem.
// If you're using some other way to attach SD, or you'd like to use in-memory or
// whatever, there are other options.
AudioPlaySdWav playSdWav1; //xy=329,371
AudioMixer4 mixer1; //xy=548,386
AudioEffectDelay delay1; //xy=749,424
AudioOutputAnalog dac1; //xy=951,421
AudioAnalyzePeak peak1; //xy=973,360
AudioConnection patchCord1(playSdWav1, 0, mixer1, 0);
AudioConnection patchCord2(playSdWav1, 1, mixer1, 1);
AudioConnection patchCord3(mixer1, delay1);
AudioConnection patchCord4(delay1, 0, peak1, 0);
AudioConnection patchCord5(delay1, 1, dac1, 0);
#define SDCARD_CS_PIN BUILTIN_SDCARD
#define SDCARD_MOSI_PIN 11 // not actually used
#define SDCARD_SCK_PIN 13
PWMServo jaw;
// Entirely optional. For stable sample management. `elapsedMillis` is a teensy type that
// automatically counts up, so it's useful for making sure if you want 25Hz, you _get_ 25Hz.
elapsedMillis timing;
int ping() {
digitalWrite(PING_PIN, LOW);
delayMicroseconds(2);
digitalWrite(PING_PIN, HIGH);
delayMicroseconds(10);
if (pulseIn(ECHO_PIN, HIGH, SONAR_THRESHOLD) != 0) {
return HIGH;
return LOW;
uint8_t mosfet_state = LOW;
void set_mosfet(uint8_t state) {
if (state != mosfet_state) {
Serial.print("Setting MOSFET to ");
Serial.println(state == LOW ? "LOW" : "HIGH");
mosfet_state = state;
digitalWrite(MOSFETPin, mosfet_state);
Serial.println("initializing audio memory");
LEDS.addLeds<WS2812SERIAL, 32, RGB>(leds, NUM_LEDS);
// tell FastLED there's 60 NEOPIXEL leds on pin 33
LEDS.addLeds<WS2812SERIAL, 33, RGB>(leds, NUM_LEDS);
// set master brightness control
FastLED.setBrightness(BRIGHTNESS);
// Set up audio memory. You need at least 1 block for each 2.9 ms of delay, plus
// a minimum of 8 blocks for the player.
AudioMemory((int) (ceil(SERVO_DELAY / 2.9) + 8));
Serial.println("initializing pins");
jaw.attach(SERVO_PIN);
pinMode(PING_PIN, OUTPUT);
pinMode(ECHO_PIN, INPUT);
pinMode(MOSFETPin, OUTPUT);
delay1.delay(0, 0);
delay1.delay(1, SERVO_DELAY);
delay1.disable(2);
delay1.disable(3);
delay1.disable(4);
delay1.disable(5);
delay1.disable(6);
delay1.disable(7);
mixer1.gain(0, 1.0);
mixer1.gain(1, 1.0);
mixer1.gain(2, 0);
mixer1.gain(3, 0);
Serial.println("initializing SD access");
SPI.setMOSI(SDCARD_MOSI_PIN);
SPI.setSCK(SDCARD_SCK_PIN);
// stop here, but print a message repetitively
while (1) {
Serial.println(SD.begin(SDCARD_CS_PIN));
//FastLED modes
// List of patterns to cycle through. Each is defined as a separate function below.
typedef void (*SimplePatternList[])();
SimplePatternList gPatterns = { rainbow, rainbowWithGlitter, confetti, sinelon, juggle, bpm };
uint8_t gCurrentPatternNumber = 0; // Index number of which pattern is current
uint8_t gHue = 0; // rotating "base color" used by many of the patterns
void loop_state_waiting() {
if (mosfet_state == HIGH) {
Serial.println("playback ended; returning to sleep.");
set_mosfet(LOW);
if (ping() == HIGH) {
Serial.println("sonar ping! Starting sound/animation.");
set_mosfet(HIGH);
playSdWav1.play(SAMPLE_FILE);
//gPatterns[gCurrentPatternNumber]();
delay(5);
void loop_state_playing() {
if (peak1.available()) {
float level = peak1.readPeakToPeak();
int new_servo_pos = (int) (level * (JAW_OPEN - JAW_CLOSED) / 2.0 + JAW_CLOSED);
Serial.print("Level: ");
Serial.print(level);
Serial.print("; servo: ");
Serial.println(new_servo_pos);
jaw.write(new_servo_pos);
rainbow();
FastLED.show();
// resets the counter
timing = 0;
if (!playSdWav1.isPlaying()) {
loop_state_waiting();
loop_state_playing();
// Only delay for the remaining time in the sample.
delay(SAMPLE_TIME - timing);
//FastLED Mode functions
#define ARRAY_SIZE(A) (sizeof(A) / sizeof((A)[0]))
void nextPattern()
// add one to the current pattern number, and wrap around at the end
gCurrentPatternNumber = (gCurrentPatternNumber + 1) % ARRAY_SIZE( gPatterns);
void rainbow()
// FastLED's built-in rainbow generator
fill_rainbow( leds, NUM_LEDS, gHue, 7);
void rainbowWithGlitter()
// built-in FastLED rainbow, plus some random sparkly glitter
rainbow();
addGlitter(80);
void addGlitter( fract8 chanceOfGlitter)
if( random8() < chanceOfGlitter) {
leds[ random16(NUM_LEDS) ] += CRGB::White;
void confetti()
// random colored speckles that blink in and fade smoothly
fadeToBlackBy( leds, NUM_LEDS, 10);
int pos = random16(NUM_LEDS);
leds[pos] += CHSV( gHue + random8(64), 200, 255);
void sinelon()
// a colored dot sweeping back and forth, with fading trails
fadeToBlackBy( leds, NUM_LEDS, 20);
int pos = beatsin16( 13, 0, NUM_LEDS-1 );
leds[pos] += CHSV( gHue, 255, 192);
void bpm()
// colored stripes pulsing at a defined Beats-Per-Minute (BPM)
uint8_t BeatsPerMinute = 62;
CRGBPalette16 palette = PartyColors_p;
uint8_t beat = beatsin8( BeatsPerMinute, 64, 255);
for( int i = 0; i < NUM_LEDS; i++) { //9948
leds[i] = ColorFromPalette(palette, gHue+(i*2), beat-gHue+(i*10));
void juggle() {
// eight colored dots, weaving in and out of sync with each other
byte dothue = 0;
for( int i = 0; i < 8; i++) {
leds[beatsin16( i+7, 0, NUM_LEDS-1 )] |= CHSV(dothue, 200, 255);
dothue += 32;
