Sysex with Launchpad MK2 and usbhost_t36
Hi everyone!
I am trying to rewrite my Processing code, that makes my Launchpad MK2 work like a sequencer, to Arduino so it can run on a Teensy 3.6. I am sending and receiving MIDI now, however I get stuck on sending sysex messages to the Launchpad.
For example, in my Processing code I send three sysex messages:
myLaunchpad1.sendMessage( new byte[] {(byte)0xF0, (byte)0x00, (byte)0x20, (byte)0x29, (byte)0x02, (byte)0x18, (byte)0x0E, (byte)0x00 } ); // reset launchpad
myLaunchpad1.sendMessage( new byte[] {(byte)0xF0, (byte)0x00, (byte)0x20, (byte)0x29, (byte)0x02, (byte)0x18, (byte)0x22, (byte)0x02, (byte)0xF7} ); // session layout select (user 2)
myLaunchpad1.sendMessage( new byte[] {(byte)0xF0, (byte)0x00, (byte)0x20, (byte)0x29, (byte)0x02, (byte)0x18, (byte)0x28, (byte)0x00, (byte)0x59, (byte)0x05, (byte)0xF7 } ); // scene launch volume button RED pulse
I am trying to do the same in Arduino by running this in setup():
#include "USBHost_t36.h"
USBHost myusb;
USBHub hub1(myusb);
USBHub hub2(myusb);
USBHub hub3(myusb);
MIDIDevice_BigBuffer midi1(myusb);
while (!Serial) ; // wait for Arduino Serial Monitor
Serial.println("USB Host Testing");
myusb.begin();
delay(3000);
uint8_t resetSysEx[] =
0xF0, 0x00, 0x20, 0x29, 0x02, 0x18, 0x0E, 0x00 // reset launchpad
uint8_t sessionLayoutSysEx[] =
0xF0, 0x00, 0x20, 0x29, 0x02, 0x18, 0x22, 0x02, 0xF7 // session layout select (user 2)
uint8_t pulseButtonSysEx[] =
0xF0, 0x00, 0x20, 0x29, 0x02, 0x18, 0x28, 0x00, 0x59, 0x05, 0xF7 // pulse volume scene launch red
midi1.sendSysEx(resetSysEx, 8, true, 1);
midi1.sendSysEx(sessionLayoutSysEx, 9, true, 1);
midi1.sendSysEx(pulseButtonSysEx, 11, true, 1);
However I am not achieving the same results. When I look at the output I get the following four lines repeatedly (I deleted 60x "00" for each MIDI Data line):
IDIDevice transmit complete
MIDI Data: 14 61 41 00
MIDIDevice transmit complete
MIDI Data: 14 00 19 41
MIDI Data: 14 00 00 19
MIDI Data: 14 41 00 00
When I was looking for some sysex issues I found a lot on buffersizes, however I do not feel that the messages I am trying to send are that large?
Can anybody tell me what I am doing wrong here?
Thanks! :)
