Hey guys,
So I have my reading and this input generated from: tip touching(or almost touching) a conductive sample --> tiny current going through amplifier --> goes to teensy
the whole circuit & teensy powered by external 3.3V. As known that there is floating voltage problem, but 1.I cannot solve it by conducting to the ground because I need to read that input. 2.I cannot solve it by adding resistor because I think it will filter out my tiny current ( the floating is random reading between 900~2000, current i want to read around 1200~1400 and it kind of satbilize in a range of ±100 to each other)
the reason why this is a problem to me right now is because i need to add a motor that level down the tip to the sample, i was hoping the pin could read nothing/something tiny, and when I approach my tip to the sample, the current kind of tunnel through the tip and goes to the teensy, and the motor will automatically stop
If anyone has any idea to help, that would be great and I will really appreciate it
Thanks!
Thanks!
