Biquad setLowShelf / setHighShelf methods not accessable from Audio library
insane
This is so odd... and I can't figure out the problem.
I'm making a simple usb external audio adapter to test out filters for a larger project, but the compiler doesn't recognize the setLowShelf and setHighShelf biquad members. I get the following error: "ExternalTeensySoundCard:49: error: 'class AudioFilterBiquad' has no member named 'setHighShelf'".
There is only a single Audio-master library on the system, and the filter_biquad.h file defines both the setLowShelf and setHighShelf methods, but the IDE just can't find them. Other functions work.
Just a note... the keywords.txt file does not contain KEYWORD2 entries for either, but contains LITERAL1 entries for both.
FILTER_LOSHELF LITERAL1
FILTER_HISHELF LITERAL1
If I add entries for the associated KEYWORD2s, they get highlighted in the IDE, but still get the error and doesn't compile.
Hope somebody can help. Thanks.
AudioInputUSB            usb1;           //xy=63.19999694824219,127.19999694824219
AudioInputI2S            i2s1;           //xy=64.19999694824219,221.1999969482422
AudioFilterBiquad        biquad1;        //xy=228.1999969482422,323.20001220703125
AudioFilterBiquad        biquad2;        //xy=225.1999969482422,363.20001220703125
AudioFilterBiquad        biquad3;        //xy=227.1999969482422,400.20001220703125
AudioFilterBiquad        biquad4;        //xy=227.1999969482422,438.20001220703125
AudioMixer4              mixer2;         //xy=372.20001220703125,283.20001220703125
AudioMixer4              mixer1;         //xy=373.20001220703125,215.1999969482422
AudioFilterStateVariable filter1;        //xy=534.2000122070312,367.20001220703125
AudioFilterStateVariable filter2;        //xy=534.2000122070312,429.20001220703125
AudioOutputUSB           usb2;           //xy=695.2000122070312,216.1999969482422
AudioOutputI2S           i2s2;           //xy=695.2000122070312,273
AudioConnection          patchCord1(usb1, 0, mixer1, 0);
AudioConnection          patchCord2(usb1, 1, mixer2, 0);
AudioConnection          patchCord3(i2s1, 0, mixer1, 1);
AudioConnection          patchCord4(i2s1, 1, mixer2, 1);
AudioConnection          patchCord5(mixer2, 0, usb2, 1);
AudioConnection          patchCord6(mixer2, 0, i2s2, 1);
AudioConnection          patchCord7(mixer1, 0, usb2, 0);
AudioConnection          patchCord8(mixer1, 0, i2s2, 0);
AudioControlSGTL5000     sgtl5000_1;     //xy=512.2000122070312,129
  float freq  = 2000.0f;
  float tGain =  -10.0f;
  float slope =    0.05f;
  // Enable the audio shield and set the output volume.
  AudioMemory( 10 );
  sgtl5000_1.enable();
  sgtl5000_1.volume( 0.5 );
  sgtl5000_1.inputSelect( AUDIO_INPUT_MIC );
  sgtl5000_1.micGain( 36 );
  delay( 1000 );
  biquad1.setHighShelf( 0, freq, tGain, slope );  //stage, freq, gain, slope
  biquad2.setHighShelf( 0, freq, tGain, slope );  //stage, freq, gain, slope
  biquad3.setHighShelf( 0, freq, tGain, slope );  //stage, freq, gain, slope
  biquad4.setHighShelf( 0, freq, tGain, slope );  //stage, freq, gain, slope
  delay( 20 );
Pretty recent--probably not the latest. It's a development shop, so we keep at the same version until it's time to migrate to the next. I'll check tomorrow when I get back to work what the version is; but I'm dubious that it's the problem, though. Do you have something in mind that would point to the Teensyduino version?
Looks like it was added on Jul 18, 2016, check your Audio library's filter_biquad.h to see if those fuctions are there.
Please verify this. If Arduino has found more than 1 library, it will print info about the libs it found and which one it is using and which others it is ignoring. Older Arduino printed this for all cases, but newer versions only show this info when the compile fails. Scroll up and look carefully for any messages about detecting multiple copies of various libs. It should show the full pathname of the one it's really using, and the others it is not.
That was indeed the problem, it was finding the older library in C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio.
The default compile gives no indication of multiple libraries:
ExternalTeensySoundCard: In function 'void setup()':
ExternalTeensySoundCard:46: error: 'class AudioFilterBiquad' has no member named 'setHighShelf'
...but specifying the verbose directive reveals the actual source of the library:
Using library Audio at version 1.03 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Audio
Using library SPI at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SPI
Using library SD at version 1.0.8 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SD
Using library SerialFlash at version 0.4 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\SerialFlash
Using library Wire at version 1.0 in folder: C:\Program Files (x86)\Arduino\hardware\teensy\avr\libraries\Wire
So, if I delete the old Audio library, the (up-to-date) one in Documents\Arduino\libraries is used. That fixes this problem. However, I was under the impression that libraries and hardware defs would be first used from Documents\Arduino\libraries and Documents\Arduino\hardware as the default. Isn't there some technique to make those directories the priorities?
