iRacing Button Box - Code
I'm using a Teensy 2.0 to build a button box that will be used with iRacing to control most all of the in-car controls and settings in-game. The project will eventually be expanded to around 120 control wired up in a 12x10 grid and utilizing push-button momentaries, a couple on-off toggles, a few rotary encoders, and a pair of 12-position rotaries.
Right now, I'm just familiarizing myself with the Arduino software, learning how to make sketches, and taking my time making sure everything works right. I'm using a simple breadboard and wires until everything is working smoothly. Currently, I'm trying to get a 3x3 matrix of momentary switches to work in-game. Once I've got that I'll figured out, I'll expand the project.
I have run across a few problems that I've researched to solve, but I have some more that have popped up in the process.
Here is my code so far. I'm utilizing a keypad matrix.
// Button Box Sketch Initial Prototype
// Rev. 1.0
// Travis Mihm
// Initialize the integers for the Row and Column Matrix
const int numRows = 3; // Number of Rows is assigned as a constant integer
const int numCols = 3; // Number of Columns is assigned as a constant integer
const int debounceTime = 250; // Set the milliseconds for debounce as a constant integer
//Use Keymap to define the character for the buttons when pressed
char keymap[numRows][numCols] = // the keymap assignments remain constant characters
{'1','2','3'},
{'4','5','6'},
{'7','8','9'}
//Set array for pins being used
const int rowPins[numRows] = {11, 12, 13}; //Assign constant integers relating the number of rows to their corresponding pins
const int colPins[numCols] = { 8, 9, 10}; //Assign constant integers relating the number of columns to their corresponding pins
//Begin setup procedure
Serial.begin(9600); // Start conversation with the serial port
for (int row = 0; row < numRows; row++) // For loop; Initial condition is the ingeger "row" set at zero. It then tests to see of the row integer is less than
// the numRows integer. If true, the statement {} runs, and the integer "row" is incremented. If false, the for loop
// terminates
pinMode(rowPins[row], INPUT); // Set row pins as input type
digitalWrite(rowPins[row], HIGH); // Turn on Pull-Ups
for (int column = 0; column < numCols; column++) // Same loop with the rows, but for the columns now
pinMode(colPins[column], OUTPUT); // Set column pins as output pins
digitalWrite(colPins[column], HIGH); // Set all columns inactive initially
// The "for" loops were to set the initial ready-conditions for the board. Now the code begins the body of the loop procedures to output which buttons get pressed
char key = getKey();
if( key != 0)
Serial.print("You pressed ");
Serial.println(key);
// returns the the key pressed, or 0 if no key is pressed.
char getKey()
char key = 0;
digitalWrite(colPins[column], LOW); //Activate (column number)
for(int row = 0; row < numRows; row++) //Scan rows on this column for a
//key press
if(digitalRead(rowPins[row]) == LOW) //When key is pressed...
delay(debounceTime); // Set the time for the debounceTime integer
while(digitalRead(rowPins[row]) == LOW); // While the row for the column being scanned is still active
key = keymap[row][column]; // The key integer is now whatever was set in the keymap function under the current row and column being scanned
digitalWrite(colPins[column], HIGH); // Deactivate the current column
return key; // returns the current key intiger to the getKey function. This ends the getKey loop and starts it over again.
1. - First, I'd like to be able to name the buttons more than just one character. I cannot seem to figure out the process for that. I tried using something like "A1" instead of 'A1' as from what I understood, the "" marks were the solution to my problem.
2. - I currently have the debounceTime at 250ms; any less than that, and I get the stray double-press when the momentary switch is released. However, I'd rather use something like a button state change. That will be useful for my toggle switches, as I really want those to act like momentaries (the toggle is really just for looks, to mimic an ignition switch, starter switch, etc. So one would toggle on or off like a momentary, another would only trigger when toggling from off to on, etc.) and I assume would be useful for the encoders as well. But I'm a little confused on how I'd incorporate a button state change into a matrix. Am I just overthinking it?
3. - I'm still a little confused on how I get the button presses recognized by my computer/iRacing. Is this where USB Type comes into play? Would I be able to name the switches through that?
My apologies if this has all been asked recently or are commonly solved around here. I have a head injury that has affected my working memory, and it gets a little tough to remember how I solved a problem, if I had found a solution somewhere, what I was trying to solve in the first place, etc ;) Lots of sticky notes and lists and diagrams drawn out right now. If I need to include a schematic let me know, but it's fairly easy to deduce how it's wired up.
I have not touched the USB Type, it's still set at serial. Will I be able to communicate through iRacing at all with it on Serial, or will I have to change the device type to something else?
-Travis
