Jim the Kiwi
Recently I purchased an Adafruit SSD1306 128 x 64 Monochrome OLED display and connected it to a Teensy 3.2 to try and get it up and running as a small display for a temperature measurement project.
following the guide for Monochrome OLED breakouts and trying to run in I2C mode I did the following:
Downloaded the latest Adafruit GFX library from Github 1.2.2
And downloaded the Adafruit_SSD1306 library and loaded them into my Arduino library folder by .zip extraction
And then the example program 128 x 64 I2C would not compile so edited the .h file to suit 128 x 64 and ran the i2c scanner and saw the device address was
0x3D so changed the define from 0x3C to 0x3D
Tried to compile and got:
Arduino: 1.6.13 (Windows 7), TD: 1.33, Board: "Teensy 3.2 / 3.1, Serial, 96 MHz optimize speed (overclock), US English"
WARNING: Category 'Real-time clock' in library DS3231 is not valid. Setting to 'Uncategorized'
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: In member function 'virtual void Adafruit_SSD1306::drawPixel(int16_t, int16_t, uint16_t)':
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:123:14: error: 'swap' was not declared in this scope
swap(x, y);
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: At global scope:
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:402:6: error: prototype for 'void Adafruit_SSD1306::dim(boolean)' does not match any in class 'Adafruit_SSD1306'
void Adafruit_SSD1306::dim(boolean dim) {
In file included from C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:28:0:
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.h:142:8: error: candidate is: void Adafruit_SSD1306::dim(uint8_t)
void dim(uint8_t contrast);
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: In member function 'virtual void Adafruit_SSD1306::drawFastHLine(int16_t, int16_t, int16_t, uint16_t)':
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:526:16: error: 'swap' was not declared in this scope
swap(x, y);
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp: In member function 'virtual void Adafruit_SSD1306::drawFastVLine(int16_t, int16_t, int16_t, uint16_t)':
C:\Users\Jim V\Documents\Arduino\libraries\Adafruit_SSD1306\Adafruit_SSD1306.cpp:594:16: error: 'swap' was not declared in this scope
swap(x, y);
Error compiling for board Teensy 3.2 / 3.1.
Can anyone help?
I did set the addresses on the solder pads and it will scan and show 0x3D
Jim the Kiwi
This is a library for our Monochrome OLEDs based on SSD1306 drivers
Pick one up today in the adafruit shop!
------> http://www.adafruit.com/category/63_98
These displays use SPI to communicate, 4 or 5 pins are required to
interface
products from Adafruit!
BSD license, check license.txt for more information
All text above, and the splash screen must be included in any redistribution
#if ARDUINO >= 100
#include "Arduino.h"
#else
#include "WProgram.h"
#ifdef __SAM3X8E__
typedef volatile RwReg PortReg;
typedef uint32_t PortMask;
#else
typedef volatile uint8_t PortReg;
typedef uint8_t PortMask;
#include <Adafruit_GFX.h>
#define BLACK 0
#define WHITE 1
#define SSD1306_I2C_ADDRESS 0x3D // 011110+SA0+RW - 0x3C or 0x3D
// Address for 128x32 is 0x3C
// Address for 128x64 is 0x3D (default) or 0x3C (if SA0 is grounded)
SSD1306 Displays
The driver is used in multiple displays (128x64, 128x32, etc.).
Select the appropriate display below to create an appropriately
sized framebuffer, etc.
SSD1306_128_64 128x64 pixel display
SSD1306_128_32 128x32 pixel display
#define SSD1306_128_64
// #define SSD1306_128_32
#if defined SSD1306_128_64 && defined SSD1306_128_32
#error "Only one SSD1306 display can be specified at once in SSD1306.h"
#if !defined SSD1306_128_64 && !defined SSD1306_128_32
#error "At least one SSD1306 display must be specified in SSD1306.h"
#define SSD1306_LCDWIDTH 128
#define SSD1306_LCDHEIGHT 64
#if defined SSD1306_128_32
#define SSD1306_LCDHEIGHT 32
#define SSD1306_SETCONTRAST 0x81
#define SSD1306_DISPLAYALLON_RESUME 0xA4
#define SSD1306_DISPLAYALLON 0xA5
#define SSD1306_NORMALDISPLAY 0xA6
swap(x, y);
swap(x, y);
swap(x, y);
Can anyone help?
Jim the Kiwi
