Hello Everyone!
I recently purchased a Teensy 2.0 for a school project. The goal is to design a mini keyboard with three buttons on it. When pressed buttons 1,2, and 3 will display inputs A,B, and C respectfully. If a button is held, only 1 input of A,B or C will be displayed. I programmed the Teensy 2.0 with Arduino language and downloaded the libraries to communicate with the Teensy 2.0. For some reason, only pin 10 works on the Teensy 2.0. If other pins are used, the display shows the input randomly and the buttons become unresponsive. The lines of code that creates the inputs A, B, and C works properly on pin 10. I comment out only one section of the line to verify the code works. I used different buttons to verify the buttons are correct as well. When attempting to use pins 1-9, the buttons do not work anymore. I move the Teensy 2.0 to other parts of the breadboard and it is still not working. I ruled out the code, buttons, or breadboard ports causing the problem and I believe is the Teensy 2.0 might be faulty. If anyone could give me another point of view that might be causing the problem would be great! If you need more information, do not be afraid to ask
I am using an Teensy 2.0. sanwa buttons which uses two pins (power, ground) http://www.amazon.com/White-Sanwa-Push-Buttons-OBSF-30-W/dp/B00367KDVU and a small breadboard.
Below is the code I am currently using using Arduino:
pinMode(10, INPUT_PULLUP);
int liftedA = 0;
int liftedB = 0;
int liftedC = 0;
//Print "A"
if (digitalRead(10) == HIGH) {
liftedA = 0;
delay(10);
} else if (digitalRead(10) == LOW && liftedA == 0) {
liftedA = 1;
Keyboard.print("A"); // we print a space
//Print "B"
if (digitalRead(9) == HIGH) {
liftedB = 0;
delay(10);
} else if (digitalRead(9) == LOW && liftedB == 0) {
liftedB = 1;
Keyboard.print("B"); // "B" is printed
//Print "C"
if (digitalRead(8) == HIGH) {
liftedC = 0;
delay(10);
} else if (digitalRead(8) == LOW && liftedC == 0) {
liftedC = 1;
Keyboard.print("C"); // we print a space
delay(10);
int liftedA = 0;
int liftedB = 0;
int liftedC = 0;
//Print "A"
liftedA = 0;
delay(10);
liftedA = 1;
//Print "B"
liftedB = 0;
delay(10);
liftedB = 1;
//Print "C"
liftedC = 0;
delay(10);
liftedC = 1;
delay(10);
