Need help configuring USB descriptor for audio device
I'm trying to set up a Teensy to be used as a serial device + audio source (to feed audio data to an application).
I successfully used the preset for "Serial + MIDI + Audio" and it works fine, but the device is seen by Windows as COM + audio input AND output (which is not needed) and I also don't need MIDI.
It would be "cleaner" for my application if the device was only reported as COM + audio input.
Is this possible? If so, can someone guide me in what I need to adapt based on the preset?
Thank you very much in advance,
