USBmidi Read, OnNoteOn, do something on different channels fails
Dear All
I got stuck within a code, managing Midi from USB with a Teensy 3.2.
I want to run two Stepper motors seperatly at the Speed of the Midi Note, coming in from two different channels.
(Motor 1 runs on Note from Midi Channel 1 and Motor 2 on Midi Channel 2)
My code is run well, as long only one Midi channel send data.
As soon the other Midi Channel is sending, data the other channel doesnt work.
At the moment I have no Idea if its a bug in my code or some RAM Proble or timing isues.
Hope some of you can help me!
Here is the complete Code:
// Two Stepper Motors runs on the Speed from Midi Notes. (Thanks to the Author of MidiMotor for basic example code)
#include <AccelStepper.h>
//AccelStepper axis(4, 2, 3, 4, 5); // FULL4WIRE Coil 1 - 4 on pin 2,3,4,5
AccelStepper axis1(4, 2, 3, 4, 5); //
//AccelStepper axis(4, 2, 3, 4, 5); // FULL4WIRE Coil 1 - 4 on pin 6,7,8,9
AccelStepper axis2(4, 6, 7, 8, 9); //
float notes[] = {
8.1757989156, // 0
8.6619572180, // 1
9.1770239974, // 2
10.3008611535, // 3
10.3008611535, // 4
10.9133822323, // 5
11.5623257097, // 6
12.2498573744, // 7
12.9782717994, // 8
13.7500000000, // 9
14.5676175474, // 10
15.4338531643, // 11
16.3515978313, // 12
17.3239144361, // 13
18.3540479948, // 14
19.4454364826, // 15
20.6017223071, // 16
21.8267644646, // 17
23.1246514195, // 18
24.4997147489, // 19
25.9565435987, // 20
27.5000000000, // 21
29.1352350949, // 22
30.8677063285, // 23
32.7031956626, // 24
34.6478288721, // 25
36.7080959897, // 26
38.8908729653, // 27
41.2034446141, // 28
43.6535289291, // 29
46.2493028390, // 30
48.9994294977, // 31
51.9130871975, // 32
55.0000000000, // 33
58.2704701898, // 34
61.7354126570, // 35
65.4063913251, // 36
69.2956577442, // 37
73.4161919794, // 38
77.7817459305, // 39
82.4068892282, // 40
87.3070578583, // 41
92.4986056779, // 42
97.9988589954, // 43
103.8261743950, // 44
110.0000000000, // 45
116.5409403795, // 46
123.4708253140, // 47
130.8127826503, // 48
138.5913154884, // 49
146.8323839587, // 50
155.5634918610, // 51
164.8137784564, // 52
174.6141157165, // 53
184.9972113558, // 54
195.9977179909, // 55
207.6523487900, // 56
220.0000000000, // 57
233.0818807590, // 58
246.9416506281, // 59
261.6255653006, // 60
277.1826309769, // 61
293.6647679174, // 62
311.1269837221, // 63
329.6275569129, // 64
349.2282314330, // 65
369.9944227116, // 66
391.9954359817, // 67
415.3046975799, // 68
440.0000000000, // 69
466.1637615181, // 70
493.8833012561, // 71
523.2511306012, // 72
554.3652619537, // 73
587.3295358348, // 74
622.2539674442, // 75
659.2551138257, // 76
698.4564628660, // 77
739.9888454233, // 78
783.9908719635, // 79
830.6093951599, // 80
880.0000000000, // 81
932.3275230362, // 82
987.7666025122, // 83
1046.5022612024, // 84
1108.7305239075, // 85
1174.6590716696, // 86
1244.5079348883, // 87
1318.5102276515, // 88
1396.9129257320, // 89
1479.9776908465, // 90
1567.9817439270, // 91
1661.2187903198, // 92
1760.0000000000, // 93
1864.6550460724, // 94
1975.5332050245, // 95
2093.0045224048, // 96
2217.4610478150, // 97
2349.3181433393, // 98
2489.0158697766, // 99
2637.0204553030, // 100
2793.8258514640, // 101
2959.9553816931, // 102
3135.9634878540, // 103
3322.4375806396, // 104
3520.0000000000, // 105
3729.3100921447, // 106
3951.0664100490, // 107
4186.0090448096, // 108
4434.9220956300, // 109
4698.6362866785, // 110
4978.0317395533, // 111
5274.0409106059, // 112
5587.6517029281, // 113
5919.9107633862, // 114
5919.9107633862, // 115
6644.8751612791, // 116
7040.0000000000, // 117
7458.6201842894, // 118
7902.1328200980, // 119
8372.0180896192, // 120
8869.8441912599, // 121
9397.2725733570, // 122
9956.0634791066, // 123
10548.0818212118, // 124
11175.3034058561, // 125
11839.8215267723, // 126
12543.8539514160 // 127
//! Onboard LED
int ledPin = 13;
//! Are we currently playing a note
bool playing = false;
//! The current motors steps
float curr_speed1 = 0.0;
float curr_speed2 = 0.0;
//! The last note that was recived - used to decide when to turn off the motors
byte last_note1 = 0;
byte last_note2 = 0;
//Define Midi Channel for Motor 1
int axisMidiChan1 = 1;
//Define Midi Channel for Motor 2
int axisMidiChan2 = 2;
//Bool for running Motor 1
bool axis1Run = false;
//Bool for running Motor 2
bool axis2Run = false;
//! Convert a midi note to steps per second
float noteSpeed(byte note)
return notes[note];
//! Called when we recieve a MIDI note-on event
void OnNoteOn(byte channel, byte note, byte velocity)
// If we're not currently playing, then we should try to accelerate
// into the requested note
if(!playing && channel == axisMidiChan1){
last_note1 = note;
curr_speed1 = noteSpeed(note);
Serial.println(String("Note On: ch=") + channel + ", note=" + note); //DEBUG
axis1.enableOutputs();
axis1Run = true;
if(!playing && channel == axisMidiChan2){
last_note2 = note;
curr_speed2 = noteSpeed(note);
axis2.enableOutputs();
axis2Run = true;
playing = true;
digitalWrite(ledPin, HIGH);
//! Called when we recieve a MIDI note-off event
void OnNoteOff(byte channel, byte note, byte velocity)
// Only turn off the last requested note
// This makes it more comfortable to jam on the keyboard
if (channel == axisMidiChan1 && note == last_note1){
axis1Run = false;
Serial.println(String("Note Off: ch=") + channel + ", note=" + note); //DEBUG
axis1.disableOutputs();
if (channel == axisMidiChan2 && note == last_note2){
axis2Run = false;
axis2.disableOutputs();
if (axis1Run == false && axis2Run == false){
playing = false;
digitalWrite(ledPin, LOW);
pinMode(ledPin, OUTPUT);
axis1.setMaxSpeed(2100);
axis2.setMaxSpeed(2100);
usbMIDI.setHandleNoteOff(OnNoteOff);
usbMIDI.setHandleNoteOn(OnNoteOn);
Serial.println("MIDI Input Test");
usbMIDI.read();
if(playing)
if (axis1Run == true){
axis1.runSpeed();
axis1.setSpeed(curr_speed1);
if (axis2Run == true){
axis2.runSpeed();
axis2.setSpeed(curr_speed2);
